At £32k, you could employ a few apprentices for several years, maybe from Thailand.
I am sure they could turn you on.
Whoops, meant lights on.
I asked ChatGPT what the difference between light and hard was.
It said 'you can sleep with a light on'
Edited by SteamyTea
I messaged him direct said he’d do it for 27k outside ebay 😂😂😂😂
Honestly! As an ex software engineer I’m stunned !
We binned qwen coder . Too many silly errors . Uma8 microphone array up and recognises “ hey jeaves “ - tomorrow custom wake word . Seems stable as is but will leave running overnight. Have a fully fledge subscription protocol running so any new features easy to add and unlikely to bust anything else .
So the Skeleton seems good !
stt should be easy . Was going porcupine route but it’s subscription so went openwake and whisper . My rules is no cost and no cloud - (expletive deleted) that !
To build an entire system with me manually doing zero coding is still insane 🤯
I know why you want to avoid the cloud, but for a little compromise and a good few grand saved, I have to say that Claude Code is probably at the front right now. Have you tried it? I've tried Deepseek, which is pretty bloody amazing too but the way that Claude can build an entire stack, spit out all the relevant code in files, plus the debugging capability just has me flawed. The other advantage is persistent memory across conversations and chat history, including file retrieval - so you can put in all your skills and provide a context that gets updated as you work. Deepseek gets a bit of a pain because as soon as you notice the context memory starting to degrade, you've got to create a new prompt with current context and paste it into a new chat. Really don't get on with ChatGPT. Last summer when I was designing a DB schema and doing it the good old fashioned way with manual normalisation etc. it was just taking forever. Put my requirements in along with a decent prompt and it spat out the schema in about 3 minutes including all the relationships keys and foreign keys in an svg too, plus it then writes all the sql. What's amazing is then how it points you to tools available and takes you through how to integrate and implement them you'd never have heard about without weeks of trawling various tech sites. It is absolutely incredible.
Do you not find that you still have to do a little stitching in of code and a little nudging for debugging though? So you need to make sure the code is properly commented - that's been the thing with Claude for me is that it makes sure the necessary commenting is in there - Deepseek stitching in was a bit more painful as the line numbers it gave me were always quite a way off, well actually a lot as I still have a 3/4 finished app on there and I can't quite face going back to resolve the bugs right now.
But I think with all these tools, you still have to properly keep them on track as they do tend to forget stuff and when you're dealing with mathematics and especially applied physics, you've got to be very careful.
My issue was cost per month for number of tokens I use . Also I need llm local to do stt realtime . I’m not suggesting local models match frontier yet ( if ever ! ) but with a bit of workflow adjustment you can get pretty far . ChatGPT plus blows my mind for £20 a month . This I use as my co boss to check everything . I think the media gets obsessed with “ the best “ - but you get to a point where it’s clearly good enough for your needs . I’ve done advanced physics / rendering / maths solely with ChatGPT and it was fantastic . Required work to get it to do it correctly and not (expletive deleted) up . So I’ve changed my workflow ; it’s now better and more efficient. Ultimately I’ll ditch ChatGPT when my local reasoner is good enough .
Like all cloud based stuff , line drops , timeouts , stalls , delays I.e workflow rather than model issues wasted more time than a slow model !
As an aside a few months ago whilst testing models with chat we defined some test spec and did a prompt for it .
The coder produced ok code but a bit amateurish. Chat then re did the prompt . The coder model code was much more robust and professional- on my level ! . Went back to chat and did a full deep prompt . The coder then produced top grade software engineering code . I could do that , but it would take weeks . Chat was demonstrating a poor prompt is more problematic than a poor coding model . So I make sure prompts are solid !
Edited by Pocster
Anthropic just announced a big increase in number of tokens included in their subscriptions. OpenAIs codex is already generous (apparently). So maybe worth another look. Seen plenty of people talking about techniques for minimizing token usage.
Also I need llm local to do stt realtime.
This is the thing that confuses me the most about your plan (not that you have told us much detail). Home Assistant can already do this can't it? (some features need a live cloud connection but some don't IIRC).
