Nicolas Posted October 24, 2025 Posted October 24, 2025 I have read quite a few discussions about architects' fees, but my question is specific to the cost of designing a Passive House. We're not too bothered about certification, but want the design confirmed via the PHPP. We are likely to use a timber frame from the likes of MBC, PYC Construction etc. Around 130-160m2, flat plot with existing services. I was about to contact an architectural practice, but noticed that they quote £8.5k to get to a planning submission, then £20k for working drawings. I assume that the latter includes Building Control drawings. All plus VAT. £20k seems excessive, especially as most (all?), of the section and junction details will have been used repeatedly on previous projects. Roughly how much has anyone paid for planning drawings and the associated application plus construction drawings for a Passive House? On a related note, do experienced timber frame companies even need detailed construction drawings?
JohnMo Posted October 24, 2025 Posted October 24, 2025 Daft question - if MBC say are designing the house to passivhaus spec, what is the architect adding to the party? So then you use a normal architect with MBC. Architect does the broad design stuff, MBC the details of thermal bridging, airtightness etc 1
Nicolas Posted October 24, 2025 Author Posted October 24, 2025 56 minutes ago, JohnMo said: So then you use a normal architect with MBC. Architect does the broad design stuff, MBC the details of thermal bridging, airtightness etc Thanks, that's what I'm wondering, although it assumes that the design for planning permission is good enough to meet the PH requirements. I have been tempted to buy the PHPP to see how difficult it is to use. I'll ask a few timber frame companies - the websites I've looked at don't make it all that clear what they need from customers or what they provide in terms of design.
JohnMo Posted October 24, 2025 Posted October 24, 2025 1 hour ago, Nicolas said: good enough to meet the PH requirements Form factor makes a huge difference, to insulation levels needed.
marmic Posted October 24, 2025 Posted October 24, 2025 for planning stage design we followed passivhaus rules of thumb and submitted old school pencil drawings and statement (by me - cost was a huge amount of time!) and stated passivhaus, but didn't state certified. Once planning approved we then developed design further and paid consultant to run through phpp and we were bang on. We are hitting passivhaus high performance but not quite certified level however (wouldn't have paid for a plaque anyway!) which I had anticipated - simple reason form factor as we are only single storey app 100m2 - as JohnMo states form factor is important. yes the theory is use phpp at planning, but with some common sense and careful thought I didn't believe I needed to - which I didn't. 1
Nicolas Posted October 24, 2025 Author Posted October 24, 2025 Thanks for the reassurance marmic, that's very helpful. I do have a fairly good understanding of passivhaus principles and a familiarity with relevant build methods, so have been tempted to do the planning submission and PHPP myself - but there's the time factor, dealing with planners and fear of ending up with a home that doesn't perform as expected. How did you find a consultant, other than picking someone from the PHI directory? Feel free to message me. What was your build method? Did you have detailed design drawings?
Duncan62 Posted October 24, 2025 Posted October 24, 2025 31 minutes ago, Nicolas said: I do have a fairly good understanding of passivhaus principles and a familiarity with relevant build methods, so have been tempted to do the planning submission and PHPP myself. I would highly recommend doing it yourself if you have the time and inclination. I did all our planning drawings and PHPP. The cost, as said, it time. But compared to the quoted costs, seems like a bargain. Takes a long time to earn £20k after tax too. No one will care about it as much as you. Id say consider Passivhaus certification. As a proportion of total cost it is low, Circa £2.5k AND the initial design reviews will correct any errors and guide you in the right direction. 1
Alan Ambrose Posted October 24, 2025 Posted October 24, 2025 PHPP is a 20-30 page spreadsheet. Pretty complicated but not indecipherable. The manual is pretty good and a good primer on relevant building physics. Highly suggest using PHPP if you’re not daunted by big spreadsheets. You may want to, or may have to (depending on your BCO) get it checked by a kosher PHPP ‘expert’. It will let you make tradeoffs on your design e.g. window schedule vs. overheating. 2
Nicolas Posted October 24, 2025 Author Posted October 24, 2025 Many thanks, to both of you. I'd looked at Richard Bendy's website, but it's encouraging to find someone who has used his services. The certification suggestion is certainly something to mull over.
