Mulberry View Posted yesterday at 11:10 Posted yesterday at 11:10 This is a general arrangement detail for my Car Port, the layout is not something I'm looking to go forward with exactly. Can anyone help with a bit of practical advice as I'm not overly experienced in timber framing. The masonry is built, inner and outer leaves are level, as per the drawing. Next to go on are the 47x100 wall-plates (I've allowed 10-13mm bed). Does the masonry cavity need to be closed? If so, what with? Should I put a DPC under the wall-plates? I don't think I need 50mm battens for the render boards and by reducing them to 25mm, I can centralise the on-end 250mx50 timbers a bit better on the wallplates. I plan to add noggins between them. I also plan to set the outer wall-plate in a bit to allow the render boards to skirt down over the wall-plates, as we clearly can't apply the render in the way shown. Any help to prevent my further procrastination is gratefully received.
Russell griffiths Posted yesterday at 12:34 Posted yesterday at 12:34 If render is your preferred finish why are you changing from brick to timber. wouldn’t it be more straightforward to continue up in a concrete block and render that. If you are happier in timber then i w put a dpc on top of the wall, then a treated sole plate first, use this to span the cavity and close the cavity in one go. then ceiling joists on top of sole plate, put noggins between joists and then another sole plate on top of joists then stud wall up from there. you want an angled top plate, or a flat top plate then an angled trimmer to take the metal web roof timbers. that’s a shit drawing. 2
Russell griffiths Posted yesterday at 12:36 Posted yesterday at 12:36 (edited) You will also need a substantial way of keeping any moisture from behind the render board running backwards into the structure I would use a wide dpc from the top of the ceiling joists downwards to create a tray damp to deflect any moisture outwards. Edited yesterday at 12:42 by Russell griffiths
Nickfromwales Posted yesterday at 13:02 Posted yesterday at 13:02 Adding the wood (TF) section does complicate this, seemingly unnecessarily. Plates for ceiling rafters and roof rafters can be done quickly and simply to connect those. 1
Mulberry View Posted yesterday at 13:51 Author Posted yesterday at 13:51 1 hour ago, Russell griffiths said: If render is your preferred finish why are you changing from brick to timber. wouldn’t it be more straightforward to continue up in a concrete block and render that. If you are happier in timber then i w put a dpc on top of the wall, then a treated sole plate first, use this to span the cavity and close the cavity in one go. then ceiling joists on top of sole plate, put noggins between joists and then another sole plate on top of joists then stud wall up from there. you want an angled top plate, or a flat top plate then an angled trimmer to take the metal web roof timbers. that’s a shit drawing. Honestly, I hadn't considered it being anything other than timber, blocks would be so much easier. Just goes to show what it's like having your brain scrambled when you're a bit out of your depth! What sort of blocks would be best for this? And yes, the drawing is shit, its what we got from a £20k Architect. Makes me feel sick. 2
Mulberry View Posted yesterday at 13:52 Author Posted yesterday at 13:52 1 hour ago, Russell griffiths said: You will also need a substantial way of keeping any moisture from behind the render board running backwards into the structure I would use a wide dpc from the top of the ceiling joists downwards to create a tray damp to deflect any moisture outwards. How would this apply if I go for blocks?
Nickfromwales Posted yesterday at 14:00 Posted yesterday at 14:00 8 minutes ago, Mulberry View said: Honestly, I hadn't considered it being anything other than timber, blocks would be so much easier. Just goes to show what it's like having your brain scrambled when you're a bit out of your depth! What sort of blocks would be best for this? And yes, the drawing is shit, its what we got from a £20k Architect. Makes me feel sick. Stick with us, kid
Mulberry View Posted yesterday at 14:02 Author Posted yesterday at 14:02 Just now, Nickfromwales said: Stick with us, kid I am always grateful for the help on here, I couldn't have done this without. 😎 1
Nickfromwales Posted yesterday at 14:02 Posted yesterday at 14:02 8 minutes ago, Mulberry View said: How would this apply if I go for blocks? A metal “bell” strip would be the junction between bricks and blocks, to kick the drip / rain away. Different types / sizes, so ask £20k boy to go draw something quick and simple; as if it was coming out of their pocket not yours for eg.
Mulberry View Posted yesterday at 14:04 Author Posted yesterday at 14:04 Just now, Nickfromwales said: A metal “bell” strip would be the junction between bricks and blocks, to kick the drip / rain away. Different types / sizes, so ask £20k boy to go draw something quick and simple; as if it was coming out of their pocket not yours for eg. The £20k girl is history. That a blessing and a curse. I feel relieved to not have the arguments and arsehole'ish attitude, but we're left trying to figure out a lot of these weak details.
Nickfromwales Posted yesterday at 14:22 Posted yesterday at 14:22 13 minutes ago, Mulberry View said: The £20k girl is history. That a blessing and a curse. I feel relieved to not have the arguments and arsehole'ish attitude, but we're left trying to figure out a lot of these weak details. It can prob be derived here, better, for free. These pro’s are just annoyingly expensive and underwhelming. About to get another new clients architect placed into the nearest bin, which actually happens a lot when I’m involved and demonstrate the long list of faux-pas. Current clown hasn’t actually followed the approved planning application, so that chat I had with the client to highlight this last week was “enlightening” to say the least. Then that moved quickly to being infuriated. Operation lead balloon was in full effect, yet again. 1
Russell griffiths Posted yesterday at 15:40 Posted yesterday at 15:40 1 hour ago, Mulberry View said: How would this apply if I go for blocks? It wouldn’t as you would have a cavity all the way to the floor. and being an open carport I presume a bit of moisture will quickly dry out if there’s a bit of breeze to blow through it. 1
Oz07 Posted yesterday at 15:41 Posted yesterday at 15:41 Take external skin right way up level with top of rafters, pro need to leave top course till rafters on so know where to set line. Take internal skin up and either sit rafters ontop or use a pole plate and hangers. If sitting rafters on blockwork probably need trimming to sit flat on the block and a bent strap hanging over end of blocks. Can you do this off your own back nowadays or do bcos want some kind of detail drawing
Russell griffiths Posted yesterday at 15:46 Posted yesterday at 15:46 Remember if you take this up In block work you need to treat it like a gable wall. so angled ties at ceiling joists level, then more test at rafter level. the ties stop the wall bowing out and restrain the ceiling and roof rafters, it all works together. with the icf walls you have done there wasn’t such a need as the structure is very rigid and stiff on its own, a block cavity wall can be a bit wobbly. 2