Even if the operational side of your plan needs a local LLM, the coding/development aspect is one of the hardest aspects of LLM use that the frontier providers are better at. So your best value for money might be using them to do the development and then using a smaller, less memory hungry local llm to do the basic daily interactions. (Should be possible to design it so it can call out to a bigger subscription model for 'hard' problems).
Having said all that, if you are enjoying the process, have the spare money for the hardware then do what makes you happy.
Edited by -rick-
Everything I'm seeing suggests that the world has changed somewhat over the last 4 months or so, so if you haven't tried with codex 5.3/opus 4.6 then you might have the wrong mental model of where things are.
I think there’s confusion here 😊
I want local - even ( obviously that a cloud based version ) is best .
i use ChatGPT as my cloud based reasoner and sometimes coder for unlimited tokens ( effectively ) for £20 a month . It’s also my ‘chat’ for architecture / design / free balling ideas .
That coupled with local Deepseek / qwen ( when needed ) is working fine .
Home assistant can do some of this yes ; Alexa can do some of what I want .
But I want to go beyond that …
as examples
” it’s hot in here isn’t it Avalon ? “
” how often was the gate opened last Tuesday Avalon ? “
” Avalon , play that album by Coldplay I played yesterday “
then ….
we get reasoning and memory for example on when to put the radio on . I.e a weighted graph ( doesn’t require an llm admittedly) based on occupancy, time of day , whom is in the room etc
Ilm linked to camera above kitchen worktop to see the ingredients and suggest / recognise the meal .
leading to stt permanently. SWMBO mentions “ bathroom light didn’t come on again “ this is stored and can referenced later . “ I need to order a usb cable “ . Again stored / referenced . My email checked for the Amazon order etc
local llm , home assistant , ip camera , voice/speech recognition all part of the bigger picture .
My “ to do “ list is long .
Then we move into a humanoid robot to physically do tasks .
You guys are focusing on “coding “ that bits solved . I never need to code again . So any method that’s cheap and/or local is perfect . The big picture is much much bigger !! < evil laugh > 😆
Edited by Pocster
Not at all, I'm focussed on using the most effective tool that requires the least amount of effort to get what I what done, working how I want it to work and it's reliable without too many bugs - and it can be maintained with minimal input, including completing regular security reviews of the implementation and doing what's necessary to lock it down. Now what I love about it is that quite regularly Claude has the audacity to add surprising things and functionality I hadn't thought about, making things even better that I'd asked!
I can hardly contain my excitement about this too. No more brain hurt and squiffy eyes at 3am.
And gets bigger all the time, I hope.
Totally agree. I was listening to an AI podcast the other day and was surprised about the discussion talking about small scale efficient models running on very little computing power. The really interesting thing was that the guy (one of the gurus of our time in this field) was saying that the focus of the big data centre huge resource hungry things is more about stroking egos and the assumption that everything has to be bigger and better and more powerful all the time. It's a specific design decision rather than a necessity.
Oh absolutely!
Remember “ i’m free “ not in an are you being served way ! 😂 . No budget limit ( well maybe a bit ) , no time constraint , no boss ( like my build ) so able to explore and experiment! . Create what I want . Equally my house is the sandbox and I’m the guinea pig ! . Perfect setup for the experiment!!
Careful where you might end up...
2001: A Space Odyssey | 2001 a space odyssey, Space odyssey, Movie lines
  • Haha 2
Yes, there's definitely been some big changes over the last few months. It seems to have been exponential and the quality of output and reasoning is noticeable. Prompting though I still really key. I did a comparison last week with my son who'd put in a prompt and received some fairly generic stuff back. I sat down and wrote a prompt and he was taken aback by how long and detailed the prompt was compared to his. Then he was blown away by the output compared to what he had received. I actually ask the AI to create prompts for me or guide me in how best to structure prompt based on what I want and like @Pocster experiences, the output can be like night and day. Often just writing my prompts takes much longer than the thinking and generating the output.
Precisely ! Not coding , not design - prompt writing ! Even that as you say can written by a more capable llm . Limitation is now human imagination!!!!
