John Carroll Posted October 30 Posted October 30 41 minutes ago, richo106 said: Yes I can understand the low dT, I checked the temps again this morning and loops ranged between 1-1.8 deg loss, but IR camera was bouncing around a little so hard to be super accurate I will turn off the GF manifold again so the the pump just feeds the FF to see what flow rates I can achieve per loop. currently the ASHP feeds a buffer tank and then pumped from there to both manifolds using a single pump. one thing that I want to try is not shutting my heating off during 4-7 during the expensive period to see if this makes any difference at all. I’ll just run my heating 24/7 on weather comp with thermostats set at 23.5 to stop overheating. do you think this will make much difference cost wise? It takes a large amount of energy to reheat the floors and buffer tank when it heats back up at 7 so hopefully it won’t be too much difference any thoughts on this would be helpful @marshian probably answered your query re continuous heating. You might check the Stuart Turner circ pump mode&setting, it has three constant curve settings and three proportional pressure settings, ensure its on constant curve setting 3, if not sure of the modes, tahe a photo of the pump switch or LEDs while running.
richo106 Posted October 30 Author Posted October 30 26 minutes ago, John Carroll said: @marshian probably answered your query re continuous heating. You might check the Stuart Turner circ pump mode&setting, it has three constant curve settings and three proportional pressure settings, ensure its on constant curve setting 3, if not sure of the modes, tahe a photo of the pump switch or LEDs while running. Yes I will certainly try 24/7 running, will set this up tonight to see how I go on for the next few days. Will try and monitor temp and energy consumption best I can but not too cold at the minute If this doesn’t make anything difference I’ll defo look at increasing the flow rate, somehow splitting the circuits and installing an additional pump
marshian Posted October 30 Posted October 30 31 minutes ago, John Carroll said: @marshian probably answered your query re continuous heating. Every house I appreciate is different and responds accordingly but I was running 2 deg setback in most of the rooms for 4 hours at night and 5 hours in the day and in a week of relatively stable OAT's I used more energy on the setback days than I did on the 24/7 (if anything the setback days were slightly warmer although I was only looking at the average temp between coldest and warmest temp across 24 hrs (it could have been colder for longer on the warmer days) It's one of those experiments that you do for fun
marshian Posted October 30 Posted October 30 1 minute ago, richo106 said: Yes I will certainly try 24/7 running, will set this up tonight to see how I go on for the next few days. Will try and monitor temp and energy consumption best I can but not too cold at the minute If this doesn’t make anything difference I’ll defo look at increasing the flow rate, somehow splitting the circuits and installing an additional pump You might not need to split the circuits - Heat Geek did a video on pump distortion not that long ago
richo106 Posted October 30 Author Posted October 30 I just turned my GF manifold off and checked the flow rates of the FF one Basically when the downstairs is on its looking approx 24/25 When the downstairs is off its about 35 Is that what people would expect? I will look into the pump settings shorty
richo106 Posted October 30 Author Posted October 30 Right after looking on the internet My pump was on proportional power - medium (flashing green) I have now changed this to constant power - highest power (constant orange)
marshian Posted October 30 Posted October 30 1 minute ago, richo106 said: Right after looking on the internet My pump was on proportional power - medium (flashing green) I have now changed this to constant power - highest power (constant orange) Modern pumps are a real head fug - they are a bit to damn clever sometimes My limited understanding is the faster the pump speed the smaller the delta between flow and return so you give the emitter more time to get rid of the heat (That's the impact in my house) but in your case where you are trying to get the emitter to give off more heat it may well prove effective - guess testing and monitoring are required Having said that constant curve is what I settled on (mainly because the flow on proportional settings changed from when I first set the pump up to maybe a week or so later - some learning logic I think)
marshian Posted October 30 Posted October 30 19 minutes ago, richo106 said: I just turned my GF manifold off and checked the flow rates of the FF one Basically when the downstairs is on its looking approx 24/25 When the downstairs is off its about 35 Is that what people would expect? I will look into the pump settings shorty Blimey 34.5 litres a min is 2070 litres per hour.... that feels like a heck of a lot of flow.
John Carroll Posted October 31 Posted October 31 Changing the pump mode should result in increased flow, interesting to see if it actually does.
richo106 Posted 11 hours ago Author Posted 11 hours ago Hi All We are now having the first cold snap since starting this thread. And unfortunately my daughter’s bedroom with door shut is Currently 17.5 degrees! The only thing I have changed so far from last year is not stopped the heating during the expensive period (16.00 - 19.00) I think it’s pretty it’s the installation/lack of pipes that’s the main reason but I now just trying to thinks of ways to help it a little I might change my weather comp to 35 deg at 0 deg (currently -3 or -5 can’t remember exactly ) I will turn my pump to powerful mode to increase l/min on the manifolds is it worth increasing the temperature passed 35 deg or would then it become inefficient? any other ideals would be very grateful
marshian Posted 11 hours ago Posted 11 hours ago 23 minutes ago, richo106 said: is it worth increasing the temperature passed 35 deg or would then it become inefficient? any other ideals would be very grateful Being "super efficient but cold" or being "slightly less efficient and warm"? Me I'll take the cooler option but Mrs Alien would rapidly be Mrs Ex-Alien (Divorces are a lot more expensive than energy) so I compromise and take the slightly less efficient option
Nick Laslett Posted 2 hours ago Posted 2 hours ago (edited) @richo106, I have not been following this thread, but I feel your pain now that the cold winter weather has arrived. I’m not familiar with this approach or the design trade offs. I have no special knowledge about UFH installs. Just another amateur forum member. This blog advocates against using aluminium spreader plates with ASHP. They say it will need flow temp as high as 55°C, not 35°C. https://underfloorheating1.co.uk/blog/article/Water_Underfloor_Heating_and_Aluminium_Spreader_Plates?srsltid=AfmBOoositKuZ1fOjlxZgV8ygJwVgrd35zIhyDGKj6mPuA0uxoPp7vSo The approach they advocate, might be a possible retro fit. But still a lot of work. https://underfloorheating1.co.uk/blog/article/Can_I_have_underfloor_heating_with_joisted_floors?srsltid=AfmBOopQsQvvgP2zHQn6UMCldTzV5P6j8MawfYv3Le-SGh1CHtie8wYo Edited 2 hours ago by Nick Laslett
JohnMo Posted 2 hours ago Posted 2 hours ago As you have thermostats and a buffer For now just go a fixed flow temp to see what temp you need to get FF output correct, start at 35. If your downstairs thermostat(s) switch of the HP, set all but one to the temp you want, leave one calling for heat (maybe turn down the flow to that loop).
