CemCet Posted Friday at 17:53 Author Posted Friday at 17:53 On 26/01/2025 at 12:44, G and J said: Of course after the event one thinks of the things one should have put. To make self building easier: allow suppliers to zero rate vat for supplies, not just when it’s supply and fit. That would help our cash flow a lot and I suspect we aren’t the only ones. Thanks for the input! Did you mention this in the survey? There is this question in the survey: "What would you change or improve about the self-build process in the UK?"
G and J Posted Friday at 18:05 Posted Friday at 18:05 11 minutes ago, CemCet said: Thanks for the input! Did you mention this in the survey? There is this question in the survey: "What would you change or improve about the self-build process in the UK?" Ummm, no. After the event I thought of the things I should have put.
CemCet Posted Saturday at 11:14 Author Posted Saturday at 11:14 On 29/01/2025 at 12:18, Bancroft said: Done. Would have been nice to have a final 'comments' box to input some personal thoughts on the process. I recognise that hundreds of complaints about planning departments might not help the core work but it could lead into other areas of study. Thank you for your input! Actually, I was thinking about that too. I thought including 'Other' boxes as one of the answer choices would be enough. I'll mention it to my supervisor and see if we can add it
Wuey Posted Monday at 17:59 Posted Monday at 17:59 I've just completed survey too - would be interested to hear more about your findings one you've completed your research. Also agree that an 'additional comments' could yield even greater insight/nuance within the self-build process
