AdamD Posted June 23 Posted June 23 Created a play area for the kids at the back of the garden, swing set with slide etc. and just need to bark it to finish it off. Any suggestions as to the best type (softer the better presumably) and how to calculate the required amount? Recommended depth? The area to be covered is 44m²
Temp Posted June 23 Posted June 23 (edited) Google rocks.. https://www.barkukonline.co.uk/collections/play-grade-surfaces?srsltid=AfmBOoqGv5CR_O96uIvH6W7C5qLGVniOzjWKG3iM-RP8oh21auQzXlVG#. Quote How to use our play area bark Our play area bark is a quality bark material with an 8-40 mm particle size, that can be used for private and public play areas as well as a general garden mulch. Bark is made from the soft outer layer of trees and is, therefore, a very safe surface for your children to play on. Play area bark has a pleasant dark brown and red appearance that is non-staining and offers great protection from frost for your flower beds. For private play areas, we would recommend a minimum depth of 10-15 centimetres and 15-30 centimetres for public areas. When used as a border bark, play area bark retains its colour and size longer than most other organic mulches. With regular raking, play area bark can last for years. I only use bark for weed control on flower beds and it does degrade and become firmer over time. Edited June 23 by Temp 1
AdamD Posted June 23 Author Posted June 23 Crikey I didn’t think I’d need that much! 370 bags for 100mm depth. That depth feel a bit ott?
Nickfromwales Posted June 23 Posted June 23 Won't somebody PLEASE think of the children lol Just look for the soft impact rubber matting panels that do not need maintenance and stop noggins from a-floggins. 1
Temp Posted Tuesday at 07:44 Posted Tuesday at 07:44 11 hours ago, AdamD said: Crikey I didn’t think I’d need that much! 370 bags for 100mm depth. That depth feel a bit ott? Apparently BS EN 1177 standard requires 300 mm of bark or wood chip for critical fall heights up to 3 meters and in the USA they want 230mm to protect from falls of 7 feet. oh and an initial extra 25% to allow for settling!
Roundtuit Posted Tuesday at 08:22 Posted Tuesday at 08:22 12 hours ago, AdamD said: Crikey I didn’t think I’d need that much! 370 bags for 100mm depth. That depth feel a bit ott? Yep, that’s one massive cat litter tray! As @Nickfromwales, I'd be looking at rubber mats in critical areas. 1
Nickfromwales Posted Tuesday at 08:28 Posted Tuesday at 08:28 Kids bounce a fair bit, remember when we used to be one? 7' drop out of a tree was not enough to deter me from attempt #2, the good old days lol.
AdamD Posted Tuesday at 17:09 Author Posted Tuesday at 17:09 Yeah I’m just going with 50-60mm depth. 300mm is insane. its a double swing set with small slide, hardly bungee jumping without a cord! 1
ProDave Posted Tuesday at 17:24 Posted Tuesday at 17:24 We only ever had plain ordinary grass under swings etc. When I was at school the school playground had tarmac under the swings and climbing frames. You learned NOT to fall off. Just saying.
AdamD Posted Tuesday at 19:01 Author Posted Tuesday at 19:01 1 hour ago, ProDave said: We only ever had plain ordinary grass under swings etc. When I was at school the school playground had tarmac under the swings and climbing frames. You leaned NOT to fall off. Just saying. Ha yeah so true. Hardwood chipping at 50mm depth is what they’re getting. Probably overkill but is what it is.
