ToughButterCup Posted Monday at 16:15 Share Posted Monday at 16:15 Hmmm, .... only wearing a bathing costume all year round eh .... hmmm. It'll be they wee midges that irritate. 1 Link to comment Share on other sites More sharing options...
SteamyTea Posted Monday at 16:16 Share Posted Monday at 16:16 6 minutes ago, Kelvin said: theory is it’s the reason the sea water temperature is rising, all the women of a certain age going for a dook. Too true. And they all park badly. Link to comment Share on other sites More sharing options...
Jeremy Harris Posted Monday at 16:22 Author Share Posted Monday at 16:22 59 minutes ago, Kelvin said: The other day my wife asked what we’d do for showers if our system stopped working for some reason. I pointed to the newly plumbed in dog bath and electric shower. Has a handy shelf for sitting on and a door and step to get in. 😂 Thinking about it, it'd be easy to buy a lower flow shower head, perhaps a bit like the ones used for electric showers, to use if we had to resort to the backup hot water system. The shower head we use all the time has a flow rate of around 10.5 litres per minute (I only know this because an annoying building inspector wanted me to measure it, then insisted a flow reducer be fitted - removed as soon as the house was signed off . . . ). I could probably find one with a much lower flow rate, rather than fit a flow reducer, simply because the flow reducer really reduced the force from the jets. If I fitted, say, a head with an 8 litre/minute flow rate then we'd get close to 10 minutes of shower time, which is pretty close to normal daily use anyway. This means that a 50 litre heater may well be all we need. These Heatrae Sadia units look well enough made, stainless steel tank and immersion element, just a simple thermostat for control and all the connections at one end. Link to comment Share on other sites More sharing options...
Gone West Posted Monday at 16:22 Share Posted Monday at 16:22 (edited) 1 hour ago, Jeremy Harris said: The question is whether 50 litres of hot water is OK as an emergency supply. I think that looks like a good solution. I'm sure 50 litres of hot water is fine as an emergency supply, as 40 minutes recovery time is reasonable. Just read your last post. An aerating shower head would reduce the water use. Edited Monday at 16:25 by Gone West 1 Link to comment Share on other sites More sharing options...
Kelvin Posted Monday at 16:25 Share Posted Monday at 16:25 8 minutes ago, ToughButterCup said: Hmmm, .... only wearing a bathing costume all year round eh .... hmmm. It'll be they wee midges that irritate. We don’t get so many midges our side of the hills even by the Lochs Link to comment Share on other sites More sharing options...
Jeremy Harris Posted Monday at 17:25 Author Share Posted Monday at 17:25 I've ordered one of the 50L Heatrae Sadia horizontal water heaters, should be here at the end of the week. Nice that it comes complete with all the bits needed to install it, PRedV, accumulator, tundish, built-in T/PRV etc, although the PRedV is redundant, as I already have a 3 bar one on the supply, plus our well pump cannot exceed about 4.5 bar anyway, given the depth of our well. If anyone wants a 22mm PRedV they are welcome to it, as I already have one spare sat here. Plan is to fix a doubled up bit of 19mm marine ply to the wall above the door, secured with loads of hefty screws into the studs behind the plasterboard. Should be fine to then bolt the bracket to this, as the max weight when full is only a tad over 70kg. Nice thing about this water heater is that it isn't smart, something of a rarity now. Last thing I want for a standby, emergency hot water system, is something that is too damned clever for its own good. Quite why anyone would ever feel the need to have a WiFi connected and controlled hot water heater is beyond me. I just want something simple that will provide some hot water if things go awry. Last thing I need is to be faffing around with an app in order to just have a shower. 1 Link to comment Share on other sites More sharing options...
SteamyTea Posted Monday at 17:52 Share Posted Monday at 17:52 25 minutes ago, Jeremy Harris said: Quite why anyone would ever feel the need to have a WiFi connected and controlled hot water heater is beyond me It gives the impression that the customer has some control and can reduce their energy bills. I blame the marketing departments. (Metal Mickey was not at work today, so could not put the PCM under the lazer, hopefully he is in tomorrow) 1 Link to comment Share on other sites More sharing options...
SteamyTea Posted 9 hours ago Share Posted 9 hours ago Saw the metal man earlier. The first column is the element, second the percentage and third is the uncertainty. 1 1 Link to comment Share on other sites More sharing options...
