February 12Feb 12 Hi everyone. I'm looking at what 'budget saving' options I have for the plinth area directly below the render line. It's block with timber frame on top. The sand/cement option seems to be a slightly eye watering sum for the whole house. I had seen some examples where slate tiles were placed onto the block as an option - but can't seem to find it now (thanks Google for delisting!). Any ideas or options?
February 12Feb 12 3 hours ago, Onoff said: I think it was @Jeremy Harris who used black uPVC board? Yes, iirc he said the tunnel bunnies don't like to munch on it so much too.
February 12Feb 12 Author @Nickfromwales @Onoff any particular prep you can remember? Dust it all off and use something particularly sticky I assume?
February 12Feb 12 Might be less work than you think. 2 plasterers did ours (48m) in about an hour and a half.
February 12Feb 12 I did a block plinth several years ago. Used sharp sand and cement with a load of water proofer in the mix. Used a sponge to finish it off. Quite enjoyed it to be honest. painted it black when dry. It lasted at least 10 years, till i sold the place. The old PVC ain't cheap, and you can see ripples if the chucked up blockwork is a bit iffy.
February 13Feb 13 We used aluminum composite panels to clad the base of the insulated slab, i.e. the outside face of the insulation - looks very good and doesn't wrinkle of course. There are some parts (where the patio extends out from the slab base) where the outside face is blockwork - just painting this hasn't been very successful, efflorescence and peeling, cracking paint, so the sand/cement idea might be an option for this.
