Hi,
I'm doing a main sewer connection for foul and surface drainage in the next few weeks/month. We're in a deep clay area and the sewers are all combined systems around here. The house just now is four bedrooms with family bathroom, w/c, and kitchen. It will later likely be (drawings still in process) 6 bedrooms, 3 en-suite shower rooms, main bathroom, kitchen, w/c, and utility. There may be a toilet in the detached garage later as well.
There is an existing manhole on the edge of the garden that is well built and looks to be 80s/90s. They left a stub so that i can join on.
I'm wondering what the ideal gradient is? I've got a connection to the main at around 1.5m and don't have that far to travel so have plenty space to make it the ideal pitch. I keep seeing maximum or minimum gradient but I cant find the ideal. Is it halfway between the max and min? I'm mindful that clay can heave, although we have moderately mobile clay here.
I think I'm going to use clay supersleeve from the existing manhole to my own manhole but open to advice. I'll build my manhole by laying engineering bricks or concrete liners, and run out a section of clay so that I can then convert to plastic. I'm going to use plastic up to the existing house for cost and convenience but I will change this to clay when I do the extension and renovation later.
Steve
More information needed. You have told us that you have 1.5m of distance between the existing fixed points, but not the height difference.
The best slope depends on the gradient and the water quantity....you say it is combined, so we also need to know if you have a huge catchment for rain.
Plastic is very much easier to work with than clay. I wouldn't dream of using clay unless I was building a motorway or the liquid is nasty.
Just lay the normal plastic pipes as said, these are very robust. Just leave a good 200mm below, around and above and backfill with plenty of pea shingle to allow a bit of wiggle room.
My bad writing skills strike again!
The drop to connection on the existing manhole from ground level is 1.5m. I've not done the length yet but it has a 90* turn that I will 45* each side of the new manhole, probably 10m and 5m ish. I can measure it later.
Water is very hard. We'll get a filter for drinking water later but will be impractical for a whole house filter given the likely water demand, although I'd prefer it.
Roof will be pretty big but mot a mansion. Fairly typical 6 bedroom detached.
Plastic is easy to use but it goes brittle over time and the seals perish. The seals also often get nicked during installation although thats from being careless, which I rarely am.
I'm 45 now and don't want any major works when I get old. I've regularly seen clay pipework in practically new condition, despite being over 100 years old. Plastic pipe literally wears out and breaks up when jetted or rodded.
I don't mind plastic when it is easily inspected or replaced but don't want it anywhere underground. The gutters and rwp will be cast iron. My wife would prefer copper gutters and rwp but the mobile mechanics will have that away in no time.
Nope, that’s completely wrong information, sorry. UG stuff is near idiot proof and extremely robust, and as it’s not got UV getting to it has the resultant longevity.
Plastic soil stacks rising externally have been fine for 30+ years in direct sunlight.
Not sure where you’re getting your information from, but it’s duff. 🫤
54 minutes ago, Russell griffiths said:
clay pipe now uses plastic and rubber connectors,
That's right. More flexible and a better seal. Clay is for veey heavy loads and for nasty chemicals from factories (though I've seen rotted ones).
You've come to the right place if you're picking up such strange and erroneous information.
Next.... two 45 ° turns isn't right. You would generally  get away with it if only rainwater but it needs to be roddable for foul.  So a rodding point and 90° turn is needed. Or 2 at 45°. Plastic is normal for these too.
When you have measured, post a sketch.
Water hardness is not relevant.
Next tconsider  aluminium gutters.  In this situation plastic is not best, but cast iron is expensive and rusts, plus is low capacity.
There is copper effect available in aluminium.
 Contracted to a plumbing company for four years straddling covid and had to attend a lot of dig-ups. Particularly when family all came back to lockdown together and the drains were wroking harder than usual. Also been building extensions and doing renovations for circa 25 years. My information comes from personal experience.
Understood, just is the opposite of mine, with ~35 years on the coal face. I can still taste the damn coal :S
I think plastic is good in general, and always what I've used. I've never actually fitted a clay system entirely, only small repair sections to connect the fernco to. Its not infallible though and I don't want to cut corners for my own home. I've seen some real horror shows when working with drainage engineers, and dealing with human waste isn't glamorous. I'm fine to use it where its accessible but I don't want to have to be digging up my own driveway in 20 years, with my wife is giving me the side eye.
