Hi,
I am in the process of buying a small cottage in Rural Scotland.
Drainage from the house is to an old brick septic tank which is within the garden.
The cottage was built in 1850, at a guess the septic tank and associated system is at least 70 years old.
The title deeds describe a servitude right to maintain the tail pipe/soakaway from the septic tank.
However, this tail pipe/soakaway is not shown of the title plot plan drawing.
I asked the Vendors to show the approximate location of the tail pipe/soakaway on a drawing.
They have produced a sketch which shows the tailpipe being only 2m long and just terminating at the garden fence, which separates the garden from the adjacent farmer’s field.
My question is; I thought soakaways were generally quite a lot longer than 2m, is it possible that the soakaway is only 2m long?
Thanks
It'll just be an old clay pipe running in to a ditch.
If in doubt, budget on a full new treatment plant and soak away / discharge and get it taken off the asking price.
Thanks Conor.
There is a small stream probably 5m downhill from where they showed the termination of the pipe, so maybe you are correct with the clay pipe.
Out of interest would the discharge from the clay pipe be a bit smelly in the summer?
A septic tank should not discharge to a watercourse.  But of course in the real world we all know many do.
The best upgrade you could do is replace the septic tank with a proper treatment plant, discharging into the watercourse.
You will need planning permission, a building warrant and a permit from SEPA but well worth it.
4 hours ago, DTL said:
Hi,
Thanks
Good post.
Hope my comment help rather than hinder. The law in Scotland is differs from the rest of the UK.
Your starting point is to check that the existing tank has been registered with SEPA, your Solicitor should check this, you can also do this yourself. It's worth doing your own due dilligence.
Now it gets a bit more complicated / political. The tail pipe seems to extend onto land you don't own and yes this is likely too short for a soak away. Also if you extend then you'll maybe need to discharge more.
So putting my crusty Scottish hat on, like Yorkshire farmers, I think, do I smell a rat? Has the seller fallen out with the farmer / owner next door or is it just benign?
Why have they not shown how the soakaway works and the location of the drainage field. I suspect that once you delve down you may find that you are exposed risk wise. Push your solicitor to get the the bottom of this.
Now some folk may just buy this, maybe get stung. But also look to see if you can do a soakaway in your own land. Make no mistake, when it comes to farmers / rural Scottish sellers most are well clued up and if they can pass the buck to you they will. One way is to think, can I do my own soakaway in my own land and negotiate a discount on the price.
Thanks for the replies, as suggested I'm going to ask some more questions of the vendor.
The Septic tank is registered with SEPA, as I understand it, it is the point of discharge from the tank within the garden that is registered with SEPA.
Its very unlikely that any new soakaway system could be implemented within the garden, as the garden is very small.
The deeds say I have a servitude right to a tail pipe, but on asking where this tail pipe was the Vendors are saying its the 2m pipe in the garden.
As Gus identifies, the fact that the tailpipe/soakaway ends exactly by the garden fence, not extending into neighbours land and not extending further towards the stream could be suspicious/problematic.
Given that the septic tank discharge is registered with SEPA, and the drainage arrangement is existing and historical, is discharge close to a water (or into) a water course allowable?
When the tank was registered, would the owner have to have declared the location of the discharge adjacent to the stream?
I.E does the fact that the tank is registered with SEPA mean that SEPA are aware how and where the discharge from the tank works, and are OK with this?
Thanks
Tail Pipe is the wrong thing to be asking about.  It is the drainage field or infiltration field that matters.  I don't literally mean a field, that term refers to an area of ground that has a network of perforated pipes set on stone buried under the field.  In the case of out last house the deed of servitude indicated the position and size of that under the adjoining field.
The good news is as long as it actually works, and it does drain somewhere, SEPA are exceedingly unlikely to ever bother you.  In spite of what they might say, the reality is they are not taking any enforcement about people here with septic tanks discharging directly into the burn.  But the bad news if you find it is not draining away then you will have problems sorting it out.  Worst case is you have to dig up the field where your tail pipe leads to and re lay the drainage field.  That will test if you really have a deed of servitude, so now is the time to properly get to the bottom of that.  Make your solicitor earn his money.
