canalsiderenovation Posted March 9 Posted March 9 Has anyone heard of Backyard Discovery? I'm eyeing up this https://www.backyarddiscovery.co.uk/products/2-7m-x-1-8m-bellerose-greenhouse?srsltid=AfmBOoqWCRTgaVCrhYBn4uvSMJGmTkG97VQOB6OdR0rom3ofu__MwLsI After the other half told me that unless I wanted a divorce the chickens had to go, there is now a concrete pad just waiting for something. Who knew that the second hand Omlet chicken stuff actually fetches a fortune... We are trying to avoid glass because the old railway embankment has lots of oak trees and whilst they are high up and the greenhouse wouldn't be shaded the acorns bloody hurt when they fall down on top of you and I suspect they would shatter and crack glass where this potentially may be a bit more sturdy and possibly looks a bit nicer.
FarmerN Posted March 10 Posted March 10 We have just built a new Robinsons greenhouse. I’m amazed at how strong the glass is. It’s toughened glass. Would withstand acorns , but mature oak trees have a habit of shedding branches, that would be a different matter. I think, but am not sure, all greenhouses have to be toughened glass now. If under a tree keeping it clean could be an issue. 1 1
SteamyTea Posted March 10 Posted March 10 The 'glazing' is multi wall poly carbonate sheets, they go 'milky' after a short time and look dreadful. Do they offer an acrylic option ? 1
canalsiderenovation Posted March 10 Author Posted March 10 (edited) 5 hours ago, SteamyTea said: The 'glazing' is multi wall poly carbonate sheets, they go 'milky' after a short time and look dreadful. Do they offer an acrylic option ? I don't think so. I'll message them and see. When we moved in there was an old glass greenhouse that got shattered by a falling tree branch (not in the same place) although it probably wasn't toughened glass either. It was metal and was all rusty etc and generally didn't look great. It's been discounted to £1999 since yesterday and I've been looking at this for at least 9 months and this is the cheapest it has been. Edited March 10 by canalsiderenovation
-rick- Posted March 10 Posted March 10 If the price is good compared to others then maybe worth buying on the basis that you might want to be replacing the polycarb at a later date. I'd guess the polycarb will last a while then all go at a similar time. Glass would get broken one at a time over a period of time requiring occasional replacement. Either way you are replacing bits.
canalsiderenovation Posted March 10 Author Posted March 10 10 minutes ago, -rick- said: If the price is good compared to others then maybe worth buying on the basis that you might want to be replacing the polycarb at a later date. I'd guess the polycarb will last a while then all go at a similar time. Glass would get broken one at a time over a period of time requiring occasional replacement. Either way you are replacing bits. I just had a response from them: We do not offer the option to choose from a different type of material for the sheets used on the greenhouse. However, our 4-wall polycarbonate sheets have been treated with a UV stabilisation that will prevent panels from changing colour through sun exposure. Additionally, whilst our greenhouses are tested against wind and weather, they are purposefully not designed to be fully watertight to allow humidity to escape, which is another benefit as internal condensation can also be reason for the sheets to turn milky over time.
Onoff Posted March 10 Posted March 10 18 hours ago, canalsiderenovation said: Has anyone heard of Backyard Discovery? @Pocster? 1
canalsiderenovation Posted April 27 Author Posted April 27 (edited) Reply to my own post... work in progress. Creosoted most of it before installing but couldn't do it all because each piece was numbered and didn't want to paint over number risking us not being able to locate the right bit! Installation has been a bit of a bu**er at times between the two of us but we are getting there slowly. Its cedar and quality is good, just instructions a bit confusing. It had a fan and digital thermostat but we don't have electricity at that end of the garden but we are going to buy a portable power station (Ecoflow do some good ones like the River 2 pro 768Wh capacity which would be more than enough and serves as a backup for us when we have power cuts). Will be putting gravel in front of it and growing some David Austin Roses onto the pergola. Edited April 27 by canalsiderenovation 2
