Stephen Crowe Posted March 16, 2025 Author Posted March 16, 2025 On 14/03/2025 at 19:27, Mr Punter said: As per my previous advice, if the Local Authority don't think it is an issue you will need to take your neighbour to court. If the neighbour's house is oriented at 90 degrees to yours the fence looks like it is protecting the amenity of their rear garden. Either way, this does not look like it stops you safely entering and leaving your driveway. I would just drop it and move on. Kent highways did a safety report and told Sevenoaks Planning that both a vehicular and pedestrian splay must be a ‘condition’ of any approval. KCC also stated that they would not give approval unless both splays complied with the regulations and gave references with drawings. Sevenoaks decided that they knew better, ignoring the regulations they passed the application with the serious safety issues and then lied stating that KCC had no objections. The case went to the Ombudsman and SDC were found guilty of the violation and injustice to me. Unfortunately Sevenoaks doesn’t give a s##t and refuse point blank to change anything. KCC are on my side but apparently have no power over SDC even though they are the Highway engineers. I have the emails both post & Pre approval from KCC to Sevenoaks stating that the Pedestrian Splay must be added but SDC instead have just blocked all communication from me stating that I am obsessed and wasting their time. It’s their fault, they have been found guilty, all the evidence of their incompetence has been submitted and yet I am the one that has to suffer.
Mr Punter Posted March 17, 2025 Posted March 17, 2025 On 16/03/2025 at 07:43, Stephen Crowe said: KCC are on my side but apparently have no power over SDC There you go. There is nothing you can do via the council. On 16/03/2025 at 07:43, Stephen Crowe said: SDC were found guilty of the violation and injustice to me I very much doubt if that was how it was phrased. I am not sure why you have got so wound up about this, but I suggest you either take your neighbour to court or drop the matter. 1
ToughButterCup Posted March 17, 2025 Posted March 17, 2025 On 12/03/2025 at 09:29, Stephen Crowe said: ... The question is: Do I have a legal right to demand a Pedestrian Visibility Splay? ... If you have, what's the point of demanding one? Annoyance drips from almost every sentence of your post. A couple of years worth of annoyance. May I suggest you ask yourself why - after all that time - you haven't worked out how to let the annoyance go. 1
ProDave Posted March 17, 2025 Posted March 17, 2025 IF you do somehow think you managed to prove the fence was actually on your land, what do you think the outcome would be? I think the outcome would be the fence would move over 6 inches so it was not on your land and be just the same fence just as tall causing just as much of an issue, except you would be £££ lighter and some lawyers would be £££ richer. and your neighbour would dislike you even more. 1
Stephen Crowe Posted September 12, 2025 Author Posted September 12, 2025 On 12/03/2025 at 10:07, Big Jimbo said: Only a guess, but I thought that the final 1m before the pavement could be no higher than 600mm from ground level ? Your neighbours fence does not go all the way out to the pavement. Is that setback a meter ? I think it is just a case of creeping out slowly when exiting your front garden, to give any body on the pavement the chance to see you. not ideal, but your neighbours obviously want privacy in there front garden. I'm not sure what you are expecting ? Removal of the fence that appears to be entirely on there own land ? The fence adjacent to my driveway is actually trespassing and on my land. The set back for the vehicular splay is only 600mm, there was supposed to be a 2m x 2m Pedestrian splay but the Council decided to ignore the regulations which should have been a 'Condition' of the planning. Council found guilty of 'error' but refused to enforce putting the general public at risk.
Big Jimbo Posted September 12, 2025 Posted September 12, 2025 I thought you would have got over this issue by now.
Alan Ambrose Posted September 12, 2025 Posted September 12, 2025 Here’s a new detail: land registry plans are only approximate and cannot be relied on - see the Land Registry website for more info.
