bmj1 Posted January 12 Posted January 12 I'm working on a community project. Today with the design team we discussed making use of a 150mm composite deck which sits between the steels, and then making use of dry screed (cement) boards on top for ufh pipes to sit in. The reason for suggesting screed board was to minimise build-up. Also important is ensuring no noise transfer between floors (hence 150mm deck). I can't help but think that there must be an approach here where the composite deck could be used as the screed ? Or alternatively we do a 100mm composite deck with 50mm cemfloor/liquid screed on top... Any thoughts on this ? I figure there must be some buildhub wisdom on this...
Nickfromwales Posted January 12 Posted January 12 This is lacking a lot of info. 150mm composite what? Purpose of building and anticipated w/m2 heating needed, and what’s heating it? Floor covering? Lots more detail required or answers will be based on assumptions
Conor Posted January 12 Posted January 12 I looked at this. Yes, you save the equivalent of a couple courses of bricks. So what? The cost came out the same, was no faster, was a niche skill that needed additional design and prep. You'll want a suspended ceiling for minimising sound transfer anyway.
bmj1 Posted January 12 Author Posted January 12 (edited) - composite concrete - it's a community building/place or worship - heated by UFH, I imagine using electricity (not gas) - floor covering likely natural stone tiles Any other questions? Edited January 12 by bmj1
Nickfromwales Posted January 12 Posted January 12 4 minutes ago, bmj1 said: - composite concrete - it's a community building/place or worship - heated by UFH, I imagine using electricity (not gas) - floor covering likely natural stone tiles Any other questions? Lots. So the most efficient way to heat this would (on the info I have so far) be to have the screed act like a radiator. Minimal mass, achieve heat quickly, turn off as soon as the premises is to be vacated. Heating up 150mm (plus another 30mm or more of adhesive and stone) of solid mass will take a long time, but will hold heat longer, just need to understand downward / outward heat losses better to say if this is a good idea or not. Absolutely a no brainer to run this off a heat pump, if this is anything like a long term situation. Convenience comes at cost, so the mention of using direct, on-demand grid electricity to do space heating is one where I also assume someone is happy to foot the energy bills per annum? At that stage I’d probably advise the use of in screed electric heater wires, as this is close to 100% efficient, less losses.
bmj1 Posted January 12 Author Posted January 12 Hi Nick, Comments as follows: I expect the space to be used frequently throughout the week, including a daytime nursery on premises So we'll likely want to keep it at temperature from say 6am to 11pm Does this change anything ? We're building it for ourselves, so we do care that it is cost effective to operate (subject to the capital investment required, but essentially we have an owner mindset on this one)
bmj1 Posted January 12 Author Posted January 12 I'm particularly surprised by your suggestion for "screed electric heater wires" - my understanding was that wet pipes are much more cost effective to run.
Nickfromwales Posted January 12 Posted January 12 1 hour ago, bmj1 said: I'm particularly surprised by your suggestion for "screed electric heater wires" - my understanding was that wet pipes are much more cost effective to run. Nope. Direct electric is near 100% efficient. I did I’ve an external heat generator, then wet manifolds, plus ongoing maintenance, losses, and the I detect nature of heat delivery, you’re going to be worse off unless the cost per kwh is managed; so gas or heat pump.
saveasteading Posted January 12 Posted January 12 4 hours ago, bmj1 said: a community project I've done a few of these, design and construction, including a church, with the starting point being 'someone says you will be able to half the price we've had from tenders'.ie it's not a cathedral and so funds are tight. It is complex, based on the use, or variable uses, of the facility, and also the size. Ventilation can be a huge issue as is means of escape , if the numbers are large. Even which inclination of church and their procedures can make a difference to performance and choices. But to start with I don't know what you mean by a Composite deck screed. 4 hours ago, bmj1 said: Today with the design team Does that mean your own steering group, or are there professionals advising?
