Great_scot_selfbuild Posted 3 hours ago Posted 3 hours ago The roofers have just finished welding the lead flashing; I've 2 questions: 1. How do I clean off the white staining? (the flashing on the garage rooflights hasn't had this appear). 2. They've only welded the folds at the corners. Should I expect (or ask for the vertical mid-section overlaps to be welded? IMG_9456.MOV
Mr Punter Posted 3 hours ago Posted 3 hours ago Well I could not view the image or the vid, but you need to put patination oil on lead to prevent the oxidizing. 1
stu w Posted 2 hours ago Posted 2 hours ago As said, clean off if necessary with some white vinegar, then coat with patination oil
torre Posted 2 hours ago Posted 2 hours ago The vertical overlap looks okay to me, to allow for expansion. Was that lead fresh off a roll? The white staining can be cleaned off as mentioned and patination oil applied but I'd expect the roofers to have done this as part of the job 1
Nickfromwales Posted 1 hour ago Posted 1 hour ago 19 minutes ago, torre said: I'd expect the roofers to have done this as part of the job And herein lies the problem folks. If they think they can pas the buck, or dodge a bullet, well......... However, if it's entered in early as a part of the remit, then they know they have to do it or not get paid.
