Temp Posted March 19, 2025 Posted March 19, 2025 We had an IBC on our allotment, it had a metal frame but I doubt I could be buried. The plastic part was more flexible than a watering can.
saveasteading Posted March 19, 2025 Posted March 19, 2025 3 hours ago, mads said: the sustainability aspect of it and reducing the need for potable water OK. So I specified a rwh for our own office development. Try it on yourself principle before recommending to a client. I forecast a 10 to 13 year return on capital. There were about 30 occupants, us and tenants which is rather different to a house. It paid itself in 4 years, because I hadn't thought about the sewage saving ( sewage quantity is based on water supplied). BUT I haven't included electric supply to the pump, or a replacement pump or future maintenance. Also, the duplicated pipework cost was a guess. Sustainability? How much carbon in manufacture, construction and operation? Hence my logic that you don't do it for a house not connected to the sewer.
Simon R Posted March 20, 2025 Posted March 20, 2025 On 19/03/2025 at 04:41, mads said: I'm interested what the Kingspan control system was meant to do? And if the new pump covers it all? The Kingspan system has a display showing tank level and options to customise auto fill from mains water. As I mentioned the pump had failed before first use and Kingspan wanted silly money just to send someone out. Our system now is very simple. A Divertron pump which switches on when it senses a pressure change in the system ie switching on a tap. No header tank. I also bought a cheap radio tank sensor which displays tank depth. In practice it’s pretty irrelevant and the tank has never run dry. 3
saveasteading Posted March 20, 2025 Posted March 20, 2025 3 hours ago, Simon R said: the tank has never run dry. That is important with long dry summers becoming more the norm. Excuse me if you've said already, but what capacity? was changing the pump very technical? ie is there justification for a specialist?
mads Posted March 21, 2025 Posted March 21, 2025 (edited) I decided to create my own calculator on how much I could save on water by RWH. Here is the calc (I included a waste water section though not applicable for me). Happy to upload the file for others to use for themselves, if helpful. I have only done it from a water consumption and waste water perspective. I have not factored in electricity costs (as I personally feel this is negligible and most of us will have PV) but have included replacement pump costs. Edited March 21, 2025 by mads 1
mads Posted March 21, 2025 Posted March 21, 2025 17 hours ago, saveasteading said: That is important with long dry summers becoming more the norm. Excuse me if you've said already, but what capacity? was changing the pump very technical? ie is there justification for a specialist? Kingspan Klagster 4,600ltr system was mentioned. Re: long dry summers, I think this is where making sure you have a high volume tank is important so can store more during the shoulder months when we do have rain.
saveasteading Posted March 21, 2025 Posted March 21, 2025 Nice to see your calls. From a quick skim. The garden usage looks high. A) perhaps showing a falsely high cost/ potential cost.. b) you would empty the tank in 3 weeks of no rain. Water cost sqm should be cm ? Does waste cost belong here as a cost? You could show the saving due to lower purchase volume perhaps.
mads Posted March 21, 2025 Posted March 21, 2025 (edited) 22 minutes ago, saveasteading said: Nice to see your calls. From a quick skim. The garden usage looks high. A) perhaps showing a falsely high cost/ potential cost.. b) you would empty the tank in 3 weeks of no rain. Water cost sqm should be cm ? Does waste cost belong here as a cost? You could show the saving due to lower purchase volume perhaps. Garden is 1 acre which will be 0.4 acre lawn, 6-8 sqm vegetable patch, medium to large greenhouse and 6m diameter pond to keep topped up, plus plants and hedging so expect fairly high use - in-laws are avid gardeners too. When I sent my request to suppliers, they came back saying I need a 5,000L tank but to be on safe side for droughts then consider a 7,500L one. I was going to get a 10,000L as I also have outbuilding roofs which I haven't factored into the water capture calc. Water cost is actually m3 - had the wrong units described and have corrected in my file. Doesn't change the calcs. Waste cost doesn't apply to me so I would zero it out. I included it in case I share this with anyone and they may need to use it due to connection to mains sewerage. For me, the ROI is around 30-40 years so one to think about in terms of capital cost outlay. Was useful to do the exercise and hope it helps others. I had to do a few iterations to get to a point where the ROI time frame balanced out. The replacement pump cost drove it up and I would look to see if 3 years is too frequent. Edited March 21, 2025 by mads 1
saveasteading Posted March 21, 2025 Posted March 21, 2025 In my office example above the calculations said use 5m3. I went for 10 which I think was right as it never ran dry. Negligible garden use. I think the ROI on the extra 5m3 would have been very short as it was only the extra tank cost...about £1k? Well done on the exercise.
