Julestools Posted January 9 Posted January 9 (edited) Hi all, I want to add internal wall insulation to my 1970's block cavity walls. The cavities were filled with a mineral wool type fluff in the 90's, which appears to be dry where I've been able to see it and there is no evidence of damp or mould in or on the walls. The external render is also in good shape. We are leaning toward a stud frame fixed to the inside of the external cavity walls with mineral wool bats like knauf RWA45 or RS45, with plasterboard over. Our reasons being, it's cheaper than using celotex or insulated plasterboard, it's a breathable option which, from what I gather, would carry less risk of issues with condensation and mould and we don't mind losing a bit of internal space. I'd love to hear your thoughts and knowledge on this approach to internallly insulating cavity walls. Is it a good idea to do it at all? Is a vapour-open breathable approach better, or should I use a vapour barrier, as some manufacturers suggest? Any and all thoughts welcomed! Cheers, Jules Edited January 9 by Julestools
Redbeard Posted January 9 Posted January 9 Depends what you are putting it on top of. If it's gypsum painted in vinyl silk then your hopes of breathability are arguably less well-founded than with a lime plaster with breathable paint (opinions vary!!). I would make insulated studs and I'd use Intello membrane as VCL.
Julestools Posted January 9 Author Posted January 9 Thanks Redbeard. So would using Intello increase the chances of a dry healthy wall and insulation space if using not-so-breathable plasterboard and plaster?
Oz07 Posted January 9 Posted January 9 You'd use metal studs with the brackets and rockwool its easier than timber stud
Redbeard Posted January 9 Posted January 9 I think , off hand, you'd want insulated stud, Intello, secondary (say 25 x 50) stud, plasterboard, but have a look at Pro Clima's site. Ecological Building Systems (UK importers of Pro Clima) may advise too. Note I was writing that when @Oz07's post came in. I like Intello as it acts as a VCL but, if any moisture has got where it shouldn't, can become slightly vapour-open to let it out.
Oz07 Posted January 9 Posted January 9 Ive seen big commercial renovations where they just use metal stud with rockwool behind and in-between. This is on 9" solid brickwork. Surely if good enough for that be fine for modern cavity?
Redbeard Posted January 9 Posted January 9 I should probably advise a condensation risk analysis for IWI on top of CWI. WUFI is good but Glaser is at least indicative. My reason for insulated stud (in my mind a glued laminate of, say, 12mm OSB, xmm plastic insulation, 12mm OSB) is to reduce thermal bridging. Metal stud leaves a bridge all the way through the sandwich, but is a narrower highly-conductive thing against a fatter less-conductive thing. So the end result may not be so different. I don't know! 3
Julestools Posted January 9 Author Posted January 9 45 minutes ago, Redbeard said: I think , off hand, you'd want insulated stud, Intello, secondary (say 25 x 50) stud, plasterboard, but have a look at Pro Clima's site. Ecological Building Systems (UK importers of Pro Clima) may advise too. Note I was writing that when @Oz07's post came in. I like Intello as it acts as a VCL but, if any moisture has got where it shouldn't, can become slightly vapour-open to let it out. Insulated stud sounds good, though someone suggested spacers at intervals to bring the studs away from the wall to minimise bridging. Then wool can go behind and between studs too. Intello is clever indeed! Would you regard pb with, say, the more porous 'one coat' plaster on it, breathable enough, or not?!
Julestools Posted January 9 Author Posted January 9 49 minutes ago, Oz07 said: Ive seen big commercial renovations where they just use metal stud with rockwool behind and in-between. This is on 9" solid brickwork. Surely if good enough for that be fine for modern cavity? Good point.. And yes I might be overyhinking it! We're they using vcl to keep moist air out, or somehow making it breathable I wonder?
Mike Posted January 9 Posted January 9 4 hours ago, Julestools said: Is it a good idea to do it at all? If you have the cash and have already done / plan to do other obvious thermal improvements, then it's worth considering - unless you can apply external wall insulation, which would be preferable. If you're able to withstand the disruption of IWI then presumably it would be part of a larger improvement scheme? With an insulated cavity wall the risk of condensation is greatly reduced / eliminated (depending on insulation thickness and provided rooms are adequately heated and ventilated). If it turns out that there is a significant risk then any gypsum plaster needs removing. Ensuring the airtightness of the existing wall (and all the junctions between the wall and other materials) is more important than a vapour control layer, as airflow through the structure is likely to cause much more condensation than the absence of / gaps in a VCL (as well as causing heat loss). If you add a VCL too, then only choose an 'intelligent' one such as Intello. There's a long meandering thread here that's worth reading. It relates to solid walls, but still useful: 1 hour ago, Julestools said: Would you regard pb with, say, the more porous 'one coat' plaster on it, breathable enough, or not?! Plasterboard & regular plaster are vapour-permiable but, as mentioned above by @Redbeard, regular vinyl paints aren't - you'd need clay-based / lime-based paint to maintain permeability. With an insulated cavity wall permeability is normally less of a concern.
