ClairedM Posted January 23 Posted January 23 So. I'm still in the middle of the fitted by crap fitters and surveyed wrong crap with Internorm and Ecotec. I love the products of Internorm BUT their customer care is abysmal. (Surveyed and fitted by Ecotec - all condemned by building standards as wrong size/fitting/wonky. Internorm proposed a bodge job.) I'm hoping to find an other company that has similar spec windows/doors. And in a heaven world, a fitting company that can both repair the damage to my home and survey/fit accurately. I've looked at Nordan and Origin. Origin has much higher U values. Nordan seems to be either Cardiff or Scotland. I live in Sheffield. South Yorkshire.
Thorfun Posted January 23 Posted January 23 we had a great experience with Norrsken (and still are some 2 years after installation). lovely windows and installation managed by them too so all under one roof.
Nickfromwales Posted January 23 Posted January 23 6 minutes ago, ClairedM said: So. I'm still in the middle of the fitted by crap fitters and surveyed wrong crap with Internorm and Ecotec. I love the products of Internorm BUT their customer care is abysmal. (Surveyed and fitted by Ecotec - all condemned by building standards as wrong size/fitting/wonky. Internorm proposed a bodge job.) I'm hoping to find an other company that has similar spec windows/doors. And in a heaven world, a fitting company that can both repair the damage to my home and survey/fit accurately. I've looked at Nordan and Origin. Origin has much higher U values. Nordan seems to be either Cardiff or Scotland. I live in Sheffield. South Yorkshire. Can you clarify, are you needing a fitter to remove all the already installed units and then install the replacements (and for the new team to first of all survey and place an order for the replacements)? Please give as much detail as you can 1
MikeSharp01 Posted January 23 Posted January 23 18 minutes ago, Thorfun said: we had a great experience with Norrsken (and still are some 2 years after installation). lovely windows and installation managed by them too so all under one roof. +1 for Norrsken here, great job and great service. 1
MikeGrahamT21 Posted January 23 Posted January 23 I'm pleased with my windows from Modern UPVC Windows, but I self installed. They do provide installation now however: https://www.modernupvcwindows.co.uk/ 1
craig Posted January 23 Posted January 23 1 hour ago, Nickfromwales said: @craig about these days? Yip, just flat out at the moment. I can recommend an installation team but for a refurbishment they will be travelling, with overnight accommodation etc. being required. I can recommend teams for new builds easily but most are not wanting to touch refurbishments these days. 1
Nickfromwales Posted January 23 Posted January 23 19 minutes ago, craig said: Yip, just flat out at the moment. I can recommend an installation team but for a refurbishment they will be travelling, with overnight accommodation etc. being required. I can recommend teams for new builds easily but most are not wanting to touch refurbishments these days. 2 hours ago, ClairedM said: I'm hoping to find an other company that has similar spec windows/doors. And in a heaven world, a fitting company that can both repair the damage to my home and survey/fit accurately. @craig may be able to help with some names etc? He's a BH 'trusted member'
craig Posted January 23 Posted January 23 (edited) 31 minutes ago, Nickfromwales said: @craig may be able to help with some names etc? He's a BH 'trusted member' Installer wise, give Dynafit a call. Edited January 23 by craig
ClairedM Posted January 23 Author Posted January 23 3 hours ago, Nickfromwales said: Can you clarify, are you needing a fitter to remove all the already installed units and then install the replacements (and for the new team to first of all survey and place an order for the replacements)? Please give as much detail as you can 1. currently Internorm windows/doors to be removed. 2. Damage be repaired. 3. New windows/doors put in. 1
ClairedM Posted January 23 Author Posted January 23 5 minutes ago, craig said: Installer wise, give Dynafit a call. Ok. Thank you. I see from the internet that you're based in Fife and it would be quite a trek for your team for a reasonably small job.
ClairedM Posted January 23 Author Posted January 23 2 hours ago, MikeGrahamT21 said: I'm pleased with my windows from Modern UPVC Windows, but I self installed. They do provide installation now however: https://www.modernupvcwindows.co.uk/ 2 hours ago, MikeSharp01 said: +1 for Norrsken here, great job and great service. Thank you.
craig Posted January 23 Posted January 23 It would be but dependant on the quantity and time to do the work, it might be feasible (probably not to be honest but there's no harm in checking).
ClairedM Posted January 23 Author Posted January 23 5 minutes ago, ClairedM said: 1. Survey for new winnows/doors, and look/quote to repair damage done to external envelop of house, and inside. 2. current Internorm windows/doors to be removed. 3. Damage from previous install be repaired. (I think this will need to be done before the new windows are put in.) 4. New windows/doors put in to the correct size and placement.
HughF Posted January 23 Posted January 23 4 hours ago, MikeGrahamT21 said: I'm pleased with my windows from Modern UPVC Windows, but I self installed. They do provide installation now however: https://www.modernupvcwindows.co.uk/ My go-to supplier for plastic these days, but I think OP wants something more fancy (european style PH windows) 1
ClairedM Posted January 23 Author Posted January 23 1 hour ago, HughF said: My go-to supplier for plastic these days, but I think OP wants something more fancy (european style PH windows) I am!
Nickfromwales Posted January 23 Posted January 23 5 hours ago, ClairedM said: Ok. Thank you. I see from the internet that you're based in Fife and it would be quite a trek for your team for a reasonably small job. Respectfully, this doesn’t sound like a small job unless it’s 1x door and 2x windows? How many units in total need to be removed and replaced?
