19 minutes ago, Nickfromwales said:
Did you install any below grade?
No, mainly because at time of design I didn't realise you could. Plus I didn't order enough to do it as a change.
A guy down the road did his with Durisol below dpc, full filled with concrete. He even did all the internal walls with Durisol.
Ok, thanks.
Do they stipulate waterproof concrete below DPC like Nudura did with us?
Didn't see anything, so presume nothing
On 01/03/2025 at 19:33, Iceverge said:
Something like.
Tiles
Tile battens
Counter battens
Breather membrane
11mm OSB
350 mm I joists with Cellulose.
Membrane
20*70mm battened service cavity
Plasterboard
Skim.
U value about 0.11.
Would it be an option to use rockwool slabs between the I joists if we couldn't do the blown cellulose. Looking at thermal values they look very similar.
No idea on cost comparison though so, any info on that would be helpful.
Cellulose is dearer than Rockwool but that includes fitting. About €150/m3 plus VAT near me. Not sure of UK prices.
There's a notable difference between the cheap mineral wool "loft roll" and higher density batts like Rockwool so ensure you're comparing like for like.
Cellulose has the advantage that it really helps the airtighess too when it's properly installed..
Thanks Iceverge, food for thought then.
I used a product called knauf omni fit.
far nicer to handle than rockwool if installed from underneath.
Edited by Russell griffiths
Yup, they create closed "boxes" which is easier to get a good densepack of the cellulose.
There's the square root of zero thermal bridging through the OSB webs of an I joist. I would counter batten underneath for a service cavity though.
Something like.
Tiles
Tile battens
Counter battens
Breather membrane
11mm OSB
Membrane
Plasterboard
Skim.
U value about 0.11.
Alternatively
Tiles
Tile battens
Counter battens
Breather membrane
11mm OSB
220mm sawn joists with Cellulose.
Membrane
95*45 mm battened service cavity with mineral wool or cellulose
Plasterboard
Skim.
U value about 0.14 but all off the shelf material from your local merchant and lots cheaper to boot.
We've hit a bit of a stumbling block with this!
SE has suggested we will likely need a supported ridge beam (span is 14m) to do the I beam detail, prob is our layout on 3rd floor doesn't have any walls directly above the 1st/2nd floor walls so question then is how to provide ridge support.
We also have a rear section of the house to tie in (L shaped design) so wondering how/can that work with I beams 🤔
Anyone know if I beams can be made into an attic truss and be 'self' supporting?
Add some walls, move some rooms about, on levels 1&2 or level 3?
Really trying to avoid that option, will have to be a compromise somewhere, just trying to find the best one!
Are you saying you have a clear span upstairs of 14m without any internal walls, that’s a big area.
The total span is 14m, we do have internal walls but the walls on the 3rd floor aren't above any supporting walls below.
Your roof will obviously be supported by a wall plate on the external walls and internally the valley rafters and ridges.  ( I like gluelam beams, please use gluelams cause dey so pretty 😍.
Hang all the normal rafters from these .
Effectively you need a path to transfer the load vertically The external walls are easy peazy.  The ridges and valleys (red) you just need to able to draw vertical lines to get the load down. I've made blue dots where I think this could happen.
IMG_20250321_210519.thumb.jpg.80e73fb33e16b9339dc817672441e163.jpgIMG_20250321_210205.thumb.jpg.87548ca54c2d509378cd10a2f97a8439.jpgIMG_20250321_210339.thumb.jpg.e6b8f2294f6d48c01cd41a622f056852.jpg
You may need to add a lintel over an internal door but it's not rocket science.
DISCLAIMER. I'm not a structural engineer any roof collapsing and tumbling on your bed at 3am instantly pulverising you and your beloved is absolutely someone else's fault .
  • Haha 2
Playing with the AI (as I do a Saturday evening.
A glulam beam 100x320mm should be ok to cover the longest ridge span of 6.7m. A 14m long one for the longest ridge would be about £700-£800.  And weight about 200kg.
A similar RSJ would be £1000 and weight 3 times as much and have awful thermal bridging and onsite workability charactistics in comparison. However it might be able to be bolted together easier.
225x47mm timber should be fine for the rafters. or you can play with different rafter and service cavities sizes etc . This is a low cost high performance option that i like. You could do a plain I joist with a 22mm uninsulated service cavity too, More material cost but cheaper labour.
Or
Thankyou 😊  lots of time spent there so really appreciate that.
Re the load transfer, the 3rd floor walls around the landing don't sit directly above the 1st floor walls so, is there an issue there transferring  the load down?
Also, would we need all those internal walls to be solid, load bearing walls? Currently we were intending to do studs on 1st Floor (except stair wall)
On 18/03/2025 at 20:30, Nickfromwales said:
Apex would go up with roof timbers to ridge and back down again, profiled to be within the same footprint as the timber.
That's certainly worth thinking about, what would the cold bridging issues be though?
I'm wondering if we could add a steel at first floor ceiling that we could take a post up from to support the ridge, do you think that's a viable option?
Edited by lizzieuk1
Altered diagram
  • 1 month later...
Something like.
Tiles
Tile battens
Counter battens
Breather membrane
11mm OSB
Membrane
Plasterboard
Skim.
U value about 0.11.
Alternatively
Tiles
Tile battens
Counter battens
Breather membrane
11mm OSB
Membrane
Plasterboard
Skim.
I'm struggling with the i joists, again!
SE happy to sort a steel ridge detail but, he can't design the roof for us. So where do I go for that? Who can I ask to design it?
Lots of truss manufacturers will do with trusses & one I found will do posi but not sure who to as for the I beam design! Any ideas?
Why I beam?
MVHR ducts can run in the insulated void of a posi joist, which is very handy for losing those for vaulted ceilings :)
1 hour ago, Nickfromwales said:
Why I beam?
We will have plenty of options for the mvhr etc in the eaves void either way though. Both will need the ridge steels and I'm wanting to compare costs. So far from 1 posi supplier the roof will be around 12k 😬
You could try Cullen Timer Design, but not sure if they'll be cost effective for just the roof. Typically they Design/Engineer the whole frame.
