Apologies about another "who shall  I contact?) posting. Again, I just don't want to miss out on any obvious suppliers/merchants out there and as insulation is one of may main cost areas, I'm looking to get the best price I can....obviously.
I'm looking to get a mix of EPS and PIR for under slab and slabs for in between rafters ("frametherm").
I've tried some merchants that people here have suggested before on ebuild including the following:
  • Minster
  • Encon
  • SIG
  • Ecclestone & Hart
And a host of local merchants and online-only outlets (Less2build, InsulationGiant, Insulation Express). so far, some are double the cost!!!
Any obvious ones worth trying please?
Again, I'll post my results on here for future readers to try too!
Thanks.
I use FGF in Birmingham for my insulation, fermacell and external cladding boards. Great prices though delivery can take a while. I found web shops to be a lot more expensive.
Was this 10mm & 12.5mm fermacell..? What sort of quantities..?
10mm, I purchased 2 pallets so far with another 2 or 3 to go. Based on room heights, I ordered 2500x1200 boards to minimise cutting and wastage, 60 to the pallet.
Aylesbury, Bucks. I decided to use 12.5 plasterboard for ceilings and fermacell on walls only - focus attention where the problem is - I dislike plasterboard for walls e.g. hanging anything up becomes a big job with an uncertain outcome.
