metalgear2k2 Posted April 15, 2025 Posted April 15, 2025 Hi all, so I have made the mistake of pouring the ICF external walls without concidering how to connect the sigle leaf internal block walls. I work in an engineering company with a large workshop so I was thinking I would get some L brakets made and concrete screw to the ICF and to the internal block. I assume I'm not the only numty to do this, would any be willing to share how they came around it, detail, photos etc? Thanks
JohnMo Posted April 15, 2025 Posted April 15, 2025 We did ICF and the internal walls are all stud - is this an option? Ours do not touch the the ICF walls.
Nick Laslett Posted April 15, 2025 Posted April 15, 2025 (edited) You just need the right wall ties. Something like this: https://pamties.co.uk/product/wall-starter-kit-2/ https://www.vistaeng.co.uk/product/v63-universal-stainless-steel-wall-starter-system/ Cut back the EPS where the wall is going to start and treat it like you would adding a block wall to an existing block wall. Edited April 15, 2025 by Nick Laslett 1
JohnMo Posted April 15, 2025 Posted April 15, 2025 1 minute ago, Nick Laslett said: Cut back the EPS where the wall is going to start Isn't that just introducing a thermal bridge? Or is the majority of the insulation on the outside?
Nick Laslett Posted April 15, 2025 Posted April 15, 2025 1 minute ago, JohnMo said: Isn't that just introducing a thermal bridge? Or is the majority of the insulation on the outside? I don’t think so, but could be wildly wrong on this one. My understanding was that with EPS ICF the external insulation is all that matters, the internal EPS is entirely sacrificial, it could be removed and it wouldn’t affect the U-value of the wall. Of course it is not as simple as that, but my understanding is that from a U-value calculation the internal EPS is ignored.
Nick Laslett Posted April 15, 2025 Posted April 15, 2025 @metalgear2k2 If you are worried about potential thermal bridge, you could bolt some timber to the EPS, like how you would construct a stud wall, and then use the starter bars. Like @JohnMo, most of my internal walls, are stud walls.
JohnMo Posted April 15, 2025 Posted April 15, 2025 This is best photo I could find on how I did it. Top and bottom plate joined with studs. Nothing interfering with ICF.
Conor Posted April 15, 2025 Posted April 15, 2025 For the walls where we didn't put in steel mesh ties before the pour, I cut back the inner insulation and used galvanised L brackets approx 150x150mm at every other course. I'll put up with a minor cold bridge with 175mm insulation on the outside, losing a strip of 75mm in the inside is preferable to a wall falling down. 2 1
LaChab Posted April 15, 2025 Posted April 15, 2025 FWIW, our SE approved using starter bars (frame) screwed through to the core. Wouldn't dream of cutting back the inner insulation! 1 1
Nickfromwales Posted April 15, 2025 Posted April 15, 2025 Time to discover timber methinks, all you masonry addicts! Even load-bearing walls can be done well in timber….. why make life any harder than it already is? 😑😌
ChrisJ Posted April 16, 2025 Posted April 16, 2025 Using Nicks comment for wood, Use an SDS drill, drill thru the stud, foam and into the concrete, epoxy/resin threaded rod in, every 600-750 starting just above the floor will be fine, once cured, square washer and a nut, snug it up add 11mm OSB typically one side is enough nail every 50-75mm on the perimeter of the sheet and 150 in the field
JohnMo Posted April 16, 2025 Posted April 16, 2025 2 minutes ago, ChrisJ said: Using Nicks comment for wood, Use an SDS drill, drill thru the stud, foam and into the concrete, epoxy/resin threaded rod in, every 600-750 starting just above the floor will be fine, once cured, square washer and a nut, snug it up add 11mm OSB typically one side is enough nail every 50-75mm on the perimeter of the sheet and 150 in the field Why does anything need to attach to ICF?
ChrisJ Posted April 16, 2025 Posted April 16, 2025 On 16/04/2025 at 13:59, JohnMo said: Why does anything need to attach to ICF? It’s needed for sheer purposes, plus to prevent cracking in the corner of the plasterboard
JohnMo Posted April 16, 2025 Posted April 16, 2025 On 16/04/2025 at 14:02, ChrisJ said: It’s needed for sheer purposes, plus to prevent cracking in the corner of the plasterboard We have had zero corner cracks in any wall and they were built in 2021 - not a single crack ever. Just dry lined. Not a single wall (structural and non - structural) is attached to ICF. All internal walls are stud walls. Tallest is 3.5m. walls are just attached to other internal walls and top and bottom plates, as photo above.
metalgear2k2 Posted April 17, 2025 Author Posted April 17, 2025 Thanks all for the info, really appreciate it.
ChrisJ Posted April 17, 2025 Posted April 17, 2025 On 16/04/2025 at 14:52, JohnMo said: We have had zero corner cracks in any wall and they were built in 2021 - not a single crack ever. Just dry lined. Not a single wall (structural and non - structural) is attached to ICF. All internal walls are stud walls. Tallest is 3.5m. walls are just attached to other internal walls and top and bottom plates, as photo above. Awesome, sometimes you get lucky with the correct moisture content in the wood and never get a crack
JohnMo Posted April 17, 2025 Posted April 17, 2025 1 minute ago, ChrisJ said: get lucky Not sure I got lucky, several different batches of timber used. All walls are solid, none attached to ICF.
Iceverge Posted April 17, 2025 Posted April 17, 2025 (edited) What was the benefits of standing the studs off the walls? Services? Edited April 17, 2025 by Iceverge
JohnMo Posted April 17, 2025 Posted April 17, 2025 58 minutes ago, Iceverge said: What was the benefits of standing the studs off the walls? Services? For me less holes in the parge coat. Maybe less noise transfer, I inserted same insulation as between the studs. My electrical services all ran around the top of wall, so nice easy runs for electrician.
metalgear2k2 Posted May 1, 2025 Author Posted May 1, 2025 Good evening all, went with the wall starter kits as suggested, they worked a treat thanks. 2 1
Nick Laslett Posted May 2, 2025 Posted May 2, 2025 @metalgear2k2, thank you for posting a follow-up on the discussion. 1