bmj1 Posted January 12 Author Posted January 12 1 hour ago, Nickfromwales said: Nope. Direct electric is near 100% efficient. I did I’ve an external heat generator, then wet manifolds, plus ongoing maintenance, losses, and the I detect nature of heat delivery, you’re going to be worse off unless the cost per kwh is managed; so gas or heat pump. Interesting... so if using electricity - then might as well go for electric UFH - interesting and will put it to the team
bmj1 Posted January 12 Author Posted January 12 6 minutes ago, saveasteading said: I've done a few of these, design and construction, including a church, with the starting point being 'someone says you will be able to half the price we've had from tenders'.ie it's not a cathedral and so funds are tight. It is complex, based on the use, or variable uses, of the facility, and also the size. Ventilation can be a huge issue as is means of escape , if the numbers are large. Even which inclination of church and their procedures can make a difference to performance and choices. But to start with I don't know what you mean by a Composite deck screed. Does that mean your own steering group, or are there professionals advising? So the knotty areas so far have been: a) Ventilation requirements: some serious kit and duct sizes involved b) Fire Strategy: means of escape/staircases c) Structural design: achieving a very large column-free main prayer space, without a crazy steel bill I was referring to the professional team (architect, SE, MEP, PM, Interior Designer). Despite having a full professional team engaged, I certainly plan to keep asking questions here, and keep sharing any findings. 1
saveasteading Posted January 12 Posted January 12 5 minutes ago, bmj1 said: Structural design: achieving a very large column-free main prayer space, without a crazy steel bill Steel will be the answer. It covers big spaces economically. My rule of thumb is that adding an internal column under a portal frame will reduce that frame by 1/3 in tonnes and cost. What width of building do you intend? You don't want a column in the middle of your space I'm sure, so make this a fundamental requirement, and accept the cost. 9 minutes ago, bmj1 said: I was referring to the professional team (architect, SE, MEP, PM, Interior Designer). OK, so they should be able to look after you, and will be charging. So anything we say on here might concern them as distrust. Have you given them a budget? Would any of them know how to achieve it?
Nickfromwales Posted January 13 Posted January 13 6 hours ago, saveasteading said: But to start with I don't know what you mean by a Composite deck screed. I was confused by this term too. However a robot in cyberspace says this: 6 hours ago, bmj1 said: I was referring to the professional team (architect, SE, MEP, PM, Interior Designer). With MEP on board this should get sorted, assuming some element of heat recovery from ventilation if it’s a sizeable property. The only factor between pipes and heater wires is the functional longevity of the wires. As more info lands here, the more I think this will be a serious chunk of change going into a commercial heat / cool / ventilation setup. Your MEP people may suggest A2A AC as it’ll service both requirements (heating and cooling) and will introduce heat pumps to the situation which would seem sensible.
bmj1 Posted January 13 Author Posted January 13 It's a steel deck with concrete poured in - I think ! "A steel deck with a poured concrete floor, known as a composite floor system, uses corrugated steel sheets as permanent formwork and reinforcement, creating a strong, cost-effective, and fast-to-install structural slab by combining the concrete's compressive strength with the steel's tensile strength. The deck acts as a working platform and holds wet concrete, while shear connectors (like headed studs) bond it to the steel frame, forming a single, load-bearing unit after curing, common in commercial and multi-story buildings."
Iceverge Posted January 14 Posted January 14 I feel being trickle fed details here is limiting how much we can help. Can you please give us a size and scale of the building. I had in my head it was a 4x4m prayer room initially but portal frames etc suggest it may be 40m X 40m. How much work has been done. What's under the floor? A house? Offices? A car park? Heating it from 6am until 11pm means a lot of energy so investment in the fabric is vital. This means insulation airtightness and mechanics ventilation. What's the approach here? Have the structural details been finalized? Direct electric UFH is of course 100% efficient like any reistive heater but heat pumps can often be "300%" efficient. It might not be an ideal fit for your building though depending on your insulation and the ability to control ventilation through public use of doors etc. Like I say more details = better advice.
bmj1 Posted January 14 Author Posted January 14 (edited) Sorry - I'm not intending to trickle feed - I think I've just posted a bit early in the process. The building itself is roughly 900m2 over 2.5 floors, it's shaped broadly in a cube. Agree that fabric needs to be spot on. The only draft detail I have right now is 250mm PIR in the roof. The rest will get fleshed out over the coming weeks. Mechanical ventilation is planned: a big unit from Systemair. I haven't yet seen details on how air tightness will be achieved, but I have discussed with the team making use of Aeroseal. I think it probably makes sense to post back in a few weeks with a bit more info and some drawings. Edited January 14 by bmj1 1
