Dave Jones Posted Sunday at 10:42 Posted Sunday at 10:42 the issue with plumbers is 99% of them have no clue how to system design a ASHPO for efficiency. Any of them can throw a kit together using same principles as a gas boiler. This is one of the reasons they have such a bad rep. If you see a roomstat anywhere you know for sure its a shit install. 1
JamesPa Posted Sunday at 14:18 Posted Sunday at 14:18 (edited) 3 hours ago, Dave Jones said: the issue with plumbers is 99% of them have no clue how to system design a ASHPO for efficiency. Any of them can throw a kit together using same principles as a gas boiler. This is one of the reasons they have such a bad rep. If you see a roomstat anywhere you know for sure its a shit install. True but inexcusable. In most professions, indeed most jobs, you need to keep up with developments through ongoing training and, if you can't, or can't be bothered, you risk a performance improvement plan followed, if you don't succeed, by the sack. Why do plumbers think they are different? Presumably because, for 20 years, they got away (and are still getting away) with setting up condensing boilers in a way that they don't condense, thus adding 10% to our heating bills. Edited Sunday at 14:22 by JamesPa 1
sharpener Posted Sunday at 14:36 Posted Sunday at 14:36 6 hours ago, JamesPa said: I found this The use of the word "ideally" rather gives the game away doesn't it? In contractual documents it recognises that the advice following it is not going to be observed by many/most recipients. You could anyway argue that the presence of lockshield valves is "some form of temperature control". 1
JohnMo Posted Sunday at 14:57 Posted Sunday at 14:57 (edited) @sharpener a triple post! Thread now tidied, lol. Edited Sunday at 18:06 by Nickfromwales @sharpeners trigger finger
SteamyTea Posted Sunday at 19:01 Posted Sunday at 19:01 4 hours ago, JamesPa said: In most professions, indeed most jobs, you need to keep up with developments through ongoing training and, if you can't, or can't be bothered, you risk a performance improvement plan followed, if you don't succeed, by the sack. Why do plumbers think they are different? And Vicars, not as if they can change horses mid stream.
HughF Posted 17 hours ago Posted 17 hours ago 22 hours ago, Dave Jones said: the issue with plumbers is 99% of them have no clue how to system design a ASHPO for efficiency. Any of them can throw a kit together using same principles as a gas boiler. This is one of the reasons they have such a bad rep. If you see a roomstat anywhere you know for sure its a shit install. Nest + weather comp for us. Nest gives the wife an easy to use hi-limit (which is only rarely met in shoulder months). I consider myself a good designer/installer. heck, even the Samsung controller when used as a room stat is just that, an on/off stat. It doesn’t do load compensation, despite what people have been led to believe.
