Space Race Posted 10 hours ago Posted 10 hours ago Looking at using board on board vertical cladding with a ventilation strip/mesh at the bottom and top of cladding. I'm struggling to find any examples of how these vents are detailed under and above windows. To form a vent over the head of the window seems easier (much like at the base) but I've not found a single example for under. Is this not done? Am i overthinking this If anyone can point me in the direction of ventilation details above and below windows that would be much appreciated
Russell griffiths Posted 9 hours ago Posted 9 hours ago I used the aluminium vent strip the 25x50 strip with all the holes in, this is finished on top of the cladding with a small gap between this and the overhanging window cill.
Mr Punter Posted 9 hours ago Posted 9 hours ago Normally you will leave the battens short of the window opening so the air can flow round. Like this: 1 1
Space Race Posted 9 hours ago Author Posted 9 hours ago 20 minutes ago, Russell griffiths said: I used the aluminium vent strip the 25x50 strip with all the holes in, this is finished on top of the cladding with a small gap between this and the overhanging window cill. How small was the gap?
Space Race Posted 9 hours ago Author Posted 9 hours ago 15 minutes ago, Mr Punter said: Normally you will leave the battens short of the window opening so the air can flow round. Like this: I was thinking the (vertical) frame timbers would be fairly snug up to each side of the window but actually they could stand clear. Then my vertical battens would be spaced as you show. Thanks!
Space Race Posted 8 hours ago Author Posted 8 hours ago Lost track of websites visited, videos watched. Glad I asked here 1
