Alwayslearning22 Posted 7 hours ago Posted 7 hours ago Shower riser rail and shower head - which should be central? It’s above a bath with a screen
ProDave Posted 5 hours ago Posted 5 hours ago Riser rail for me, that is more obvious if not centred. 1
Spinny Posted 3 hours ago Posted 3 hours ago Here is ours. Went with neither 20 years ago, although the screen folds in half inwards, so it helps the screen clear the shower head. The centre line is on the left of the riser, i.e. midway between the riser and the centre of the shower head - you can count the mosaic tiles. 1
ProDave Posted 3 hours ago Posted 3 hours ago 46 minutes ago, Spinny said: Here is ours. Went with neither 20 years ago, although the screen folds in half inwards, so it helps the screen clear the shower head. The centre line is on the left of the riser, i.e. midway between the riser and the centre of the shower head - you can count the mosaic tiles. With controls remote from the shower, I would (I did) put the controls on the left hand wall, so you can reach in and turn the shower on without the cold water in the pipes spraying on you.
