low_and_there Posted January 17, 2025 Posted January 17, 2025 We've finally had our ASHP installed. Total nightmare, turned out the installers really did not know what they were doing with the heat loss calcs, nor tbh, much about heat pumps, despite being an 'MCS' outfit. But anyway, here we are. Due to the various sagas since install I've not actually noticed before that the ASHP unit outside pushes air out towards the garden, rather than against the wall, which is what I expected... I've drawn a diagram, attached, showing what I mean. I'm curious if this is to be expected and how other people have their heat pumps installed? Thanks in advance
Conor Posted January 17, 2025 Posted January 17, 2025 Thats correct. Draws air from behind, expels to the front.
low_and_there Posted January 17, 2025 Author Posted January 17, 2025 thanks both, at least they did that bit right
G and J Posted January 17, 2025 Posted January 17, 2025 Hmmm, we’re planning a similar installation. Is there much difference in the noise level between standing to the side of the unit and in front of the unit (i.e. with the airflow coming towards you)?
ProDave Posted January 17, 2025 Posted January 17, 2025 3 minutes ago, G and J said: Hmmm, we’re planning a similar installation. Is there much difference in the noise level between standing to the side of the unit and in front of the unit (i.e. with the airflow coming towards you)? The noise will obviously be more if standing in the air flow, and of course you will be blown by cold air. It is a theoretical question really. The ASHP won't be on doing heating when you are trying to sit in your garden, and if it happens to come on to heat the hot water while we are in the garden, I go and turn it off, the hot water can wait.
Chanmenie Posted January 17, 2025 Posted January 17, 2025 I have a 4KW Veismann ASHP and can’t hear it even when standing quite close, I actually need to look at the fan to see if it’s running
G and J Posted January 17, 2025 Posted January 17, 2025 5 minutes ago, ProDave said: The noise will obviously be more if standing in the air flow, and of course you will be blown by cold air. It is a theoretical question really. The ASHP won't be on doing heating when you are trying to sit in your garden, and if it happens to come on to heat the hot water while we are in the garden, I go and turn it off, the hot water can wait. Ours will, I hope, cool as well so it might be going when we are in the garden. 2 minutes ago, Chanmenie said: I have a 4KW Veismann ASHP and can’t hear it even when standing quite close, I actually need to look at the fan to see if it’s running Hmmmm, so if there’s little noise anyway then there can’t be much if a difference. So sitting in the garden when it’s running hopefully won’t be too bad.
sharpener Posted January 17, 2025 Posted January 17, 2025 12kW Vaillant is almost imperceptible from the side and not very noticeable from the front unless putting out 10kW or more which is rare. Sucks from back (only 200mm rear clearance, 250 if for cooling) and blows v cold air out from the front. Visitors (who have to walk past it) have remarked on the cold rather than the noise.
JohnMo Posted January 17, 2025 Posted January 17, 2025 2 minutes ago, G and J said: Hmmm, we’re planning a similar installation. Is there much difference in the noise level between standing to the side of the unit and in front of the unit (i.e. with the airflow coming towards you)? Yes - most the noise is pushed forward by the fan. You don't want to install with air pushing towards a wall. You get air recycling of cold air coming back round and that reduces CoP and changes the defrost onset temperature for the worse
kandgmitchell Posted January 17, 2025 Posted January 17, 2025 Our vaillant emits so little noise it's hard to know it's running. The way to tell is to walk past it - the cold air flow is very cold!
Michael_S Posted January 17, 2025 Posted January 17, 2025 4 hours ago, G and J said: Ours will, I hope, cool as well so it might be going when we are in the garden. Hmmmm, so if there’s little noise anyway then there can’t be much if a difference. So sitting in the garden when it’s running hopefully won’t be too bad. I was advised that air to water doesn't really work for cooling because you get condensation on the rads If the fa blew at the hose it would probably freeze the wall - when it is cold outside the heat pump puts out a majorly icy blast - or 'refreshing' as my teenage son puts it.
JohnMo Posted January 17, 2025 Posted January 17, 2025 18 minutes ago, Michael_S said: advised that air to water doesn't really work for cooling because you get condensation on the rads You need UFH or fan coils 1
