December 9, 2025Dec 9 Been playing with ChatGTP over the last few days, generally going down a rabbit hole. Was looking for a simple way to model Weather Compensation fine tuning and or boosting during low tariff periods. So generally ChatGTP was no help. Had a search for something unrelated on Google and came across this site https://www.diyenjoying.com/2025/04/11/harnessing-the-power-of-predictive-heating-revolutionizing-home-comfort-with-home-assistant-and-derivative-sensors/ And finally a very simple modelling tool became realistic. So using the data on site above to add a couple of helpers to home assistant (hardware is already there - temp sensor). Then fine tuned for my UFH (thick screed etc). You now have a simple hourly and now 4 hourly look ahead at likely room or house temp if nothing changes. The author of that site used the information to start and stop heating, based on a generic thermostat, but taking account of floor inertia to not get swings in room temperature. So start boiler early and stop early, based on likely house temp - not actual house temp. But for weather compensation you just need a simple notification house temp is increasing or decreasing and you can simply adjust the curve. Add a bit of human looking at the day, it's stunning and room temp is increasing - no shocks don't do anything. But if it's dull outside you can decrease curve. So went back to ChatGTP for assistance. I have actually extended everything out to 4 hours to make it a little more meaningful for my house. There are few things this allows Intelligent fine tuning of WC curve. So you can see the likely house temp in 1 and 4 hrs and rate of change as a positive or negative. Options you could implement - you could run a cooler WC curve and boost during cheap periods. Could use it for batch charging alone, add some simple energy calculations based on you heating system store energy etc. Will add a few screenshots later Edited December 9, 2025Dec 9 by JohnMo
December 9, 2025Dec 9 Author So this is the small dash board on home assistant. I have a target temp set at 20 degC. The yaml code for the prediction automation, this just sends a notification to me if we are running to cool.in the house to see how it works. If connected to an output devise and house was likely to be too cold, ASHP would be started at a flow temp higher than the normal WC curve. alias: ASHP Batch Charge Based on Prediction and Slab Temp description: Batch-charge UFH during cheap windows using predicted + slab return history triggers: - at: "04:00:00" trigger: time - at: "13:00:00" trigger: time actions: - choose: - conditions: - condition: time after: "04:00:00" before: "07:00:00" - condition: or conditions: - condition: template value_template: | {{ predicted_min_4h < (setpoint - 0.35) }} - condition: template value_template: | {{ (return_now - return_min_4h) < -1.5 }} sequence: - action: notify.mobile_app_cph2449 data: message: "Batch heat started test " - delay: "03:00:00" - action: notify.mobile_app_cph2449 data: message: Batch charge finished test - conditions: - condition: time after: "13:00:00" before: "16:00:00" - condition: or conditions: - condition: template value_template: | {{ predicted_min_4h < (setpoint - 0.30) }} - condition: template value_template: | {{ (return_now - return_min_4h) < -1.5 }} sequence: - action: notify.mobile_app_cph2449 data: message: "Batch test " - delay: "03:00:00" - action: notify.mobile_app_cph2449 data: message: Batch charge finished test mode: single variables: setpoint: 20 predicted: "{{ states('sensor.lounge_predicted_temperature_in_1_hour') | float }}" predicted_min_4h: "{{ states('sensor.4h_min_predicted_lounge_temp') | float }}" return_now: "{{ states('sensor.emoncms_emoncms_org_heatmeter_returnt') | float }}" return_min_ 4h: "{{ states('sensor.4h_min_return_temp') | float }}"
December 9, 2025Dec 9 Author Details of some of the template sensors This is the import windows defined - have only use morning and afternoon slots binary_sensor: - name: hp_import_window state: > {{ now().hour in [4,5,6] or now().hour in [13,14,15] }} Predicted trigger state sensor: - name: hp_predicted_trigger state: > {% set p = states('sensor.lounge_predicted_temperature_in_1_hour') | float(99) %} {% set setp = 20 %} {% if (p < setp - 0.3) and (is_state('binary_sensor.hp_import_window', 'on')) %} on {% else %} off {% endif %}
September 20Sep 20 Author This has been a thing I have worked on and off for a while, but never really got to a model I liked. Had a play with AI and a few iterations later fell on to an energy based system similar to @TerryE but implementing is slightly different. I have an ASHP and heat meter, so came up with a closed loop system. It establishes a rolling energy target for next 24 hours and splits in to 3 chunks, we try to deplete the 8 hours worth of energy in a the Cosy cheap rate window. Down to about 5 degs we should be able to. Below that we allow an over run in to running from battery. We also have a carry over to next cheap slot. If below 2kWh we allow it move to the next slot, if above 2kWh we extend the run time to deplete to 0.1kWh. A flow chart is attached. If this is fails, we loose internet etc or we have issues.in general, a thermostat comes into play and we run on WC. As long as we stay with Octopus the automation stays true, as it's run via the octopus integration in home assistant and we use the cheap rate trigger to define the cheap windows.
September 20Sep 20 Interesting stuff John, thanks for sharing. I've long had ideas about doing something similar but I doubt it'll get to the top of my to do list until a couple of years into my retirement (the start of which is still way too far off for my liking).
September 21Sep 21 17 hours ago, jack said: Interesting stuff John, thanks for sharing. +1, but I doubt I’ll ever be this focussed on micro-control of my heating, just too many variables in my household; timing / number of occupants, and more. My stat responds to our needs pretty well tbf, but obvs different build fabrics make a big difference here. Mine is crap.
