Beelbeebub Posted 11 hours ago Author Posted 11 hours ago 1 hour ago, ProDave said: I await your explanation of how it will cost upwards of £300K to install your heat pump........ I have about 30 properties to install them in and assume about £10k per property. 30 x 10 = 300
Beelbeebub Posted 10 hours ago Author Posted 10 hours ago 31 minutes ago, JohnMo said: So you really don't give a chuff about what is correct climate wise, so what are you trying to achieve? I do give a chuff - though this thread is specifically about the non-climate related reasons for needing net zero policies. But the idea of comparative advantage extends to carbon as well. There are some items that can be produced and shipped for less CO2 than being produced here. Aluminium from Canada being an example that springs to mind. For jackdaw gas Vs LNG gas the difference is relatively small - about 0.3% of UK emissions and even smaller if the gas is sourced from Norwegian pipeline (which it will be this winter as LNG from Quatar is not available)
Beelbeebub Posted 10 hours ago Author Posted 10 hours ago 2 hours ago, -rick- said: Agree with this. We have already cut our emissions substantially from prior levels, but any serious analysis just shows we've exported the emissions (and to some degree damaged our future economy by doing so). Here is the serious analysis It is true that upto 2005 the idea that we were merely exporting emissions was mostly true, but since then even our footprint emissions (which includes the footprint of stuff made abroad) have fallen. 2 hours ago, -rick- said: In international forums now we are among examples of 'how not to decarbonise', I'd be very interested to see which "international forums". The UK is generally considered to be a leader in the field of transition policy (at least regarding generation).
Beelbeebub Posted 10 hours ago Author Posted 10 hours ago 2 hours ago, -rick- said: A good example of decarbonisation would be an economy that has shifted away from carbon emissions without changing the domestic industry mix. Why? Why is the domestic industry mix of UK 2025 inferior to 2000? Or 1975? Or 1950 or 1850? Name a country that has had the same industrial mix that it did in 2000? Certain people have nostalgia for manufacturing but the fact is the UK was always going to have to transition away from labour intensive industry because the world marches on. If we still built cars the way we did in 1970 the cars would be more expensive and poorer quality than competitors who used modern, lower labour, plants. Arguably it's part of the reason out motor industry failed - not modernising. China's industrial mix has massively changed. Has their policy failed? A far better measure is the impact on the economy and living standards of decarbonisation. This is going to be hard to disentangle from the other things that have happened over the last 2 decades that have also impacted out economy and living standards. 2008 crash Brexit COVID Ukraine invasion Hormuz
Beelbeebub Posted 10 hours ago Author Posted 10 hours ago 1 hour ago, JohnMo said: If your properties are all electric, let all your tenants to choose there own tariff and add a battery The best solution would be a heat pump and possibly a battery EPC regs don't reward that (zero for batteries and a heatpump yields a couple of points over the existing storage heaters). Plus there are planning and install issues (5 stories, conservation area, AONB). The best solution. The one we are going with is to swap the heaters for new HHR storage heaters. If I can get solar fitted I will - and probably a battery. As for the gas properties the issue is not making it more expensive for the tenants (plus the EPC issue). Right now I can't make the bus case stack up despite trying many permutations. Again solar is the current front runner.
Beelbeebub Posted 10 hours ago Author Posted 10 hours ago 1 hour ago, SteamyTea said: I suggest that you all get together and come up with a coherent plan as why we should drop the policies and just carry on as normal, rather than divert the climate change debate to one about personal finances. The problem is the reason we should drop the policies is that "they cost too much and we should use the vast reeves or North sea gas and oil to make ourselves energy independent" Which is all bollocks. But sticks in certain minds alongside "we are being invaded" and "the most pressing issue facing our nation is where somebody takes a piss"
JohnMo Posted 5 hours ago Posted 5 hours ago 5 hours ago, Beelbeebub said: Aluminium from Canada being an example that springs to mind. Although for many years it was all made in Scotland from hydro power so zero carbon.
