Pocster Posted July 31 Author Posted July 31 Oh yes and the amazing cube marched clouds. VERY expensive! need to optimise again soon !. Lit!, can have a nice storm with them! Which means a detour (as usual) to .... lightening!!!
Pocster Posted August 1 Author Posted August 1 2 hours ago, Pocster said: Pocster's Unreal Kafkaesque Engine P.U.K.E (tm) PUKE now does God rays, lightening storms, ambient occlusion , terrain can influence cloud colours and likewise; same for water etc. So all in the same render pipeline. Limits in webgpu are no more than 16 sampler passes for the march. This limit has been a constant problem. Also back at a crippling frame rate if you have max clouds/max rain and a lightening storm and decide to look at a grazing angle over water!.
Nickfromwales Posted August 2 Posted August 2 9 hours ago, Pocster said: Also back at a crippling frame rate Time to upgrade the machine then........ 1
Pocster Posted August 2 Author Posted August 2 6 hours ago, Nickfromwales said: Time to upgrade the machine then........ Amateur ! Time to analyse shaders ! Optimise 💪
Nickfromwales Posted August 2 Posted August 2 3 hours ago, Pocster said: Amateur ! Time to analyse shaders ! Optimise 💪 And then realise your FPS is still crap, and then it’s……. 10 hours ago, Nickfromwales said: Time to upgrade the machine 1
-rick- Posted August 2 Posted August 2 Just now, Nickfromwales said: And then realise your FPS is still crap, and then it’s……. Most code these days is horrifically optimised. Someone who knows what they are doing can often find orders of magnitude speed ups if they look hard enough. IIRC @Pocster used to work in game development and to get this far even with AI is, I think, showing that experience. There are likely a lot of speedups still to be found even in webgl which is hardly the fastest way to do 3d graphics. What I want to know though is what happened to the original plan? This is all very pretty but I don't think the mountains are telling @Pocster what's for dinner or where he left his socks. Which I thought was the starting point of all this 1
Pocster Posted August 2 Author Posted August 2 (edited) 35 minutes ago, -rick- said: Most code these days is horrifically optimised. Someone who knows what they are doing can often find orders of magnitude speed ups if they look hard enough. IIRC @Pocster used to work in game development and to get this far even with AI is, I think, showing that experience. There are likely a lot of speedups still to be found even in webgl which is hardly the fastest way to do 3d graphics. What I want to know though is what happened to the original plan? This is all very pretty but I don't think the mountains are telling @Pocster what's for dinner or where he left his socks. Which I thought was the starting point of all this Theres always ways to optimise. My main lever is of course the shaders (even though Claude wrote them) and pre-baking - 256Gb to burn so we create lots once at runtime to use later and save on some computations. The original premise is still there - just got a bit distracted. But yes the Alex/Chatgpt from Avalon 1 will be imported into this. The robot running over these luscious landscapes will tell you when your chicken is ready and then you're playing Ed Sheeran AGAIN! Edited August 2 by Pocster 1
Pocster Posted August 2 Author Posted August 2 34 minutes ago, Nickfromwales said: I thought it was just to water his plants. That was an esp32 project and works!. I'll integrate that into Avalon later. One thing at a time! ( well lots of things at lots of times really - so never get bored!) 1
Pocster Posted August 2 Author Posted August 2 38 minutes ago, -rick- said: get this far even with AI is, I think, showing that experience Tell you what - that's a massive understatement. What I mean is I've created a custom 3d engine that would be commercial grade - yet not 1 line of code. That is the real power of AI. I see plenty of youtube/reddit "wrote this in 5 hours with Fable from 1 prompt". Some are believable some are slop. But most are relatively simple (still impressive that Ai can take "write me a really good minecraft game with dinosaurs in it" and still produce something). But use it properly from experience and build it up layer by layer rather than the final product from 1 prompt and its a phenomenal tool. The accomplishment here is WELL beyond my technical ability. But the "difficult" parts the code and horrific maths aren't my burden 99% of the time. I'm still in awe of what's possible. Must also admit it can take some effort - occasionally days on 1 feature to be correct. Or bastard bugs... we had a few mountain tops going black as you approach. No obvious reason some would and some wouldn't. Check all the render stuff/textures/lighting everything me and Claude could think of. Nothing obvious. Found it out of frustration!. The ray march on water can shoot a ray so far that it can hit a mountain top. Essentially at that point its a NaN so plots black! - what a bast!. Water affecting a mountain maybe 4km away in real space. That kind of bug finding without Claude (as I've done many a time when a software engineer) its pure torture and can literally take weeks to find... 1
Pocster Posted August 5 Author Posted August 5 (edited) Finally got decent looking snow. It accumulates on terrain and thaws. Edited August 5 by Pocster
Pocster Posted August 6 Author Posted August 6 Sunsets do it for me!. Been working on "real" rainbows. Most engines cheat at this but mine's created correctly (I think!). Now I need the water to freeze over time. GPU burden has been creeping up again as expected. So optimisations required yet again. Lightening thunder storms are extremely impressive and expensive!