Kevan Marshall Posted December 20, 2025 Posted December 20, 2025 On 24/10/2025 at 16:29, JohnMo said: Form factor makes a huge difference, to insulation levels needed. On 24/10/2025 at 13:55, JohnMo said: Daft question - if MBC say are designing the house to passivhaus spec, what is the architect adding to the party? So then you use a normal architect with MBC. Architect does the broad design stuff, MBC the details of thermal bridging, airtightness etc Hi John, Going through the same thing with my architect, my timber frame company do all calculations with their engineers do drawings for building control, make sure everything is ok for signing off, do all AT tests, etc, my architect is asking for technical specs to submit drawings for building control and I’ve told him drawings from TF manufacturer shall be ok and all he has to do is submit them with a note saying “as per according to Building regulations and Timber frame manufacturers specifications”, I am finding the worst part of self building is Architects and Solicitors…
SimonD Posted December 20, 2025 Posted December 20, 2025 17 minutes ago, Kevan Marshall said: I am finding the worst part of self building is Architects and Solicitors… You will find a general allergy of 'professionals' on BH as we've all been there, done that and got burned to various degrees. You can often lump SEs in there too - we had to sack our first one. That's one of the reasons som many on here do so much themselves and provide very good guidance on how to navigate the swamp. 1
Kevan Marshall Posted December 20, 2025 Posted December 20, 2025 3 minutes ago, SimonD said: You will find a general allergy of 'professionals' on BH as we've all been there, done that and got burned to various degrees. You can often lump SEs in there too - we had to sack our first one. That's one of the reasons som many on here do so much themselves and provide very good guidance on how to navigate the swamp. Yes I fully agree, architects love spending other people’s money and think they are designing the house for themselves, I gave detailed drawings to my architect to tweak a little and we ended up back at the start after draft number six, Solicitors just don’t answer emails or telephone you, their communication skills are zero, hopefully I’ll not need a structural engineer as that would just be another headache… 1
Stratman Posted December 20, 2025 Posted December 20, 2025 1 hour ago, Kevan Marshall said: my architect is asking for technical specs to submit drawings for building control and I’ve told him drawings from TF manufacturer shall be ok and all he has to do is submit them There's more to technical design than just the timber frame. If you don't appoint (and pay) your consultants to provide this service you can do it yourself if you feel qualified, or go down the design and build route with a general contractor. One way or another you'll pay for it.
Kevan Marshall Posted December 20, 2025 Posted December 20, 2025 1 minute ago, Stratman said: There's more to technical design than just the timber frame. If you don't appoint (and pay) your consultants to provide this service you can do it yourself if you feel qualified, or go down the design and build route with a general contractor. One way or another you'll pay for it. Yes, fully understand, he is used to new builds that are conventional block built houses and he cannot get his head around timber frame/SIP’s structures, I told him at the start that I would require him for planning applications, drawings for foundations (timber frame company shall give exact dimensions for base/sole plate), I am looking at more modern building techniques whereas the architect is doing everything in a way he has always done things, he is also going way above and beyond what is necessary but I think most architects do that, hopefully things shall get easier when I decide who I use for building envelope and get their drawings…
Stratman Posted December 22, 2025 Posted December 22, 2025 That's quite a limited scope of service. For planning application things like stairs and drainage won't be designed in sufficient detail to submit for building regs. You'll probably need to supplement the design with other details and specs for things like overheating (to part o), stairs and guardrails (to part k), ventilation (part f), accessibility (part m), fire safety (part b), etc. But you've probably looked at those already so apologies if you have that covered. Part o seems to cause a lot of confusion if you want to follow the 'simple' method. It has caused me some headaches.
