Hi All
I have got new upvc windows installed in the past three months to replace wood ones. I'm not too impressed with them if I'm being honest.
After inspecting every window in the house, I noticed small beads of water in between panels. There are 4 other panels in the house that have this issue, and it always seems to be on the non-fixed panel (the one that swings open).
I've tried to highlight this. I am no expert but this doesn't look right to me. Has the seal failed? Should I contact the installers?
Would appreciate anyone's advice
Edited by mousecat181
More information
I'm  with @dpmiller.
Please give us a few more photos - some a bit further away so we can understand what is being shown. Otherwise like you its a bit confusing.
The first photo seems to show the glass sealed unit with the beading that holds the glass in the frame removed. Is that right?
Hi guys, sorry first day I've been able to get some more pictures in daylight
Some more views attached. The water droplets are underneath the rubber strip. This rubber strip is attached to the outside glass of the window so I feel water must be seeping in behind this.
Would this effect the insulation of the window?