mads Posted March 21, 2025 Posted March 21, 2025 2 hours ago, saveasteading said: In my office example above the calculations said use 5m3. I went for 10 which I think was right as it never ran dry. Negligible garden use. I think the ROI on the extra 5m3 would have been very short as it was only the extra tank cost...about £1k? Well done on the exercise. Thanks. Though I have to say that my exercise presumes the costs stay the same for the entirety. We know that the cost of water supply is going up, with numbers of around 36% over the next 5 years. If I assumed a 3% YOY increase to the fresh water price, that goes up to 360 pence per m3 in 10 years. At that cost, it could shave off around 8-9 years from a ROI timeline. I need to do some financial modelling to see what this might look like over a 10-15 year horizon as I suspect it will be different to the static view I have started with.
SteamyTea Posted March 21, 2025 Posted March 21, 2025 1 hour ago, mads said: We know that the cost of water supply is going up, Base the price on South West Water. Have I ever mentioned that we have the most expensive water and waste in the country, which probably makes it one of the most expensive in the world.
mads Posted March 21, 2025 Posted March 21, 2025 4 minutes ago, SteamyTea said: Base the price on South West Water. Have I ever mentioned that we have the most expensive water and waste in the country, which probably makes it one of the most expensive in the world. £348 for the year vs £304 for ST Water on a like-for-like
mads Posted March 21, 2025 Posted March 21, 2025 So some modelling shows... Over 10 years, based on a 5% YOY price increase (I think this is too low imo), the fresh water supply cost for my scenario would be: 2025/26: £304.56 per annum 2034/35: £472.47 per annum The total over the 10 years would be £3,830.72 vs £3,045.60 if the costs were to remain static. Looking at just today with the current costs, the ROI timeframe is 26.6 years Looking over a 10 year horizon with the above increases, the ROI timeframe reduces to 21.1 years Over a 20 year horizon with still a 5% YOY increase, the ROI timeframe reduces to 17.3 years
AartWessels Posted March 21, 2025 Posted March 21, 2025 I moved here from Belgium, where rain water harvesting is mandatory. We had a 5000L tank installed. Water costs around £2.20/m3 there. We used rain water for laundry, toilets and the garden. There is however absolutely no way to get an ROI, or at least not in Belgium. A major part of summer, the tank will run dry. In the wet periods, it will be full, and therefore the rain water will overflow to a drain. So the theoretical volume of rainfall can not be used, as it cannot be harvested in practice, and part of the year you will have to fill the tank from mains water to keep toilets and laundry running. Anyway, that's just my practical experience. 1
mads Posted March 21, 2025 Posted March 21, 2025 9 minutes ago, AartWessels said: I moved here from Belgium, where rain water harvesting is mandatory. We had a 5000L tank installed. Water costs around £2.20/m3 there. We used rain water for laundry, toilets and the garden. There is however absolutely no way to get an ROI, or at least not in Belgium. A major part of summer, the tank will run dry. In the wet periods, it will be full, and therefore the rain water will overflow to a drain. So the theoretical volume of rainfall can not be used, as it cannot be harvested in practice, and part of the year you will have to fill the tank from mains water to keep toilets and laundry running. Anyway, that's just my practical experience. Thanks for sharing. I'm interested as to why they then mandate it? And could it be different if the tank size was doubled?
SteamyTea Posted March 21, 2025 Posted March 21, 2025 15 minutes ago, mads said: I'm interested as to why they then mandate it? Probably as a general water management policy, similar to our SUDS. That raises an interesting point, if SUDS has to be employed, can a rainwater harvesting system replace it.
AartWessels Posted March 21, 2025 Posted March 21, 2025 2 hours ago, mads said: Thanks for sharing. I'm interested as to why they then mandate it? And could it be different if the tank size was doubled? It's mandated to prevent water problems. Prevent a bit of flooding, etc. And then 'sustainability'. I don't think it's hitting either of these targets. Doubling the tank size depends on the size of your roof. Still, watering the garden in summer will suck it dry in 2 weeks.