Pocster Posted August 8 Author Posted August 8 Got lakes to freeze now. Doing this brought up a few long term bugs so was a bit more work than I thought. Avalon 1 did have a basic procedural flora generator. This has since been improved in Avalon 2. Texture wise took basically every free terrain/plant texture from polyhaven!. Alien plants will of course be procedural. Masses of optimisations again. Spent an entire day trying to do bubbling mud for volcanic worlds - still not right. Claude likes to overcomplicate on an epic scale; our "camera" had 127 parameters! - now just 8. Tree lab still has around 80 variables to "grow" the plant (inspired by what Unreal Engine does). Now just main ones on first screen. As for bubbling mud it somehow did an entire advanced physics simulation causing some chronic frame rate issues as you can imagine. It goes off on it's own little adventures I'm sure!
SteamyTea Posted August 9 Posted August 9 This is all so yesterday evening, the technology has moved on. You are using a bicycle to find a partner in the next village, the rest of us are using an app to find several all over the country. Technology Could a new approach to AI finally deliver artificial general intelligence? AI chatbots can describe reality in words, but don’t truly understand cause and effect in the real world. Now, a fresh kind of machine intelligence that does just that is emerging Daniel Cossins3 August 2026, updated 6 August 2026 http://localhost:56805/wp-content/external_image/aHR0cHM6Ly93d3cubmV3c2NpZW50aXN0LmNvbS93cC1jb250ZW50L3VwbG9hZHMvMjAyNi8wNy9TRUlfMzA2Njg5MTI5LmpwZw__.jpg Andrea De Santis What happens when you knock a glass off a table? Ask ChatGPT and you get a step-by-step explanation: how gravity accelerates the receptacle along a “parabolic trajectory”, why it could shatter “if the impact generates stresses greater than the material can withstand”. Ask my 3-year-old daughter and she’s less bothered with fine details: “It go smash and water everywhere!” When it comes to the future of artificial intelligence, the difference is instructive. The large language models (LLMs) powering today’s chatbots are trained on vast swathes of text to predict the next word in a sequence. Unlike little Adeline, however, no LLM has ever actually knocked a glass off a table – or thrown spaghetti at a wall, or driven a scooter into a pond – and that may impose a fundamental limitation on their capabilities. This, essentially, is why some researchers argue that what we need to take AI to the next level isn’t ever-larger LLMs, but “world models”: systems that learn through observation so they can simulate the consequences of actions in the real world. Read more A golden age of maths is dawning and mathematicians are freaking out World models have rapidly become AI’s next frontier, attracting huge buzz from industry and business thanks to their promise in autonomous robotics. What makes the world-model approach especially intriguing, though, is that it also ostensibly offers a route to artificial general intelligence (AGI), or machines with human-level reasoning that can be applied across a range of tasks. The problem is that it is tricky to parse substance from bluster. The term “world model” is confusingly elastic, for starters – for some, problematically so. It has become “a kind of shorthand for all the things that current AI systems can’t do well”, says Melanie Mitchell at the Santa Fe Institute in New Mexico. It is unclear exactly what these systems should model, never mind whether internal representations of physical reality will be sufficient for the kind of generalisable intelligence that means my 3-year-old intuitively understands what happens when she swipes a glass, even if she can’t say why. To make sense of world models as they apply in AI, it helps to understand the concept’s roots in cognitive science. AI researchers themselves typically trace it back to 1943, when psychologist Kenneth Craik wrote that the human mind “carries a small-scale model of external reality and of its own possible actions”, allowing us “to try out various alternatives” and “react to future situations before they arise”. http://localhost:56805/wp-content/external_image/aHR0cHM6Ly93d3cubmV3c2NpZW50aXN0LmNvbS93cC1jb250ZW50L3VwbG9hZHMvMjAyNi8wNy9TRUlfMzA1OTUxMzA0LmpwZw__.jpg Human minds have world models that enable us to predict what will happen next timsimages/Alamy That idea has evolved in the decades since, most notably with the theory of predictive processing. This posits that perception – possibly even consciousness itself – relies on the brain constantly generating predictions about the external world and updating them in response to incoming sensory data. But the point remains. “The key idea is that intelligence involves building models of the world in our