Looking at floor coverings for our basement but we don’t have a lot of thickness to play with (max 15mm).
For laminate our choices then would be 8mm laminate with 5mm wood fibre underlay or 12mm laminate and 1.8mm foam underlay.
this is being laid on a Cemfloor screed so it’s pretty level with wet ufh below.
anyone used 8mm laminate? How does it perform? Anyone got both 8mm and 12mm and notice a difference?
I guess another question is would the 1.8mm underlay be suitable for under laminate on the screed. With regards to it being enough to even out any small imperfections in the screed.
Another question while I think about it. Which solution would you choose?!
Why not wood effect LVT?
I’m not convinced I can diy that. We’re pretty good at wood/laminate so was thinking about what we know we can install.
5 minutes ago, Nickfromwales said:
Cant see why not. You’ll not be running at very high temps down there?
Nope and it’s hardly used down there as it’s a pretty constant temperature but need something suitable in case we do want to run the ufh.
I have 12mm laminate with 2mm foam on screed with ufh, I have also fitted something like what @Nickfromwales linked to in a customers house with ufh.
I would probably go with the lvt as it is waterproof and seemed a bit more robust than our laminate. Your floor should be good for flatness which is important.
Then don’t fit a thin laminate as it’ll likely be dogshit and won’t go the distance. Everywhere where I’ve seen cheap laminate the corners have come away, where they have already started their death roll by the boxes being moved and edges bumped which fractures the laminate, or they start to show their age early in high traffic areas.
Consider ribbons or other thresholds so a room can be ‘fixed’ without pulling up other areas to facilitate this.
We have just ordered 6mm thick click fit LVT with integrated underlay. We are going to put this directly on a Cemfloor screed on one floor and on top of 6mm plywood on the other floor.
Comes from a company called Invictus. This is one of the chosen "patterns" - https://invictus.co.uk/lvt-maximusclick-newenglandoak-sand?sc_trk={254AF85D-8A2B-4925-8DD4-DCC0EB1A71FC}
Edited by BotusBuild
If I was restricted for thickness
Id go for the thinner laminate and more underneath it
We used Lignum Core LVT, with the built in underlay. Picture of it being laid, very easy to work with but you need a very level floor. Went for it due to its advantages with UFH and that its scratch, impact proof, waterproof etc.
Get yourself to a flooring store as they nearly always give a bit of a discount
so we decided to go for the click-lvt, 6.5mm with the underlay already attached.
do i need to seal the concrete before i lay? it's a Cemfloor screed that was laid about 3yrs ago
Nope. DPM will already be dealt with so just follow the installation instructions and crack on 🫡
That was the correct answer! 🤘
