Alan Ambrose Posted March 21, 2025 Posted March 21, 2025 That's it really. For the people with a lot of experience - what's the best quality go to manufacturer?
crispy_wafer Posted March 21, 2025 Posted March 21, 2025 had a mix of polypipe and floplast. no problems with either. I used weld-on 611 for solvent weld cement after having a string of poor results from using the gloop from screwfix. A tube of the lubricant from toolstation has proved invaluable too!
BadgerBodger Posted March 21, 2025 Posted March 21, 2025 Wavin-Osma and polypipe. Floplast seems to be the same quality. 1
Nick Laslett Posted March 21, 2025 Posted March 21, 2025 (edited) Wavin Osma for drains according to my groundworks people. Interior SVP/waste any of the acoustic products like Wavin AS, Marley dBlue or Geberit Silent. I can bring a piece of Wavin AS to next meet-up. Edited March 21, 2025 by Nick Laslett
Mike Posted March 21, 2025 Posted March 21, 2025 Hepworth SuperSleve (clay) below ground. No strong preference above ground.
Alan Ambrose Posted March 22, 2025 Author Posted March 22, 2025 @Mike That’s interesting. No problem getting a pressure test?
BadgerBodger Posted March 22, 2025 Posted March 22, 2025 54 minutes ago, Alan Ambrose said: @Mike That’s interesting. No problem getting a pressure test? vitreous clay is a premium drainage product. Never seen it on Resi and not oft used in anything but public developments in my experience. I’ve always used it in schools and hospitals. It’s resistant to chemical attack etc. so suitable for labs etc. in cases like that you’d have vulcathene above ground and clay below. Some clay products are designed for resistance to thermal shock and can take 100 degrees+ water which PE/PVC struggles with. It’s a bit of a mare to work with IMHO. Requires experienced labour to install well. Easily damaged, very heavy for 225 or above. Re air testing it’s the same as any drainage, installed well no problem. Sloppy install, guaranteed issues. I’ve always had the least issues passing an air test with cast iron!!
Mike Posted March 26, 2025 Posted March 26, 2025 (edited) On 22/03/2025 at 09:53, Alan Ambrose said: No problem getting a pressure test? No, none at all. I used it professionally (as a manager) many times, always specified it when I had the choice, and have always used it on my personal projects, without problems. And although the pipes are a bit more expensive than plastic, you save money on stone fill & spoil removal (you can often backfill with as-dug material). And if you're unlucky and your trenches fill with rain, it definitely won't float, as plastic can. On 22/03/2025 at 10:58, BadgerBodger said: It’s a bit of a mare to work with IMHO. I've only laid the 100mm personally and it's pretty easy. No problem to DIY single-handed if you're practically inclined, hire the recommended pipe cutter & follow the manufacturer's info. Edited March 26, 2025 by Mike 1
BadgerBodger Posted March 27, 2025 Posted March 27, 2025 19 hours ago, Mike said: I've only laid the 100mm personally and it's pretty easy. No problem to DIY single-handed if you're practically inclined, hire the recommended pipe cutter & follow the manufacturer's info. In fairness I’m inclined to agree with you on the 100mm stuff. It’s heavy and cumbersome but solid. It’s the larger bore stuff I have had a lot of issues with damages.
