Del-inquent Posted October 24, 2024 Posted October 24, 2024 We are having all the soffits on our Chalet Bungalow taken out shortly as they're asbestos cement and the window installers want it gone first. I'm just not sure about how to replace them, never done any on a roof structure like this before. There is nothing at all supporting the soffits at the moment, they're just sat upon the external leaf and held in place by a groove on the back of the fascia panel, nothing to attach any replacement to at all. The facia's may well be replaced as well, will have a look at the condition of them once the soffits are down as they're currently capped with UPVC (badly). Soffits are 380mm from wall to fascia. I wanted to replace them with UPVC, cheap and cheerful and as little fuss as possible and if the fascia's do need replacing (pretty likely) I'll use 18mm UPVC ones. How would you approach it?
saveasteading Posted October 24, 2024 Posted October 24, 2024 Fix a triangular batten under the rafter against the fascia, and screw up into it? 1
Del-inquent Posted October 24, 2024 Author Posted October 24, 2024 9 minutes ago, saveasteading said: Fix a triangular batten under the rafter against the fascia, and screw up into it? Would you bother with any additional support for the soffit - like ply run underneath the batten before the soffit goes on, or just straight up with some soffit?
saveasteading Posted October 24, 2024 Posted October 24, 2024 Depends on the soffit. Is it stiff and can pan that distance? You will have to fix it at the wall side too. A batten on the wall.
Del-inquent Posted October 24, 2024 Author Posted October 24, 2024 4 hours ago, saveasteading said: Depends on the soffit. Is it stiff and can pan that distance? You will have to fix it at the wall side too. A batten on the wall. I guess as it'll be sitting on top of the wall and pinned every 400mm (or thereabouts) plus supported by the fascia, probably should be okay. Can't put a batten on the wall as the wall stops just below soffit height lol
Gone West Posted October 24, 2024 Posted October 24, 2024 6 hours ago, Del-inquent said: they're just sat upon the external leaf and held in place by a groove on the back of the fascia panel Ours are fitted like that where the 1970s cavity wall alterations were made. Apparently our uPVC soffits replaced asbestos ones as well. 1
Del-inquent Posted October 24, 2024 Author Posted October 24, 2024 3 hours ago, Gone West said: Ours are fitted like that where the 1970s cavity wall alterations were made. Apparently our uPVC soffits replaced asbestos ones as well. No additional fixings used on yours either?!
Gone West Posted October 25, 2024 Posted October 25, 2024 11 hours ago, Del-inquent said: No additional fixings used on yours either?! Nope, makes it easy to remove though. 😀 1
saveasteading Posted October 25, 2024 Posted October 25, 2024 2 hours ago, Gone West said: makes it easy to remove though. That's my concern too. Will it displace if you hose it, brush it, ir with the wind? Will gaps fill with insects? 1
Russell griffiths Posted October 25, 2024 Posted October 25, 2024 far easier to find you a pick than try and explain. 1
Gone West Posted October 25, 2024 Posted October 25, 2024 2 hours ago, saveasteading said: Will it displace if you hose it, brush it, ir with the wind? Will gaps fill with insects? The wind has never moved it. I've not tried hosing it because I didn't want water going in the vent slots. I have brushed it with a broom and it was ok. To a degree it is held in place by the slot in the fascia. I won't be altering it for the time being.
Del-inquent Posted October 25, 2024 Author Posted October 25, 2024 12 hours ago, Russell griffiths said: far easier to find you a pick than try and explain. Interesting, I’d never have thought that would be sufficient on the width but I do have a habit of over-engineering everything.
Russell griffiths Posted October 26, 2024 Posted October 26, 2024 10 hours ago, Del-inquent said: Interesting, I’d never have thought that would be sufficient on the width but I do have a habit of over-engineering everything. Run the horizontal batten the full way around the house, not just little bits, you can add a batten front to back as well. 1
Conor Posted October 26, 2024 Posted October 26, 2024 On 24/10/2024 at 09:40, Del-inquent said: We are having all the soffits on our Chalet Bungalow taken out shortly as they're asbestos cement and the window installers want it gone first. I'm just not sure about how to replace them, never done any on a roof structure like this before. There is nothing at all supporting the soffits at the moment, they're just sat upon the external leaf and held in place by a groove on the back of the fascia panel, nothing to attach any replacement to at all. The facia's may well be replaced as well, will have a look at the condition of them once the soffits are down as they're currently capped with UPVC (badly). Soffits are 380mm from wall to fascia. I wanted to replace them with UPVC, cheap and cheerful and as little fuss as possible and if the fascia's do need replacing (pretty likely) I'll use 18mm UPVC ones. How would you approach it? Why are you removing them? The best practice for asbestos is to leave it be. Will the window installers work involve them cutting/drilling in to the soffits?
