skeg0 Posted April 22, 2025 Posted April 22, 2025 Hi! Would appreciate some quick advice with regards to attaching some wooden sills to our recently constructed timber frame house. You’ll see in the attached image that the timber frame is there under the plasterboard and the silver insulation. I have pine ‘planks’ to go on top of this that form the window sill but I’m not sure the best way of attaching them to the frame below. Can I for example screw/nail them through the silver insulation to the frame underneath? Or should I keep the insulation completely intact? If it helps the house construction is timber frame with block work. Thanks so much in advance!
ProDave Posted April 22, 2025 Posted April 22, 2025 Am I seeing a gap down into a cavity between the window and the silver foil? If so that wants addressing first. I just cut a strip from the plasterboard each side so the sill slides in and fill around it afterwards and mine were just stuck down.
skeg0 Posted April 22, 2025 Author Posted April 22, 2025 2 minutes ago, ProDave said: Am I seeing a gap down into a cavity between the window and the silver foil? If so that wants addressing first. I just cut a strip from the plasterboard each side so the sill slides in and fill around it afterwards and mine were just stuck down. Thanks for your reply - no gap into the cavity, just (im assuming) some black DPC. So you would put some plasterboard flat on top, screw it down and then stick down with glue/adhesive?
ProDave Posted April 22, 2025 Posted April 22, 2025 I didn't even screw mine down, just glued it. It depends if you think the wood will warp or not? See what I mean about the sill going into a slot each side cut into the plasterboard.
Roundtuit Posted April 22, 2025 Posted April 22, 2025 Is that insulation you can see, or just silver breather membrane lapped over the timber frame? If the window is sitting in the block outer skin, there will be a cavity somewhere. As @ProDave says, maybe have a poke about just to make sure you don't have a cold spot. 1
skeg0 Posted April 22, 2025 Author Posted April 22, 2025 I reckon it’s just the silver breather as you say. From what I can see there is no cavity. There were gaps left and right between the vertical plasterboard at the sides of the window and the sill which I filled up with foam which you can see in the photo as there were draughts coming through there but everything else was fine. I read a note from our timber frame company that asks is what type of paslode nail we want to fix the sills. So I guess they suggest we nail them?!
Iceverge Posted April 22, 2025 Posted April 22, 2025 Let the timber sills inside the house for 3-4 days to acclimate to the house first. Then glue or pin nail the sills in place.
skeg0 Posted April 22, 2025 Author Posted April 22, 2025 4 minutes ago, Iceverge said: Let the timber sills inside the house for 3-4 days to acclimate to the house first. Then glue or pin nail the sills in place. they have been inside for a year pretty much. But show signs of warping
Iceverge Posted April 22, 2025 Posted April 22, 2025 Thats timber for you. It does that. A good joiner will be able to plane it or somehow otherwise magically straighten it for you. 1
markc Posted April 22, 2025 Posted April 22, 2025 1 hour ago, skeg0 said: they have been inside for a year pretty much. But show signs of warping That board was destined to cup, if you look at the growth rings you can see it’s pretty much the bullseye in centre of the tree and will absorb moisture and expand much more than the outer rings. 1
G and J Posted April 22, 2025 Posted April 22, 2025 @skeg0 Are you going to paint them or leave them for varnish/wax/whatever?
skeg0 Posted April 23, 2025 Author Posted April 23, 2025 10 hours ago, G and J said: @skeg0 Are you going to paint them or leave them for varnish/wax/whatever? Probably varnish I think. Seemingly can’t risk any water getting on them!
G and J Posted April 23, 2025 Posted April 23, 2025 1 hour ago, skeg0 said: Probably varnish I think. Seemingly can’t risk any water getting on them! New (and better) bits of wood and glue it is then.
Nickfromwales Posted April 23, 2025 Posted April 23, 2025 If using those, not a hardwood, then defo seal the underside / sides as well, if not better, than you seal the faces. If not these will absorb moisture from the cavities. +1 for better bits of wood (sorry!).
Nickfromwales Posted April 23, 2025 Posted April 23, 2025 For eg Link We then bought 30mm oak stock and faced the 18mm stuff so that when installed it looked like 30mm thick oak sills were installed.
ProDave Posted April 23, 2025 Posted April 23, 2025 In case I did not mention all our window boards were leftovers from the engineered Oak flooring with a hardwood bead to finish the front. All still completely flat.