Do you have direct access to the watercourse or would you have to run a pipe over other peoples land to get there.  It is worth exploring that so you have the option to upgrade to a treatment plant discharging to water. That is SO much better,
P.S.  the outflow from a septic tank will stink.  The outflow from a properly functioning treatment plant should be a clear and odourless liquid.
Thanks for response.
According to the text in the deeds we have a servitude and maintenance right to the tailpipe. Which the vendors are now saying is 2m long, and within the garden.
There is no mention of a soakaway or drainage field within the title deeds.
The stream is outside the garden, and we would not have any rights to be installing anything outwith the extent of the garden, unless it historically existed.
I had a look a the SEPA certificate and it stated that discharge shall be "to land via a soakaway"
I will challenge Vendors more on the location of soakaway/drainage field.
However in the worst case can one argue to SEPA, that a 2m long clay pipe has historically been operating as a soakaway?
Edited by DTL
You don't need a servitude right for anything in your own garden.  A servitude right gives you a right to do something on other people's land, like the example of my previous house where it allowed us to install a drainage field under the adjacent farmers field.  That servitude right was presumably negotiated by the owner before he put our plot up for sale.
Be very careful here, you have a system that might work now by discharging to somewhere unknown (I doubt that 2M pipe is enough) but you don't appear to have any right to do anything outside your own garden,
IF that system ever fails, then you have no right to do anything on other land to fix it, or install any replacement system.  Your own small garden will NOT be enough room.
This is where you need a good solicitor that understands these things.  He should be insisting the vendor gets busy and negotiates a servitude right with the owner of the adjoining field where this tail pipe leads to.
I hope you have not yet concluded the missives?
The missives are not concluded, this is the final piece.
The title gives rights to the servitude of the tail pipe in text only, with no description as to where the pipe is actually located.
So, in theory if it had turned out it was in the farmers field we would have had rights to access, albeit it might have been a bit argumentative with the farmer as its location was not explicitly stated. However, in theory our right would have existed.
To make things tidier we asked the vendor to clarify the pipe location, they then provided the sketch showing the 2m pipe in the garden.
This was provided via an affidavit, so if the purchase was to go through the title would be updated to reflect this supposed location of the pipe, which would then effectively remove our rights for anything that is maybe in the farmers field.
In similar circumstances I got a letter from the vendor stating that the septic tank and drain to soakaway in the nearby field had been in use for x (over 50??) years.
It is very likely that your pipe extends beyond the boundary as it is pointed that way.
If there is a hedge over a porous pipe  it's roots  will have filled it long ago.
 So it's likely a pipe to a rubble soakaway.
Thanks for your response.
I don't understand what you mean about blocked pipe and how that then leads to requiring a rubble soakaway?
Can you clarify this for me
Many Thanks
Thanks for all the input on this thread.
I'm working on getting the vendors to perform a drain survey.
However, to plan ahead a bit.
We know the tank is an old brick tank.
The current set up is fully licensed by SEPA.
After the survey if we find out the soakaway is only 2m long, then I'm pretty confident that the system cant be upgraded if constrained within the garden, because a 2m soakaway is not going meet the requirements.
The property will be an unlet 3 bed holiday cottage probably only occupied for 8 days a month.
The septic system has probably been there for at least 70 years and has probably been working fine.
If it was to have problems in the future will it be possible to maintain my way out of any problems, ie repair the brick tank?
And, if a 2m soakaway stops working can I not dig out all the muck and replace it with fresh stone?
Thanks
Edited by DTL
Likely, yes. But the brickwork is probably already leaking significantly, but steadily and in semi treated form.
it would probably be better and easier  to extend the rubble soakaway rather than dig it out, then there will be new clean capacity and the old volume may rot away over time.
OR you build a modern style soakaway using perforated pipes / drainage field.
With respect to what you mention about the brickwork already leaking do you mean;
Partially broken down sewage is probably leaking into the ground around the tank through the brickwork?