Julestools Posted January 9 Author Posted January 9 Thanks Mike for a very helpful reply. Yes, this is part of an extensive refurb, including a roof upgrade later this year, and floor levelling and insulating currently underway. I am confident about the air tightness of the walls so currently not seeing a need to remove the plaster, but perhaps a condensation risk assessment may be a good idea, as Redbeard suggests. Breathable paint, no probs! Thanks again👍
Julestools Posted Sunday at 19:22 Author Posted Sunday at 19:22 On 09/01/2026 at 19:51, Mike said: If you have the cash and have already done / plan to do other obvious thermal improvements, then it's worth considering - unless you can apply external wall insulation, which would be preferable. If you're able to withstand the disruption of IWI then presumably it would be part of a larger improvement scheme? With an insulated cavity wall the risk of condensation is greatly reduced / eliminated (depending on insulation thickness and provided rooms are adequately heated and ventilated). If it turns out that there is a significant risk then any gypsum plaster needs removing. Ensuring the airtightness of the existing wall (and all the junctions between the wall and other materials) is more important than a vapour control layer, as airflow through the structure is likely to cause much more condensation than the absence of / gaps in a VCL (as well as causing heat loss). If you add a VCL too, then only choose an 'intelligent' one such as Intello. There's a long meandering thread here that's worth reading. It relates to solid walls, but still useful: Plasterboard & regular plaster are vapour-permiable but, as mentioned above by @Redbeard, regular vinyl paints aren't - you'd need clay-based / lime-based paint to maintain permeability. With an insulated cavity wall permeability is normally less of a concern. Mike, I'm thinking of using 100mm mineral wool between studs .. Do you think that is too much, or OK due to the lower risk of condensation due to the walls being cavity, with the cavity already insulated? Also, I had the idea if using 45x45 treated studs/battens with 45mm spacers of some sort every 600mm or so, where the studs are screwed to the wall, giving me a 45mm space behind the studs to fill with insulation, then the regular 100mm batts fitted between the studs. I guess it's a kind of 'warm batten' design, cheaper on timber, but solid enough to fix plasterboard to. I have seen continuous insulating spacer strips used, only 10 or 20mm thick behind the studs ..but I'm wondering if my idea is a daft one, as I've not seen it done quite like that before!
Julestools Posted Sunday at 19:55 Author Posted Sunday at 19:55 19 minutes ago, ETC said: Pump the cavity. ETC, I'm not sure what you mean!??
ETC Posted Sunday at 20:09 Posted Sunday at 20:09 Hi all, I want to add internal wall insulation to my 1970's block cavity walls. Pump the walls with insulation. 1
ETC Posted Sunday at 20:13 Posted Sunday at 20:13 https://www.instagroup.co.uk/our-products/insulation/cavity-wall/ Other suppliers are available. 1
Julestools Posted Sunday at 21:01 Author Posted Sunday at 21:01 47 minutes ago, ETC said: Hi all, I want to add internal wall insulation to my 1970's block cavity walls. Pump the walls with insulation. Ah, thanks, ok got it. The cavity is already insulated.. They had some kind of fluff pumped in back in the 90's. I'm looking to improve the walls with internal wall insulation.
Mike Posted Monday at 01:06 Posted Monday at 01:06 (edited) 5 hours ago, Julestools said: Mike, I'm thinking of using 100mm mineral wool between studs .. Do you think that is too much, or OK due to the lower risk of condensation due to the walls being cavity, with the cavity already insulated? It depends. If the external wall is in good condition, free from penetrating rain and not very exposed, and provided the DPC is doing its job, then it's generally accepted that it's safe to apply internal wall insulation to a solid wall if the resulting wall u-value is at or above 0.5 W/m².K, pretty much irrespective of the method used. However there is significant research such as the Historic Scotland Refurbishment Case Study 4 where they went down to between 0.37 and 0.19 by using vapour-periable materials (important!) without using a vapour barrier, and without any concerns during their 18-month initial study (AFAIK they never published their promised follow-up report); it's worth downloading a copy. Since most of the research is on insulating solid walls I don't recall seeing anything about upgrading insulated cavity walls. Ideally you'd find someone to model the risk with software such as WUFI (though it isn't without problems - best to model the entire building, not just the walls). As mentioned in one of my earlier posts above, remove any gypsum plaster if there's a risk of any condensation against the existing wall - many materials can tolerate some moisture in winter temperatures provided they dry out again quickly enough in spring (so a Glaser analysis using a tool such as Ubakus isn't very useful), but gypsum holds the moisture and turns to slurry. For more reading, see the link to the other thread I posted above. You'll see there that I chose hemp insulation for my own IWI due to its good moisture handling abilities (plus good decrement delay). I wouldn't have been at all comfortable going as low with my u-values using mineral wool, or using a vapour-impermeable build-up. 5 hours ago, Julestools said: with 45mm spacers of some sort I'd probably choose cork. Edited Monday at 01:12 by Mike
Gus Potter Posted Monday at 20:36 Posted Monday at 20:36 On 09/01/2026 at 14:22, Julestools said: Hi all, I want to add internal wall insulation to my 1970's block cavity walls. I assume you have a suspended timber ground floor with timber joists. Take a step back and check that what you are doing will not compromise these joist ends or any joist running parallel to the external wall. If so by how much and what are the risks. The basics of timber preservation are; keep it in the dark, cold and with plenty air circulation (drafty!). Once you get a handle on this then the rest of the insulation strategy / air tightness is based around that.
