Spinny Posted October 28, 2025 Posted October 28, 2025 Anyone used LED strip under the edge of a kitchen worktop ? Does it need to be IP65 or is IP20 going to be fine ? Does it need to be 8mm wide, could I use 10mm addressable ? Need to rebate the underside edge of the work top ?
jack Posted October 28, 2025 Posted October 28, 2025 Can't help with your actual question, sorry. I have a suspicion that you might highlight every little imperfection in your drawer and cupboard door alignment, but I might be overthinking it!
Nickfromwales Posted October 28, 2025 Posted October 28, 2025 1 hour ago, Spinny said: Anyone used LED strip under the edge of a kitchen worktop ? Does it need to be IP65 or is IP20 going to be fine ? Does it need to be 8mm wide, could I use 10mm addressable ? Need to rebate the underside edge of the work top ? If 12/24v then it’s SELV (Safety Extra Low Voltage) so you could lay it in the bath and jump in safely. There are some very thin led strips out there atm, but the likelihood is you’d need deeper than standard worktops to gain a little more overhang, as a standard worktop doesn’t have sufficient real estate to do this imo. 1
nod Posted October 29, 2025 Posted October 29, 2025 The groove that is cut in granite and quarts is 20 mil x10 mil deep and seems to work ok 1
Spinny Posted October 29, 2025 Author Posted October 29, 2025 So I have kitchen cabinet people saying they normally just stick the LED strip to the underside of the worktop. Worktop people say it can be stuck on the bottom, but they can also cut a rebate in the underside of the quartz, for which there is no standard size rebate, and customer needs to specify depending on strip size used. . Anyone have this in their kitchen ? I guess you do @nod - did you buy the strip ?
-rick- Posted October 29, 2025 Posted October 29, 2025 Don't just stick normal strips underneath, you need a diffuser to avoid seeing the individual LEDs. You can get COB strips that have diffusion built in but the are usually white only so may not be what you want. So get an aluminium profile with a diffuser strip if you want a good looking outcome, consider getting profiles that angle the light in the way you want. I'd guess there are some prepackaged solutions for significant money that might avoid the profile but then you have lock in to the manufacturer rather than a generic, future proof, solution.
nod Posted October 29, 2025 Posted October 29, 2025 4 hours ago, Spinny said: So I have kitchen cabinet people saying they normally just stick the LED strip to the underside of the worktop. Worktop people say it can be stuck on the bottom, but they can also cut a rebate in the underside of the quartz, for which there is no standard size rebate, and customer needs to specify depending on strip size used. . Anyone have this in their kitchen ? I guess you do @nod - did you buy the strip ? Yes Just use a self adhesive strip type
Jothetaxi Posted November 19, 2025 Posted November 19, 2025 If used, the LED tape is for effect under the overhang of a deeper worktop, such as an island seating area. They can also be used along the base boards of the kitchen units. Personally, I would keep it simple and stick to under cabinet lighting for tasks, pendant lights over islands or lighting inside units. These are all functional.