I would agree with this and the need to evolve ever more effective prompts. Naturally AI supported prompt engineering is a thing as well although, so far, the Human in the loop remains - once they start prompting themselves who knows. However, I am not sure of the exponential growth in the model's capabilities themselves. Three other things seem to be emerging in the region of AI that also merit our attention:
Firstly, it seems to me that the eco system is perhaps where the real explosion is.  The number of other technologies, techniques and spinout applications is growing very fast EG in the areas like increasing use and application of vector DBs and all its variants (Hybrid Indexing etc),  Retrieval-Augmented Generation (RAG) and all its variants (Embedding free RAG, Chain of thought RAG), agent frameworks ( Swarm etc), structured knowledge stores, synthetic data engines and model side retrieval. Of those variants today not all will survive contact with reality and many more will emerge. Interestingly some of the early front runners in this sphere are reaching the end of their useful lifer already - Langchain is, for instance, being shunned because it is seen unstable and poorly documented as developers move over the likes of PydanticAI, Pocketflow & LlamaIndex. This tells you a second order story around the rush to get eco systems tools out quickly but skipping essential QA steps which leads to a broadly experimental feel rather than a sound production basis. Some argue that this because the LLMs, in the hands of developers, can create tools at an alarming rate but few are built well enough to live long!
Secondly, although we still live in a gas guzzling age where the size and power of the global scale models makes huge demands on memory & energy the size of really powerful, sometimes task specialised, models is falling fast as mathematicians and engineers work out ways of squeezing them into ever smaller memory spaces. This will, admittedly somewhat hyperbolically, eventually bring the full power of the models onto our watches.
Thirdly, as the HAL - "I can't do that Dave", example above illustrates some would argue that the control of this technology is getting further and further behind the bleeding edge.
Perhaps we might conclude that while there are burgeoning combinatorial opportunities in the first two, eco system and small models, the third is somewhat being neglected, pushed into the too difficult box by politicians or being briefed against by the tech companies.
It always was and always will be ..... until AGI!
  • Like 3
Chat thinks frontier agi ( depending on exact definition) by 2030 .
local it says longer . But I argued by then macs might be easily link able ( I know it can be done now ) so you could have your own mini data centre agi . With that consideration it said 5 - 7 yrs .
Then things go from bonkers to mega bonkers at all levels …
If you asked Grok, it'll probably tell you this year, just like the self-driving taxis for the last what 10 years?
Personally I think the whole AGI thing depends on what you consider to be intelligence - if it's the kind of intelligence that's displayed by a large proportion of leaders in the tech world, then maybe. If it's considered to be merely acting at the level of concept & proposition, then perhaps also so, but as intelligence also encompasses navigation and manipulating one's physical environment, all the computing power of all data centres in the world combined couldn't manage it successfully. And this is where it all falls down because we actually don't possess the knowledge to build systems that are efficient enough to properly act in the real world and make necessary decisions to successfully navigate it without unimaginable computing power - and this problem resides in our basic understanding in neuroscience which is stuck in the world of computational analogy and dominance of a constructionist view of the brain - e.g. we 'construct' reality in our brains based upon meaningless stimulus and therefore the world we see isn't really the world.
Yes, it's a rather huge and complex area right now, and even more so that when we saw similar patterns during the dotcom boom. The only difference being that a vast amount of money being ploughed in is from cash rich tech hegemonies. But I also see a play out of the worrying trends of laziness/sloppiness in development, which I think is perpetuated by poor implementation of project management approaches like Agile where they end up tacking crap onto existing crap foundations rather than re-think and rebuild. But also we see really poor UX/UI development nowadays and pushing system testing out onto users. This is exactly what's causing some of the issues you mention above. But in a slightly ironic way, the supply chain problems and costs associated with the large scale LLM implementations are perhaps making the industry think a bit harder about memory use, something that's largely been ignored for the last few decades.
But I suppose the more insidious issue is that of control. I prefer to think about it as regulation rather than control, because despite all the negative talk out there, there's a huge amount of positives this technology can bring. It just needs to be reigned in a bit but also actually understood properly by those tasked with the regulation. I don't envy those having to look at it and make these decisions, particularly with the speed it's going. What I don't want to see is a bunch of knee jerk quick pieces of legislation to deal with isolated events which we seem to be seeing more and more of in politics more widely.
