April 22Apr 22 I am looking for some recommendations for a concealed cistern, I already have the bathroom suite but decided I was not spending £150 on the cistern they had in the showroom. I was on a commercial site inspection a few weeks ago and had a look at the cisterns going in behind the wall panels - they were Ideal Standard Concela 3 - looked decent, well made, good commercial option - I also took the IPS off the wall at work and had a look and we have Viva Sanitary Skylo which I can order through Amazon or B&Q for about £33. I see other options like Nuie etc, Flomasta. Don't get me wrong, I am a brand guy, I like good brands, Bosch, Miele, Samsung etc. I buy OEM car parts, quality professional grade tools, MK sockets, Schneider consumer units, Prysmian cable - I am that guy, but when it comes to something like a concealed cistern, I do question just why I should give some of these top brands 3-4 times more for something. I know there are issue with cheap ones delivering poor flush volumes and slow refill, but the Viva one above at work is spot on - does the job, good flush and fast refill and seems OK - £33! Can anyone give me some real-life, hands on experience with some of the other cheaper makes - I need to order something soon.
April 22Apr 22 Have a TECE concealed cistern waiting to be fitted so can't comment on any direct experience of it. But on paper looks good and allows the flush volume to be adjusted and provides for a double flush. Cant recall the price but not likely a budget option. Full maintenance through the flush cover plate. Depends what features you want, and on ease of maintenance through the flush plate I guess. I do have a simple cheap plastic cistern on one toilet which is easily maintained by scoring through the right secret grout lines to then remove the worktop above for full access to maintain.
April 22Apr 22 We ended up with TECE cisterns. Quality seems very good - no issues in operation, very quiet. Instructions are those awful wordless pictograms so sub-optimal but just about workable.
April 27Apr 27 Author On 22/04/2026 at 19:41, Onoff said: Geberit. The End. Looks like I can get one for £80 - if they really are the one to go for... I can do that.
April 27Apr 27 Author On 22/04/2026 at 19:57, Spinny said: Have a TECE concealed cistern waiting to be fitted so can't comment on any direct experience of it. But on paper looks good and allows the flush volume to be adjusted and provides for a double flush. Cant recall the price but not likely a budget option. Full maintenance through the flush cover plate. Depends what features you want, and on ease of maintenance through the flush plate I guess. I do have a simple cheap plastic cistern on one toilet which is easily maintained by scoring through the right secret grout lines to then remove the worktop above for full access to maintain. TECE do look very good from a quick Google, but are overpriced for what they are I think - also don't appear readily available.
April 27Apr 27 1 minute ago, Carrerahill said: Looks like I can get one for £80 - if they really are the one to go for... I can do that. Post a link to the one you can get for £80, as there are different heights and variants. I’ve been fitting Geberit for nearly 25 years, with not so much as a murmur. Fantastic quality and unmatched longevity. Recently installed some Roca ones, very difficult to work on to access internal gubbings 👎
April 27Apr 27 1 hour ago, Nickfromwales said: Roca ones, very difficult to work on to access internal gubbings 👎 Agreed. I had to change a seal in a concealed cistern it is very clever that this is possible through the flush plate.....and it works well again. Part was easy to get and reasonable cost too. The instructions are good too . But my hands are too big/ my clumsiness, and I dropped a small plastic fixing that is then inaccessible, and I had to improvise. I will buy Roca again though.
April 27Apr 27 2 hours ago, Carrerahill said: Looks like I can get one for £80 - if they really are the one to go for... I can do that. Not quite the end as Clive ( @Onoff )suggests. But nearly. We have 2. Care needed with the mechanism that actuates the flush. Its so super- adjustable that its easy to over - or under adjust it. Our Botticelli washer-upper broke (the solid-state circuitry failed) : Geberit came and fixed it, and tried to charge us. One tart email later, silence was the loud response.
April 27Apr 27 15 minutes ago, ToughButterCup said: Care needed with the mechanism that actuates the flush. Its so super- adjustable that its easy to over - or under adjust it. Don't think I adjusted it or anything when it went it. It's just all"worked", forever.
