My flat is fed from a 32mm OD (25mm ID???) MDPE pipe. Today the water maintenance company were here to disinfect the tank on the roof and as part of that isolated the supply. When the supply came back on the right angle MDPE fitting in my ceiling started letting a lot of water out of it.
Seems like the fitting loses its seal when the pressure is off and then is at risk of blowing off the pipe when the pressure comes back. Managed to isolate at the meter and with extra hands reintroduced pressure while holding the fitting in place and now pressure is back on with no leaks.
However, my confidence in these fittings is now shot and I want to replace them. I assume I need to get compression type fittings.
Should I favour any specific brand? Any gotchas I should look out for?
There’s no way that should have pulled / blown off, unless it wasn’t seated fully into the fitting (Plasson?) properly.
Don’t choose compression onto MDPE as that’s garbage compared to a proper MDPE fitting + insert.
If you’re not sure, replace like for like, and mark on the blue pipe the depth of the fitting to the internal stop point (like a shelf that the pipe insert butts up against and then can’t go in any further) so you know the pipe is fully ‘home’ in the fitting.
I’d say it was poorly installed or being not fully home that caused this.
Certainly once the pressure was off and I felt the pipe it was possible to push the fittings on by another inch with zero resistance. Pipe was completely free to move. When the pressure was turned back it pushed the fitting back out with some force as I was trying to hold it tight. Shouldn't the joint seem stiff/tight even with no pressure?
Just had a look on the Plasson site, nothing that matches these fittings on there (at first glance).
I meant compression MDPE like this, in case that wasn't clear:
https://www.pipestock.com/mdpe/mdpe-pipe-fittings/mdpe-elbow-90
FWIW these fittings are approx 20 years old. Google suggests a known failure of them is o-rings failing due to age (15-20 years).
Ah! Gotcha. Yes, that type of fitting is also robust.
Being able to push the pipe an inch means it wasn’t past the o ring, so you were living on luck there!!
yup. Just found the bugger lol.
I know the feeling. Some of my seals are less robust these days :D
Sounds like an issue to put back on the leaseholder? Or have you signed your life away?
I am the leaseholder. Would dearly like not to be but stuck here until the cladding issue on this building is fixed (even then flats in London are not in high demand right now so I'm likely stuck here for a while).
So what should I do? This is the second time this fitting has leaked after tank maintenance. Trust it, despite it being very loose (even after pushing back on as best I could with the access)? Replace with same fitting? Or something else?
Replace with new, I’d go Plasson.
Edited by Nickfromwales
My phone is dyslexic
I would replace with this. https://www.screwfix.com/p/floplast-492015-mdpe-elbow-25mm-x-25mm/14096
Part of the locking mechanism when you tighten the compression bit is they physically dig into the pipe so there is no way they will pull out without dismantling the fitting.  You First push the pipe into the fitting and you can check it has pushed properly into the O ring seal only then do you tighten the compression bit which ensures it is not coming out, pressure or no pressure.
All my mdpe pipe is connected with that type of fitting.
