Mr Blobby Posted February 23 Posted February 23 On the ground floor we have a few inches of airtight paint beneath the wet plaster covering the join between wall and floor. On the first floor we have membrane (aka Tony tray) around hollowcore slabs and plastered into the wall above and below.  So far so good for airtightness. 🤞  But soon the fixing skirting boards will be fixed. With nails. This will of course make lots of nail holes through the (airtight) plaster into the blockwork. Is this going to have a significant impact on airtightess? And if so, is there a better way to fix the skirting?
ProDave Posted February 23 Posted February 23 Mine is all fixed with sticks like sh*t (other glues are available)Â Why make nail holes that need to be filled before painting / staining? Â But if nails are your preferred fixing method they are not an issue as long as the nails remain in place, they are filling the hole they have made.
Russell griffiths Posted February 24 Posted February 24 Who’s fixing skirting with nails, it’s not 1960. good quality grab adhesive. a few pin nails on the external mitres or even mitre bond. 1
Nickfromwales Posted February 25 Posted February 25 If I saw someone beating a few hundred masonry nails into my skirting boards they’d be bounced off down the road.  Onto timber studs with 2nd fix gas fired pins, yes, but onto masonry?  Is Fred Dibnah doing it? 1
