Sunil237 Posted 20 hours ago Share Posted 20 hours ago Another problem! My builder was supposed to build with a 125 cavity and use 115mm ecotherm full file cavity insulation t&g leaving a 10mm gap... They have built to dpc and built all the block work but there's no 10mm gap once you place a brick on the dpc The 10mm gap is to prevent transfer of moisture but it's literally going to be touching the boards Is this an issue and can anyone provide an alternative insulation that would work? I really don't want to compromise the u value as I am going for a heat pump I need them to keep on track and start bricklaying tomorrow! He's only just told me this is going to be the case today Link to comment Share on other sites More sharing options...
Russell griffiths Posted 20 hours ago Share Posted 20 hours ago It’s about time you got rid of them. Link to comment Share on other sites More sharing options...
gravelrash Posted 20 hours ago Share Posted 20 hours ago is dpc at floor level? if so he could possibly overhang the inside or outside wall block 10mm all round (or 5mm on each) to gain back your cavity size. Link to comment Share on other sites More sharing options...
nod Posted 19 hours ago Share Posted 19 hours ago Your Architect is at fault Not the bricklayer 10 mil is not enough Even if the brickwork and blockwork is absolutely perfect 10 mil isn’t enough room 25 is tight but 50 is better Im surprised no one has pointed this out Link to comment Share on other sites More sharing options...
ADLIan Posted 19 hours ago Share Posted 19 hours ago Not really the architect’s fault. Fault lies more with the insulation manufacturer for developing a system that needs this level of dimensional tolerance. Link to comment Share on other sites More sharing options...
jayc89 Posted 19 hours ago Share Posted 19 hours ago Our Architect wanted to go 90mm Kooltherm in a 100mm cavity which I pushed back on. We ended up with a 150mm EPS full fill instead. Link to comment Share on other sites More sharing options...