September 21Sep 21 Author Its not easy, if the outside temperature trending has shown to be utter rubbish - weather station being 40 miles away doesn't help, so getting AI to build a compensation system look forward and backwards on an hourly basis. But its all fun for the mind
September 22Sep 22 Author Building on the above. So we built a correction mechanism and this feeds into the start of the process to hopefully limit getting miss calculations of heat input data. We also added an adjustable internal target temperature to some variation in house temperature if needed.
September 26Sep 26 @JohnMo, out of interest do you know the time constant for your house? We have an MBC cellulosic-filled twin-wall with an outer stone leaf, so ours is pretty long: the house loses about 1°C / day in a typical winter day when the heating is off all day. I also use an Octopus Agile tariff rather than Cosy. I can just treat the day-ahead as a time shiftable window for heating purposes. OK we still use resistive heating, and like you I do a 24hr-ahead heating calculation aligned to the daily Agile roll-over; this shifts all heating to the cheapest hour-hour price slots. The CH+DHW app is a standalone Node-RED implementation running with its own IoT stack (MariaDB, mosquito broker, Zigbee2MQTT) in a Proxmox Container. This is loosely couple into Home Assistant (running in a Proxmox VM) via MQTT. I do use HA for the UI and other house automation, but heating control itself is autonomous from HA. (This design choice dates back almost 10 years when HA was a lot less stable, but if I were starting now with a clean slate I don't use any 3rd-party cloud services for active control. At some point in the next few years before I get too old, I will add an ASHP for UFH, plus a battery which is Agile tariff aware, and retire my custom App. One thing that I will pass on is using the ASHP for DHW heating. I'd rather just fix the ASHP output flow temp at 35°C, say, with long heating window and take the 5 - 6 CoP. At the moment our large OSO UVC is really low loss and uses the cheapest Agile slots. so it rarely costs more that 40p / day and the average is less than that. The immersion thermostats are set at 60°C, but the heating control stops at a target 55°C unless the Agile price is negative, in which case it goes all the way to 60°C to a do an anti-Legionella cycle. PS. Since you reference me, I though that this summary is a point of comparison for other readers. You already know most of this. PPS If you use the <> code tag for YAML etc., this demarcates code and preserves spacing, etc.
September 26Sep 26 Author 7 hours ago, TerryE said: the house loses about 1°C / day in a typical winter day when the heating is off all day. Ours is similar. 7 hours ago, TerryE said: Octopus Agile tariff rather than Cosy. Find in winter Cosy is generally cheaper, but I have a 13.5kWh battery to lean on. So generally paying currently 13p, was 10.6p last week per kWh. 8 hours ago, TerryE said: One thing that I will pass on is using the ASHP for DHW heating Yep, I just used immersion, leaves ASHP for heating when it suits. All the programming in home assistant is done via template sensors and a couple of automations. Have made another refinement to add more heat during the day and less at night. So 120% of 8h allocation in the day and only 90% to each night slot
September 26Sep 26 Author 8 hours ago, TerryE said: battery which is Agile tariff aware I use Predbat so managed battery SoC and import via Cosy and export Agile. Little bit of faff setting up, once done seems to work well.
September 26Sep 26 Author 2 minutes ago, MikeSharp01 said: Did you need to get your battery install certified or did you jusT plug it in? Battery was MCS install, but PV wasn't, so I did the paid Octopus approved scheme for export. They weren't interested in the battery MCS, didn't tick any of the right boxes.
September 27Sep 27 7 hours ago, JohnMo said: They weren't interested in the battery MCS, didn't tick any of the right boxes. So what advantages does MCS battery install bring over a competent electrician.
September 27Sep 27 Author 2 hours ago, MikeSharp01 said: So what advantages does MCS battery install bring over a competent electrician. None, mine came with the install that's all.
Just now1 min Author The predictive heating was switched off soon after starting, had teething problems and to much reliance on the internet, so reference temps would drop etc. it was parked and ran pure WC until I realised the CoP really wasn't that great, it's was ok but not great, but the biggest issue I couldn't get flow temp low enough so was always using more energy than I needed in milder weather.Tried upping temperature and running less time and eventually settled on a simple fixed 33 Deg flow temperature and ran in Cosy cheap periods, controlled by an on/off thermostat. But that is only good down to about 4 degs. Then the heat pump has to run outside Cosy periods at a fixed flow temperature. CoP over the last 7 days being and temps down to 4 degs has been 5.4.Could have added a slight WC curve to compensate for reducing temperature, but there's no fun in that.Looked at a method of control flow temperature. All the modbus directory is open source on a Hiaer heat pump, so have purchased a Waveshare Industrial Serial Server RS485 To RJ45 Ethernet TCP/IP converter for £29. This will be connected to Home Assistant and home assistant mapped, with the required modbus details. Then will have read write control of heat pump. Then simply map the heat energy required over the past 24 hrs as a rolling score compared to heat delivered and determined if 33 is to hot or not warm enough and via modbus change the flow temp. Will leave the existing thermostat as the gate keeper for timing and overall comfort.Adds a simple variable flow temp based on energy needs, no internet needed everything via ethernet. Reason using past 24 hours and not future, the floor at 100mm thick and 192m² has plenty of capacity to be a few hours out on the calculations.