Del-inquent Posted October 27, 2024 Author Posted October 27, 2024 On 26/10/2024 at 09:47, Conor said: Why are you removing them? The best practice for asbestos is to leave it be. Will the window installers work involve them cutting/drilling in to the soffits? They’re in a bad way as is the facia on one end, so work is needed regardless, plus the soffit sit on top of the window frames and have been sealed to it in the past. Ideally I wouldn’t have touched it but it has to be done
TommoUK Posted October 27, 2024 Posted October 27, 2024 If it's AIB (asbestos insulation board) its nasty stuff and notifiable work. Get someone licenced to remove it and ask them for a post completion report so you can show what has been done should you sell.
Del-inquent Posted October 27, 2024 Author Posted October 27, 2024 2 hours ago, TommoUK said: If it's AIB (asbestos insulation board) its nasty stuff and notifiable work. Get someone licenced to remove it and ask them for a post completion report so you can show what has been done should you sell. Had it tested a couple of weeks back, it’s not AIB just asbestos cement board, non licensed, however I am still getting someone in to do it as I don’t want to. Some things are best left to the pros. 2
scottishjohn Posted October 28, 2024 Posted October 28, 2024 when you expose the rafters i would look carefully that they are not rotted at the 4 corners of the roof where the barge boards affix i had to cut them out and graft in bits when i was replacing my plywood soffits . iwas lucky in some ways as the actual soffits were T+g boards ,so icould nail everything to the plywood and old soffit boards very common when only single battons are used as they collect crap behind them and make sonewhere for water to sit single battons to me should never be used as there is no direct path vor water to exit ,just makes dams especially as htis is anold roof using roofing felt ,it gets hard and can disintergrate where its not supported 1
Del-inquent Posted October 28, 2024 Author Posted October 28, 2024 11 hours ago, scottishjohn said: when you expose the rafters i would look carefully that they are not rotted at the 4 corners of the roof where the barge boards affix i had to cut them out and graft in bits when i was replacing my plywood soffits . iwas lucky in some ways as the actual soffits were T+g boards ,so icould nail everything to the plywood and old soffit boards very common when only single battons are used as they collect crap behind them and make sonewhere for water to sit single battons to me should never be used as there is no direct path vor water to exit ,just makes dams especially as htis is anold roof using roofing felt ,it gets hard and can disintergrate where its not supported with the budget in its current form I intend to close my eyes and wave the hammer around blindfolded, I can’t afford to find any more problems 😂
scottishjohn Posted October 29, 2024 Posted October 29, 2024 11 hours ago, Del-inquent said: with the budget in its current form I intend to close my eyes and wave the hammer around blindfolded, I can’t afford to find any more problems 😂 on your head then you have been informed
Del-inquent Posted September 15 Author Posted September 15 A year later... only just got round to attacking this job! All Asbestos now gone, new windows in place, time to replace soffits and facia. The window installer suggested that some additional support at the top of the windows, whilst not strictly necessary, might be worth adding. So the plan now is to make the triangular hangers as previously suggested, sheet of 12mm hardwood ply over the top of those and then the UPVC soffits pinned to the ply. Partly because we can then screw the ply to the top of the window to give a bit more support, but also because the rafters are spaced all over the place so I can just pin the UPVC to the ply equidistantly. Does mean trimming the rafter feet off a bit to accommodate the ply and retain the correct height as the soffit sits on top of the wall / windows, but not too much of a faff I guess. Fortunately the rafters are all in pretty good shape. Question though - would you use treated timber for the hangers or will some CLS do? Cuts the cost by more than half just using CLS (and I have a load spare...)
saveasteading Posted September 15 Posted September 15 10 minutes ago, Del-inquent said: will some CLS do If it can get wet or is exposed to insects, then use treated timber. I suppose you could immerse your untreated timber in preservative, so that it goes into the end pores. But a tin of that is expensive itself. 1
