Hi,
My partner and I are just at the beginning of a self build project, rural build on the family farm. We opted to go down the route of a borehole for water as there is no option for mains and the farm well is some 400 meters away.
Has anyone successfully zero rated a water borehole commissioning for their new build?
I have a £17k invoice to pay to a VAT registered driller and wanted to amend the VAT if it’s possible!
Any experience or advice would be welcome! Thanks
Not everybody has a borehole so maybe ask someone who does directly. Either post on an existing thread or search for someone who might know and tag them by @name.
I’ve done exactly that, thank you!
Did find this which might be useful... Also Andrew the VAT man might also be a good one to ask..
Yes, services related to a borehole can be zero-rated for VAT if they are an integral part of the construction of a new qualifying dwelling in the UK.
This depends on the following conditions:
  • "In the course of construction": The work must be carried out during the construction of the new dwelling and not after it has been completed.
  • A "qualifying building": The new build must be a self-contained house or flat designed as a dwelling.
  • "Closely connected": The borehole and associated works must be "closely connected" to the construction, making the building functional and usable. This includes essential services like water supply.
11 minutes ago, JohnMo said:
We paid vat on our borehole and pump and filters to contractor. But included in our VAT submission, which I believe got paid.
That surprises me! Are you sure?
Things may have changed but we included an invoice (for windows, including installation) in our claim and HMRC told us that the company should have zero rated the invoice, so we should go back to them and get them to re-issue the invoice without VAT and refund us the amount.
So to avoid later hassle it may better to make sure the contractor is happy to zero rate the amount.
We had to supply the windows people with copies of the planning permission so they were covered if their VAT inspector asked any questions.  They were only too happy to sort things out - fortunately!
Was compliant with that. Was done as we put up the walls
Was compliant with that, new build house
Was compliant with that. No other water connected to house
I don't think that's the correct procedure.
Pretty sure it should all be zero rated to you. So no VAT to pay and reclaim.
Might help to provide the company with a certificate. A letter giving your  details, that of the site and copy of the planning permission. Something like..
I certify that the service you are providing are for a new house at...
You can also refer them to VAT708.
You should get the quote revised before you accept it to say vat at 0%.
Note you can't reclaim VAT on anything paid before you get planning permission.
If the CIL is in your area don't do anything on site until you have filed the exemption forms and have confirmation of receipt.
Edited by Temp
All a little late now, borehole went in in 2021, vat reclaim in 2023. Scotland so no CIL stuff to worry over.
For info..
All services, including supply and fit that might include materials (eg Bricklayers, electrician, plumbers, plasterers) must be zero rated to you.
The only things you can reclaim VAT on are materials you buy personally. If shown on a landscape plan as part of your planning permission you can also include trees.
Edited by Temp
Hi All,
Just a wee update, after equipping myself with enough confidence of eligibility and knowledge I contacted the company that completed the drilling and requested kindly that the works be zero rated, I provided them with a certificate (adapted from the HMRC one advised in VAT Notice 708), along with a copy of my outline planning approval.
They kindly obliged and we have 0% VAT!!!!!
For anyone who it may help, I have approved outline planning only, with full planning being submitted as reserved matters in the next few weeks.
This is reasonable to meet the VAT notice 708 ‘in the course of construction’ requirement.
What I’ve learned!
A Water borehole commissioning is eligible for VAT adjustment as long as they are for an eligible VAT notice 708 buildings water supply and completed ‘in the course of construction’.
Water boreholes completed before or after construction are not eligible.
Survey boreholes are not eligible.
Thanks again for your help everyone, 3k saving!!! I hope this helps somebody going forward!!!!
I had same problem and  Ihave it claim it back  for hmrc -with vat reclaim
same as all the other stuff you will be buying
zero rate will only apply if work being done by main contractor
 vat reclaim