heads so we can simulate outcomes and avoid costly mistakes,” says Josh Tenenbaum, a cognitive scientist and AI researcher at the Massachusetts Institute of Technology. “So ‘our ideas die in our stead’, as Craik put it.” It doesn’t take a genius to see why that has piqued the interest of AI researchers. LLMs have proved astonishingly capable, and they can certainly give the impression they understand things as we do. But language is a description of reality, rather than reality itself, and their lack of direct experience means that even the most powerful language models struggle when it comes to “understanding” physical phenomena in the real world. Read more Why I have changed my mind about AI and you should too LLMs often perform poorly when they are asked to reason about spatial concepts and things that might happen in the physical world, says Mitchell. “If you’ve ever uploaded a map to one of these models and asked it questions about it, you’ll know that they will often have a lot of problems with reasoning.” Indeed, in a 2024 study, when researchers trained language models on a database of turn-by-turn directions for taxi trips around New York City, they found that the system could provide reasonable routes from one point to another – but failed miserably when asked to take the odd detour. The reason why is that the LLMs have only descriptions of journeys, and therefore lack the sort of mental map that allows us to imagine what would happen in different scenarios. And navigation is just one example. LLMs demonstrate similar shortcomings in any scenario where you need to simulate the physical world – safely loading a dishwasher, say, or folding laundry. “They’re not designed for it, which is why people are interested in alternatives like world models,” says Tenenbaum. http://localhost:56805/wp-content/external_image/aHR0cHM6Ly93d3cubmV3c2NpZW50aXN0LmNvbS93cC1jb250ZW50L3VwbG9hZHMvMjAyNi8wNy9TRUlfMzA2Njg5MTgzLmpwZw__.jpg Andrea De Santis Probably the most influential proponent is Yann LeCun, a computer scientist at New York University and, until recently, chief scientist of foundational AI research at Meta. His argument, first made in a 2022 paper, is essentially that if we want to build truly intelligent systems that can reason, plan and act effectively in the real world, we need world models. “I cannot imagine we can build agentic systems without those systems having an ability to predict, in advance, what the consequences of their actions are going to be,” LeCun told artificial intelligence forum AI House Davos in January. And the key to that, he reckons, is systems that learn the rules of the world from observation. The idea has caught on. In December 2025, LeCun left Meta to found AMI Labs, raising just north of $1 billion to build world-model systems. A year earlier, Fei-Fei Li at Stanford University in California started World Labs, with $230 million of investment, to develop AI with “spatial intelligence”. Many of the established AI firms, most notably Google DeepMind, are now also actively pursuing world models in one form or another. The reason for the influx of money is primarily the promise that world models hold for advancing robotics (see “What are AI world models good for?”, below). However, it is early days and the existing prototypes are modest in their applications. With Marble, for instance, World Labs has built a system that generates coherent 3D scenes from text prompts. Similarly, DeepMind’s Genie 3 creates convincing interactive virtual environments – “snowy mountain at dusk”, say – in which you can move around for several minutes and even prompt events like rain. http://localhost:56805/wp-content/external_image/aHR0cHM6Ly93d3cubmV3c2NpZW50aXN0LmNvbS93cC1jb250ZW50L3VwbG9hZHMvMjAyNi8wNy9TRUlfMzA1OTUxMjc1LmpwZw__.jpg Google DeepMind’s Genie 3 creates worlds that users can explore from text-based prompts Google DeepMind In both cases, the companies describe their systems as “world models”. But Marble is really a 3D video generator and Genie 3 a video-game simulator, albeit one producing simulations in which agents could plausibly act, observe consequences and learn. Arguably, a proper world model would be something that exists inside an agent such that it can predict the consequences of its decisions, imagine the future and plan ahead before taking actions – and that is what DeepMind is pushing towards with its Dreamer 4 system, released in September 2025. It learns an internal predictive model of its environment, training mostly on data from the video game Minecraft, and uses that to train an agent that repeatedly “dreams” the consequences of possible actions to improve its behaviour. “The biggest difference [from Genie 3] is that Dreamer 4 is an agent, not just a world model,” says Danijar Hafner at DeepMind in San