Hi all,
In the wait for planning and before wanting to commit to professional input for building regs drawings, I’m just starting to plan services etc around the house.
The current thing I’m trying to work out is the runs for the soil pipes. These will eventually head out to a treatment plant (to be specced).
Out of the two designs below, which would be preferable?
One option minimises runs under the (insulated raft) slab and has multiple inspection chambers to pick everything up, the second utilises 45 deg branches.
One option allows rodding access from both ends; the branch option only allows rodding from one end. This will need toilet, etc., removing to access?
Any thoughts on which is best? I can’t seem to find any guidance about minimising runs under the slab but common sense says less is more.
Let me know if there are any suggestions, and I'll resketch!
Thank you all
Thank you allScreenshot2026-02-22at20_39_07.thumb.png.7a1bb411ec46dcf48fec6f929e031f0b.pngScreenshot2026-02-22at20_38_58.thumb.png.d457a7ec18f83e05dd2e9c77484ff8ca.png
Top image will not work as you need an inspection chamber at each junction.
2nd image you are going to be metres below surface by the time everything meets up with the fall requirements. Don't like the angles, would aim for 90 degs
Where is the treatment plant going? Start from there first. Longs runs equal very deep.
Noted, I’ll redraw. The site is sloping, but not that much and the fall slipped the ‘design’
Treatment plant will be to the north/top of these drawings. Thank you