AartWessels Posted March 21, 2025 Posted March 21, 2025 2 hours ago, SteamyTea said: Probably as a general water management policy, similar to our SUDS. That raises an interesting point, if SUDS has to be employed, can a rainwater harvesting system replace it. Maybe. I'm not against storing rainwater, I just think using it in a house is not a case with an ROI. In our new build we'll store it in a wildlife pond.
saveasteading Posted March 21, 2025 Posted March 21, 2025 6 hours ago, mads said: presumes the costs stay the same for the entirety. That's pretty standard. You are laying out funds that could otherwise earn interest. 2 hours ago, AartWessels said: Doubling the tank size depends on the size of your roof. It also depends on catching all the rain in any storm. So for a dual pitched roof there may be more drains and deeper runs. 4 hours ago, SteamyTea said: if SUDS has to be employed, can a rainwater harvesting system replace it. Yes, or part of the proposal at least. But anything differing from the accepted hierarchy can be difficult for a planner to accept, and you get into the need for an expert proposal. I showed planners why a harvester was better than a green roof, for example, which surprised them. 1
AartWessels Posted March 22, 2025 Posted March 22, 2025 8 hours ago, saveasteading said: It also depends on catching all the rain in any storm. So for a dual pitched roof there may be more drains and deeper runs. Although I agree that is factually true, I don't think in real.life it matters that much. With that, I mean, there are so many factors in the actual environmental conditions,that you can't accommodate for all of them, not even when designing. KISS. An oversized track will hardly ever fill completely, so the tank must fit to the roof surface. Only water from the roof areas should go in. Keep your gutters clean. That has a very big impact. Clean the inflow filter regularly. Again. A big impact. In a big storm, you won't catch it all. Many reasons why not, but mostly because the time of year these usually come (the wet time), when your tanks are filled already anyway. Now, if you don't intend to use it for the house, but just for the garden, allotments, greenhouse, etc., the story changes. Using a catchment basin, IBC containers, etc. change the ROI dramatically I'd say. 1
saveasteading Posted March 22, 2025 Posted March 22, 2025 46 minutes ago, AartWessels said: change the ROI dramatically I'd say. The cheapest rwh I ever installed was a series of IBCs. 4m3 for £400 plus some plumbing. It was only for buckets of water for slunging vehicles OR could be set to dribble to slow down flow to drains and ground. Not pretty but the client loved the value. 1
AartWessels Posted March 22, 2025 Posted March 22, 2025 6 minutes ago, saveasteading said: The cheapest rwh I ever installed was a series of IBCs. 4m3 for £400 plus some plumbing. It was only for buckets of water for slunging vehicles OR could be set to dribble to slow down flow to drains and ground. Not pretty but the client loved the value. That's it. Works wonders in a rural environment, and an ROI of around 10 years if you included a pump, or less than 7 years if you don't. And maybe even less if it is in a location without any existing infrastructure.
Simon R Posted March 22, 2025 Posted March 22, 2025 On 20/03/2025 at 22:08, saveasteading said: but what capacity? Our tank was is 4600ltrs. Just the two of us and a small garden. Lots of washing though as we’re both sporty.
Stu789 Posted March 28 Posted March 28 Does anyone have experience of direct feed rainwater harvesting systems (no attic tank) with automatic plant watering systems & also using a pressure vessel to reduce pump cycling? The hydroforce pump manual has a note: "Pressure-sensitive pumps are unsuitable for use with low flow applications such as drip feed irrigation systems. To be used on such a system a pressure vessel must be installed and charged to 2.1 bar (30 psi)." Planning on using the small tube plant watering on timer for raised flower beds (not the constant drip feed style) so might not be an issue but it also occurred to me that a pressure vessel ~10-15 litres could significantly reduce pump cycling (would get a couple of toilet flushes before the pump kicks back in and then runs for longer).
marmic Posted March 28 Posted March 28 no idea about plant watering but we have sucessfully installed 15000litre underground potable tank with pump controlled by pressure switch/pressure tank. filters before tank. Once in house water goes through 3 stage filter then UV - feeds into hot water tank (set at 55° - which as far as i know will kill anything) /hot taps/shower and cold taps/washing machine/dishwasher/toilet cistern. Water not completely clear with tanins still present but not bad at all. Think this will improve however over time as found about 6 weeks ago groundworker was incapable of following clear instructions regarding tank overflow - I've done a temporary fix - another job on list for summer! Once we have built kitchen we'll have reverse osmosis supply to kitchen sink and bathroom basin. Once all in we'll get RO sample tested (and UV only for interest). I'll be astonished if any issues but better to be safe before drinking. If calcs right reckon a full tank will last at least 50 days without rain. Might add another tank for additional storage and/or a connection (dryer season only) from a second roof not currently utilised, and we do have back up supply if really needed. I found the numerous 'uk rainwater harvesting companies' pretty useless and arrogant - most are just ticking boxes / playing at it imo. and found lots of info on Australian/US sites - they are way ahead - and worked out for myself along with significant assistance from pumpexpress.co.uk who suggested schemes and products - which we bought from them. definitely worth talking to. The potable tank from elsewhere - shop around and be careful. 3