Get a good brand of pipe. I've picked some cheap ones up which feel half the weight of proper brands. Also make sure they come straight I've sent some bananas back once. Mustve been stores wrong for ages in sun or something.
If you fit it properly it'll probably outlast you. UG pipework is never accessible....
It is when it runs under suspended floors...
…… but technically not actually UG then and should revert back to domestic / above ground.
Bottom line is, it should be buried, or boxed in, and out of sight / UV, which is why you typically revert back to standard pipe as soon as you are out of the ground.
Stuff is still bombproof afaic, if fitted by someone who is competent / conscientious in their work.
I’ve installed miles of this stuff in domestic and commercial settings, just trying to think of a time where we had an issue with a seal, and tbh I can only recollect the seal ever pushing out completely because it was a Friday fitting; 2 mins to lube and push back in, and on to the next.
Silicone gel / spray lube is a must, plus chamfering the ends of cut pipe, then make sure the pipe runs are clipped properly, with particular attention paid where there are changes in direction (where the flush water etc drops one or two storeys and then turns horizontal, you need to control that ‘thump’), so observe that and you really will struggle to fail here.
Loads on here have DIY’d their foul and waste who have never done it before, just relying on lots of advice taken from here / other resources, and away to go.
The only problem I can recall in many km of drains is with connectors from one supplier. They were a pain to fit, but they then worked and it saved a lot of money.
My default is to use a smaller merchant and likely a brand that is not major, but the quality is good.
I contracted to a plumbing company for four years. They're like anything that's made from plastic i.e. cheaper and quicker but not better. The stuff literally wears thin and then fails. It gets chewed out by rats. It blows and explodes when jetted. It gets pierced and broken when rodded. Its affected by ground movement and the joints slip. Nothing wrong with it in a general sense, and I use it myself because its the industry standard, but its a downgrade.
I didn't think I'd get in to a conversation about how amazing plastic pipe is when asking about the ideal gradient for drainage. I like details, and finding out the pluses and minuses of any building component so I'm grateful for the input.
I appreciate the conversation points and I know that using clay is potentially an unnecessary extra expense. I personally will prefer to use it in the main run where its underground. I will change over to plastic where it enters the house.
I think even the quality of clay is not as good as it used to be. I've chopped into old clay before to make connections good as gold tried it couple of years ago on some modern clay stuff, supersleeve? It just went dead brittle and splintered into a million pieces. You can probably find some better quality stuff though. Was on a job where a 6" public drain had to be diverted and that was all in clay so must be a reason the water companies prefer it.
Depressingly true. Is anything as good as it used to be?
No. Sometimes I rethink on self build. For the price you pay for an older property, I think especially with some of the nicer period ones, you literally couldn't rebuild them for the price you can buy them for. The skills are not there. That's before you consider the quality of the materials used compared to now. Obviously there's cons to an older house but I'm not sure energy efficiency is the be all and end all it's made out to be.
I'd like to build using lime mortar instead of opc. Reasoning being that its just a softer and more natural product. It seems "alive" whereas opc just seems dead and lifeless. I know its not realistic though so am resigned to opc. We're on deep, moderate, clay here so I feel that lime would be a better option since it can handle the movement better and will need far less movement joints, which I hate the look of. I suspect that using Lime for new work will just cause loads of drama now and in the future for certification and selling.
It's a personal preference (and so for my own buildings is easy,  but not so much commercially), but I like to limit movement.
Movement joints can be much reduced, especially in masonry.
Bricks expand after manufacture, as they absorb moisture.
Blocks shrink as they cure then dry. Sometimes they were made only days before delivery.
Thus a cavity wall is severely stressed and needs joints.
Buy them early and store in free air and the situation disappears or at least lessens.
With concrete,   cracking is reduced through limiting the water content, and stopping evaporation. Judicious use of mesh or fibres helps too.
It will shrink and crack but much less than it might.  eg I haven't ever had cracks in large areas of floor tiles.
OR in some situations you let concrete floors or walls craze, then finishes cover it..
I've never thought about that before, thanks for telling me. Its something I consider when sizing timber but it hasn't ever occurred to me about bricks. Of course that makes sense!
I had a uni module of 'building science' (heat, light, sound) and it included materials science. It made me interested in such matters.
A  text  book comes to mind...'The new science of strong materials, OR why we don't fall through the floor.'
We only build houses to keep us warm, dry and safe from wolves. Then we want it to not fall on us. The rest is art.
