More pages , more content , more fun .
Like a Netflix series with too many episodes only to get to a drab finale . Suspense and wonder are the key !
Just back from a trip to a very wet place in Bonnie Scotland.
Talking to a home owner with an external, windward wall - completely covered in pitch. The covering was so old, it had a fine patina of whitish dust on it
(sand grains from the nearby dunes ?)
"Why's that then?"
"Eh Jimmie, hov' ya seen how mooch it rains here, eh ?"
And I thought of you.
Episode 19 - “ that muvver fecker “
Story recap :
After witnessing extreme violence and scenes of a sexual nature Pocster decides to take matters into his own hands . The mistress threatens to announce their relationship to the world - causing tension .
Pocster concludes the only way is forwards towards his inevitable fate ….
Rotten tomatoes rating : 99%
Average journalist rating : 2%
Isolated further - and made it leak …
That gate post asphalt needs a closer look once I get the Ali decking supports up
The latest suspect ; these seams .
Too wet inside to retest . Tomorrow is rain and storms so no good either . Have expanding foam so will build a little perimeter barrier around this area then fill it up .
Well son, looking at those photos, I reckon you've done well to have just a small leak.
A small impudent watery area.
A leaklet .
A UsedToBeDry.
A damp bit.
A damp Brizzle.
Ermmm, while your on here mate , ermmmm   .... how old's the felt?
Just askin' for a friend..... cos you might want to be ..... nah, can't say it...... leave it to @Onoff or someone like him - someone credible....
A leaklet .
A UsedToBeDry.
A damp bit.
A damp Brizzle.
4 yrs ish . I was told the felt isn’t the waterproof layer …
I suspect those gaps in the felt have always been there as it’s always leaked !
SBS-modified bitumen - self healing ; the felt as I was told was not needed but added to ‘physical ‘ damage to protect the underlying layer . I guess there’s a poor joint around this gate post .
Edited by Pocster
I reckons the "solution" is something like this...
Screenshot_20250611-173015.FilesbyGoogle.thumb.png.2b918ed01d9857f9cba395089c66dbd7.png
Maybe . But assuming it’s those seams just a load of ct1 in there should do it yeah bro ?
Dry day . So built my perimeter .
leave it a few hours then will test the outside edge to check water tight . If so will fill that little pond of mine .
Hmmmm . 30 mins . I top it up as it drops . But my perimeter probably isn’t 100% waterproof . Inside is damp from previous rain - but no droplets of water …. 🫤
Edited by Pocster
I guess next is to foam isolate from the existing foam down towards this front bit and make another dam
Foam expanded over the seam I want to test 🙄
Rain soon - foam will be cured by then but no good testing
Bastards about to drip !!!
So it’s one ( or both ! ) of these points .
It would seem static water is an issue - leaks much slower than moving water ??
So those 2 extra foam perimeters still curing are probably obsolete- but I’ll leave them .
I need to foam isolate that front bit tomorrow so it doesn’t run over the block paving .
I’ll pick that one as my 1st test tomorrow ( assuming no rain ) . Going to persist with that one continually ….
Edited by Pocster
Making content
You've convinced me not to build and underground lair, but I'm afraid I can't offer any suggestions for resolving your issues.
Edited by -rick-
I understand, but you want to see the successful climax 😉