Francisco, who leads the Dreamer 4 team. “It predicts actions and improves them through iterative self-improvement, using planning and [imagined] trial and error.” The power of this approach is apparent in Hafner and his colleagues’ demonstration that Dreamer 4 can figure out how to collect diamonds in Minecraft, a complex task involving thousands of different actions – gathering resources, crafting tools, navigating the landscape – without being shown how to play. “The system has to understand its environment and generalise, because each new episode starts in a randomly generated world,” says Hafner. That is an important step, not least because this is precisely the kind of world model that could facilitate autonomous robots capable of folding laundry, say, or loading the dishwasher. “I think it’s going to solve robotics,” says Hafner. “What’s missing now is execution: data, compute, scaling. But we have the recipe, so, like with language models, it’s about scaling and details.” Read more The AI expert who says artificial general intelligence is nonsense Who would bet against DeepMind, given its impressive track record? After all, its researchers have won a Nobel prize for work on protein folding. But while Dreamer 4 demonstrates that agents with internal world models can reason and plan, it leaves a deeper question unresolved: what exactly should these systems learn about the world, or, more specifically, at what level of detail? And this has become a key fault line in the field, with two distinct approaches emerging. Many of the existing strategies are attempting to generate predictions on condition of action, as the researchers put it, by reconstructing future observations as faithfully to the training data as possible. But LeCun reckons that is the wrong approach, or at least not the best. His argument is based on the fact that humans don’t mentally simulate the world in any great detail, and certainly not pixel by pixel. When we imagine a glass falling from a table and smashing to pieces, for example, we don’t predict the position of every shard of glass, every water droplet. Instead, LeCun argues, we run highly compressed models that capture only the aspects that matter. This why LeCun advocates for a different tack, which he calls joint-embedding predictive architecture (JEPA). In this framework, world models infer abstract representations of what is relevant for reasoning, planning and action. “Generative models try to reconstruct pixels, whereas JEPA learns in a latent space and only predicts what is useful,” says Randall Balestriero at Brown University in Rhode Island, who has worked with LeCun on JEPA-based world models. “It ignores irrelevant details and focuses only on what matters for the agent.” LeCun and his investors appear to be betting that the JEPA approach will offer a swifter route to real-world applications, largely because it requires less training data. The most concrete publicly available demonstration of this technique so far is a system called V-JEPA 2, released by Meta in June 2025. Trained on video inputs, V-JEPA learns by masking certain regions of footage – obscuring a moving ball, say, over multiple consecutive frames – and repeatedly predicting not pixels, but abstract representations of what was hidden to learn a compact internal model of how the ball moves. What LeCun and his colleagues have shown, then, is that their system can model the causal structure of the physical world without having to reconstruct it in detail. Which isn’t to say that JEPA is necessarily any better than generative world models. Its advocates argue that it will be, of course. “Without abstraction, AI systems will stay limited to narrow tasks,” says Balestriero. But V-JEPA 2 is yet to clearly demonstrate that its abstract representations are sufficiently meaningful to enable an agent operating in an open-ended environment to reason and plan. “The biggest missing piece is the question of, how do we know that the abstraction is actually useful,” says Balestriero. “This is where there is a huge amount of active research right now, to understand: what do you capture, or how do you encode something very rich about the world that is useful for planning downstream.” Hafner, for his part, isn’t convinced that more compressed representations of reality are better. “Yann is right about many things, even if maybe he expresses them more controversially than necessary, and the JEPA approach is very promising,” he says. “But I don’t think that representations should be compressed and tiny. Ultimately, you want to learn strong representations, and what we did with Dreamer 4 [which trains with pixels but predicts in abstract space] is incredibly robust.” http://localhost:56805/wp-content/external_image/aHR0cHM6Ly93d3cubmV3c2NpZW50aXN0LmNvbS93cC1jb250ZW50L3VwbG9hZHMvMjAyNi8wNy9TRUlfMzA1OTUxNDI1LmpwZw__.jpg