Happy Valley Posted Wednesday at 12:44 Posted Wednesday at 12:44 Two of our landing triple glazed Origin aluminium windows do not open. This time of year the landing can get extremely warm transferring heat into other rooms. We are looking at installing an external window film which reduces the solar heat gain enormously. What are the best products for this that people have used please?
Mr Punter Posted Wednesday at 14:19 Posted Wednesday at 14:19 3M do some that are fairly transparent for the reduction in solar gain but expensive. The silver reflective ones are cheap and effective but noticeably darker inside. 1
Post and beam Posted Wednesday at 14:23 Posted Wednesday at 14:23 Shutters outside? Or the fancy french name for same 2
Russdl Posted Wednesday at 14:52 Posted Wednesday at 14:52 Will a film affect your desired solar gain during the winter months? An external shading solution that can be removed when not required would be your best bet. Can you mount sail shades? 1
Gone West Posted Wednesday at 15:36 Posted Wednesday at 15:36 We had Clearview Vista 80X fitted on a 4m glazed gable which did reduce heat gain, but was expensive. https://www.sun-x.co.uk/window-film/clearview-solar-film 1
Happy Valley Posted 15 hours ago Author Posted 15 hours ago 23 hours ago, Post and beam said: Shutters outside? Or the fancy french name for same It is one consideration although it is likely to be massively more expensive and I don't like holes being drilled through the house for the electrics or manual operation
Happy Valley Posted 15 hours ago Author Posted 15 hours ago 23 hours ago, Russdl said: Will a film affect your desired solar gain during the winter months? An external shading solution that can be removed when not required would be your best bet. Can you mount sail shades? It's mainly NE facing so gets very little solar gain in the winter but becomes hot in the summer. It's 1st floor so shade sails are not something that I would want to maintain.
Happy Valley Posted 15 hours ago Author Posted 15 hours ago 23 hours ago, JohnMo said: Internal blinds? Already have them and want to stop the heat the other side of the glass.
Happy Valley Posted 15 hours ago Author Posted 15 hours ago 23 hours ago, Post and beam said: Shutters outside? Or the fancy french name for same Breize Soliel is a consideration if the film doesn't work effectively enough. Shutters are probably the best overall solution but not one I want to entertain at this stage due to cost and drilling through to inside of the property.
mike2016 Posted 15 hours ago Posted 15 hours ago I've briese soliel but it required structural calcs and a steel window header to connect to (done as part of build). That said they worked brilliantly this year. Just check your warranty with windows supplier vs any film to make sure it doesn't invalidate it. Or plant tall trees!