Julestools Posted Monday at 20:56 Author Posted Monday at 20:56 16 minutes ago, Gus Potter said: I assume you have a suspended timber ground floor with timber joists. Hi Gus, no I have a solid concrete floor so no ground floor joists to worry about! 1
Julestools Posted 5 hours ago Author Posted 5 hours ago On 19/01/2026 at 01:06, Mike said: It depends. If the external wall is in good condition, free from penetrating rain and not very exposed, and provided the DPC is doing its job, then it's generally accepted that it's safe to apply internal wall insulation to a solid wall if the resulting wall u-value is at or above 0.5 W/m².K, pretty much irrespective of the method used. However there is significant research such as the Historic Scotland Refurbishment Case Study 4 where they went down to between 0.37 and 0.19 by using vapour-periable materials (important!) without using a vapour barrier, and without any concerns during their 18-month initial study (AFAIK they never published their promised follow-up report); it's worth downloading a copy. Since most of the research is on insulating solid walls I don't recall seeing anything about upgrading insulated cavity walls. Ideally you'd find someone to model the risk with software such as WUFI (though it isn't without problems - best to model the entire building, not just the walls). As mentioned in one of my earlier posts above, remove any gypsum plaster if there's a risk of any condensation against the existing wall - many materials can tolerate some moisture in winter temperatures provided they dry out again quickly enough in spring (so a Glaser analysis using a tool such as Ubakus isn't very useful), but gypsum holds the moisture and turns to slurry. For more reading, see the link to the other thread I posted above. You'll see there that I chose hemp insulation for my own IWI due to its good moisture handling abilities (plus good decrement delay). I wouldn't have been at all comfortable going as low with my u-values using mineral wool, or using a vapour-impermeable build-up. I'd probably choose cork. Thanks Mike. The Historic Scotland study is very interesting and offers hope for trouble free IWI for my walls. I'm assuming that I am at less risk of condensation, having an already insulated cavity and therefore a warmer inner leaf? Nor sure if I want to go down the road of modelling the whole building with WUFI. It seems the current U-values of my walls are likely to be around 0.5, so perhaps 75mm mineral wool would be an adequate upgrade. I will look into hemp, and there's also cork boards (no plasterboard needed)... I'm just no so keen on the cost! Thanks again
Roger440 Posted 5 hours ago Posted 5 hours ago All good stuff. Interested as as my 1980 extension is currently just a cavity block wall. 75mm cavity, no insulation. As the house is "compact", i dont want to apply to much depth internally so was thinking of combining it with cavity wall insulation (eps beads) As per OP this is a bit "hydrid".
Mike Posted 5 hours ago Posted 5 hours ago (edited) 16 minutes ago, Julestools said: I'm assuming that I am at less risk of condensation, having an already insulated cavity and therefore a warmer inner leaf? Yes, it will be a big help Installing MVHR, would help too. It keeps internal humidity lower than it would otherwise be, cutting the moisture entering the structure in winter and allowing it to dry out quicker in spring. Making the building airtight should also be a key priority and to accompany that you need an effective ventilation strategy, be it MVHR or otherwise. There are several threads on here about both topics. Edited 5 hours ago by Mike
Mike Posted 5 hours ago Posted 5 hours ago On 18/01/2026 at 20:22, Julestools said: I had the idea if using 45x45 treated studs/battens with 45mm spacers of some sort every 600mm or so I briefly mentioned using cork as a spacer earlier; I'd use continuous strips, not just spacers every 600mm; without that kind of firm support 45x45 would be too flimsy. Personally I'd increase it to 45x75 if I was using timber. 1
Julestools Posted 5 hours ago Author Posted 5 hours ago 8 minutes ago, Mike said: Yes, it will be a big help Installing MVHR, would help too. It keeps internal humidity lower than it would otherwise be, cutting the moisture entering the structure in winter and allowing it to dry out quicker in spring. Making the building airtight should also be a key priority and to accompany that you need an effective ventilation strategy, be it MVHR or otherwise. There are several threads on here about both topics. Brilliant, thanks. I'll look into ventilation options👍