Some tech investors say that world models will be an effective way to power humanoid robots Wang Jiang/VCG via Getty Images More broadly, it is also far from clear at this stage if any of the world models in development – whether they learn and predict by reconstructing the world in high-fidelity or by inferring abstract representations – will ultimately be enough to get us to AGI. Now, it’s fair to say that AGI is another elastic term, and that claims about world models as a route towards it exist on a spectrum, with some of the most ambitious suggesting that learned simulations of physical reality could become the foundation of generally capable reasoning agents. When it released Genie 3, for instance, DeepMind insisted world models are “a key stepping stone on the path to AGI, since they make it possible to train AI agents in an unlimited curriculum of rich simulation environments”. Indeed, Hafner argues that “if you have systems that are able to represent the rules governing the world, then you’re approaching something like AGI because that’s understanding, that’s a key part of intelligence”. For his part, LeCun talks about them as a vital component of broader systems, rather than the whole story. And yet it is worth exploring the extent to which the kinds of world models in development would approximate human intelligence, because it can reveal what else might be required. Hafner says the most immediate requirement is temporal abstraction – that is, being able to reason not just about what will happen in the immediate future, but as things continue to play out. “You cannot just simulate everything at a sub-second, frame-by-frame level, because humans do not reason like that,” he says. “This is one of the open frontiers.” Tenenbaum goes further. Human world models aren’t just engines for predictions, he says, “they are much richer than that”. Human reasoning depends on various forms of causal abstraction and hypothesis-driven inference – not to mention models of other minds – which together allow us to flexibly recombine knowledge across different situations. “A key open question in all this is whether scaling up these world models will recover that richness, and my view is that it likely won’t,” says Tenenbaum. Mitchell makes a similar, if slightly broader, point. “I think the ability to have a kind of compressed, simulatable representation of aspects of the world is very important, and this notion of world models is probably going to result in useful improvements,” she says. “But I think there are probably lots of other aspects of intelligence that matter.” http://localhost:56805/wp-content/external_image/aHR0cHM6Ly93d3cubmV3c2NpZW50aXN0LmNvbS93cC1jb250ZW50L3VwbG9hZHMvMjAyNi8wMy8wNDExNTc0MS9TRUlfMjg3ODAxODkyLmpwZz93PTkwMCZoPTYwMCZjcm9wPTE_.jpg A very serious guide to buying your own humanoid robot butler You can now buy a humanoid robot housekeeper for less than the price of a second-hand car. But before splashing out, there’s something you need to know Another limitation of AI systems today, says Mitchell, is a lack of metacognition – an awareness of their own cognitive state, of what they know and don’t know, and how uncertain they are. “Is that fixable with a world model? Well, it depends what kind of world model, obviously,” she says. “But I’m a little worried that the notion of ‘world model’ is going to be used as the term for the difference between what we have now and ‘AGI’.” All of which suggests that world models as currently conceived may well be necessary for human-level machine intelligence, but not necessarily sufficient. Indeed, while it looks increasingly likely that they will be powerful and genuinely useful in robotics, and possibly scientific simulation too, it is far from a sure bet that they will replicate the way world models work in human cognition, never mind human-level intelligence more broadly. “One of the big misconceptions is that intelligence is a single thing, that there is a single world model in the brain,” says Tenenbaum. “What we actually have is the ability to run many different models depending on the context, task and goal.” Ultimately, then, the task of replicating what my 3-year-old daughter’s brain is capable of when it comes to modelling and predicting the physical world – even if it doesn’t stop her knocking glasses of water off the table – is not one to be underestimated. What are AI world models good for? 2
Pocster Posted August 9 Author Posted August 9 Not 100% correct yet but the detail on a procedural tree can be insane. Snow accumulates and bends individual branches. At a certain point branch will shed the snow and 'flip' back. Intend to do similar with rain i.e. rain accumulates so even when rain has stopped branches/foliage can still drip.
