Duncan62 Posted Wednesday at 10:27 Share Posted Wednesday at 10:27 Help please! I have spec'd open face cladding - what USE CLASS specification should the batten and cross battens be? I am concerned I require UC3 treated wood (pressure treated to push preservative into the wood), and not UC2 which is easily available (green treated timber that is dipped, not pressure treated. i.e. roofing battens). Because open cladding means the battens will be subject to constant moisture - I think UC3 should be spec'd? Correct? Further info: https://www.jamesjones.co.uk/assets/uploads/files/treatment/tanalith-e-suppliers-guide.pdf Then we can get into actually finding this UC3 wood in sized like 25x50mm, 50x50mm or 50x100mm, I cant find it anywhere. Link to comment Share on other sites More sharing options...
Duncan62 Posted Wednesday at 10:59 Author Share Posted Wednesday at 10:59 @ToughButterCup @the_r_sole @Gary M @markocosic @Dave Jones @joe90 what did you guys use for the battens please? Link to comment Share on other sites More sharing options...
joe90 Posted Wednesday at 18:40 Share Posted Wednesday at 18:40 UC3 Would be my choice fir longevity Link to comment Share on other sites More sharing options...