And if the answer to the above is yes then is this a good thing or a bad thing, I mean I guess it takes some pressure off the soakaway. Thoughts?
Thanks
Yes that. And not a very bad thing as long as it is working.
Brand new brick would allow seepage anyay. An older one will have cracks and I wouldn't repair it unless it was clearly causing problems.
I had ours emptied once and there was a foot of sludge on the bottom. More importantly it had junk in it , dumped by cowboy roofers from the past, and most importantly the inlet and outlets were damaged and needed repair.
You should assume that yours will need some such unpleasant work s a minimum. Eg
1. Suck out tank and the outlet pipe, rinse and repeat.
2. Check for internal damage  ask thd tanker company for an overview.
For this you must tell the company first or they will only allow a quick suck and leave.
At some cost level you decide instead to build a new system.
So I went and had a look:
The tank was full of liquid all the way to the concrete lid, the outlet being at least a couple of foot below the lid.
So I’m thinking there is no functioning soakaway. It’s clearly leaking out of the  top course of bricks.
There is about 4 foot of garden ground where the soakaway runs, but it’s a bog.
It probably works fine, but I’m concerned it’s not future proof.
Edited by DTL
NO it's NOT "working fine"
Clearly whatever soakaway it was supposed to have is either blocked, non existant or the water table is too high.  It is just leaking it's effluent into the now boggy garden.
Seriously, you need to factor at a very minimum getting the soakaway completely renewed which WILL mean digging up the field next door and re laying and so will need a deed of servitude.
I would be having serious discussions with the vendor (via your solicitor) to sort out the deed of servitude needed AND reduce the price to cover the work you WILL need to do.  You also need a proper percolation test done in the location you will construct the replacement drainage field to determine if indeed it is even feasible.
Failure to do that could leave you with a non functioning drainage system without the means to fix it.
If that is too much for you, walk away and look for a different house to buy.
this will be noted during any search process, so the vendor should be advised to allow for this reduction. unless of course they think it is allowed already in the asking price.
MY inclination would be to do less rather than more, ie clean it out and increase the soakaway.  £2-3k ?
But at worst case you do this and it `works for a while then ceases to work, so you  end up with a treatment tank. £12k.
£5k allowance reasonable, depending on how much diy is involved and any design costs. Others may say allow more.
Good Feedback, Thanks
I don't think there was ever a proper soakaway.
The Deeds mention the rights of servitude on neighbouring land for a "tailpipe".
But it is not marked up on the plan.
And the sellers are now just implying they have a very short soakaway in their garden, which cant work cos that corner of the garden the water table is too high.
The sellers are implying that the original tail pipe might be gone.
Looking at the pipe run then the original tail pipe ran towards a stream 15m away from the septic tank, the land on the way to the stream is also peaty bog.
I'm now thinking that when the tank was built back in the old days, the discharge was piped direct to the stream.
The water table is too high on the entire run between the septic tank and the stream for a soakaway, you would just be installing a land drain.
If this is the case then that original tail pipe is now blocked or no longer exists, otherwise the tank level would be down at its outlet level.
I guess if I did have rights to a piped discharge to the stream I could maybe install one of the bio disc tank things.
But to get get this right it would be necessary to prove the pipe is there, ie excavate it.
How tricky is it to get the right to discharge from a bio disc tank to a water course in Scotland?
Thanks
It's part of the building warrant process and agreed with SEPA who issue a permit.  Generally they only do so if land drainage is not possible which appears to be the case here.
You could always get the existing tank pumped out and get at the tail pipe with drain rods and see how far it goes and who knows it might go all the way and you unblock it?
OK thanks.
Assuming I could unblock the tail pipe to the stream, would I be able to operate the tank with discharge to the stream for a while?
i notice the SEPA certificate mentions the use of a soakaway with no pollution of water.
That will say whatever the vendor told them when registering it prior to putting it for sale.
I know of 2 round here with septic tanks draining to a watercourse and SEPA have shown no interest in doing anything about it.
My suggestion of rodding it was to see just how far it went and if by chance it did go to the stream, you know you have a route to discharge a proper treatment plant.