Pocster Posted August 9 Author Posted August 9 Claude's funny. We can go on for literally hours and not resolve issues and then it says "for whom picks this up....". I take that as a hint!. Open a new session same model same level and off we go again. You would assume bigger context would give better reasoning on a problem but sometimes not it would seem. I let Claude now use "auto" so it can roam more files without approval. Literally just churns away... I have to stop it and ask "WTF are you doing?" - frequently its gone down a pointless rabbit hole. I do swear it has its own agenda within mine!
Pocster Posted August 11 Author Posted August 11 All day at it. Claude's now struggling to find optimisations. So I need to be extra creative on the method rather than the code. 1024 trees on screen kills frame rate. Tricks a plenty needed
Pocster Posted August 13 Author Posted August 13 (edited) Just a test so 1024 trees. All real meshes. Nearer ones move per branch with wind and have higher fidelity shadows. Take lighting from sun/cloud/terrain/atmosphere (froxel,fog etc etc). Lots to compute!. Been rethinking lots and applying every trick I can to get frame rate sane but still heavy. I'm now onto placement - so got to go and plant 10'000's of trees! Edited August 13 by Pocster
Pocster Posted August 14 Author Posted August 14 stuck. pushed the turbo "fable" button.... here's hoping...
Pocster Posted August 15 Author Posted August 15 Ok! Well Fable really is doing better than Opus 5 on high. Getting right down to the nitty gritty and understanding it. Not quite there yet but big optimisations on the way for trees and grass I think.
Pocster Posted August 15 Author Posted August 15 Well! Been avoiding TAA as the visual artefacts annoy me and I want to get the best before I pull the big performance lever. But after some other smaller optimising this is the route we're going. Most major (if not all AAA ) games do this so it was always inevitable. 60fps is coming back!
Pocster Posted August 16 Author Posted August 16 Struggling to maintain 60fps and thats without Mike the robot, creatures and other goodies in. Even Fable is kicking back. TAA in was a big gain took some scenes from 200% GPU down to 120% (still over but considerable gain). Of course what's exactly on screen has a massive impact not just trees and imposters (tried those 3 times and gave up, after some thought 4th time worked good enough) but!, as essentially the terrain,sky,shadows,lighting,clouds,water is 1 massive shader (2Mb! as inline for speed) ray marching them from grazing angles can punish fps. I cant lie visuals are AAA - which is staggering. Still not looked at any code but tell it what to look for optimise wise and indeed it does and especially Fable goes off and find extra rabbit holes to explore which is good! A few more things to try though from a very empty bag of tricks. What do we have though? You can see maybe 10,000 trees on screen (yes most are a black pixel!), you can get right into the grass and it moves as you pass and each blade is vertex lit. Looks (expletive deleted)ing better than most of my holiday snaps!. Final push before rapier physics and Mike goes in. Then linking back to whisper and the local LLM - see we got there in the end just via a 3d engine! LOL!
