GeoffSmith Posted 21 hours ago Share Posted 21 hours ago Hi everyone, Just had a plumber fit a radiator in our living room, and we had him chase out the wall to fit the pipes. Everything's installed fine, I'm just wondering how I go about filling the hole in the pipes - what's the best practice? The chase is 80mm wide, and 2m long. Can I just fill it with bonding and then Easifill over the top, or do I need to fill with lime render? Ideally, since it's such a small chase, I'm hoping it's just ok to do it the modern way and avoid lime, but I'll do whatever needs to be done. Also, side question - do I have to protect the copper pipes, or if it OK to just completely surround them in whatever I end up using? Link to comment Share on other sites More sharing options...
SteamyTea Posted 18 hours ago Share Posted 18 hours ago 3 hours ago, GeoffSmith said: do I have to protect the copper pipes If it is an external wall, then yes, with insulation. Generally best to insulate pipework anyway. It is also possible that the 'filler' you use could react with the copper. Link to comment Share on other sites More sharing options...
saveasteading Posted 17 hours ago Share Posted 17 hours ago 4 hours ago, GeoffSmith said: to fit the pipes. Heat in the pipes will be lost into the wall. Can you get some foam rubber or bubblepack or similar behind them? Link to comment Share on other sites More sharing options...
Nickfromwales Posted 16 hours ago Share Posted 16 hours ago https://www.bes.co.uk/class-o-adhesive-tape-black-3mm-x-50mm-x-15m-17548/ A bit of this both sides/around, and then nail clip the pipes. Then fill over. It’s not the best things to chase a wall and bury pipes, but I’ve done it so many times I’ve lost count. Heat will leak into the wall, but a comet may also hit planet earth and kill us all, so decide if a neat room is important and accept the compromise afaic As per @SteamyTea’s comment, under NO CIRCUMSTANCES should you render or fill onto bare copper pipes. In a previous life, if I had to do this, I usually used 10mm plastic coated copper. Link to comment Share on other sites More sharing options...
GeoffSmith Posted 15 hours ago Author Share Posted 15 hours ago (edited) Argh, bugger, I don't think that's going to be possible, there won't be enough room to put a jacket round the pipes and the plumber has filled a bunch of it with expanding foam to hold in place. It is an external wall, but it's a cavity wall with foam bead insulation I'll see if I can get enough space around the pipes to cover with that tape, thanks so much for the advice. As per the material, can I just use normal bonding instead of lime? Edited 15 hours ago by GeoffSmith Link to comment Share on other sites More sharing options...
Andehh Posted 14 hours ago Share Posted 14 hours ago Wrap pipes in duct tape, slight fill of expanding foam behind them? That's gotta get you half way there? Link to comment Share on other sites More sharing options...
Andehh Posted 14 hours ago Share Posted 14 hours ago Even try Armaflex tape? Link to comment Share on other sites More sharing options...
saveasteading Posted 12 hours ago Share Posted 12 hours ago 3 hours ago, GeoffSmith said: the plumber has filled a bunch of it with expanding foam AAArrggh. Maybe it will be ok.....but expanding foam is used far too often because it is a quick bodge. Does the can say anything about heat / shrinkage /reactions against copper? Link to comment Share on other sites More sharing options...
Nickfromwales Posted 4 hours ago Share Posted 4 hours ago 10 hours ago, Andehh said: Even try Armaflex tape? Same kind of stuff I linked above, just a cheaper brand Link to comment Share on other sites More sharing options...
Nickfromwales Posted 3 hours ago Share Posted 3 hours ago 12 hours ago, GeoffSmith said: Argh, bugger, I don't think that's going to be possible, there won't be enough room to put a jacket round the pipes and the plumber has filled a bunch of it with expanding foam to hold in place. It is an external wall, but it's a cavity wall with foam bead insulation I'll see if I can get enough space around the pipes to cover with that tape, thanks so much for the advice. As per the material, can I just use normal bonding instead of lime? Bonding will be fine, just don’t try to fill it all in one set. Half fill, leave 24hrs, then final fill just a bit shy. Then finish with Easi-fill or Tupret filler which will sand back easily. If you need to remove the plumbers foam then it’ll just scrape out tbh. Link to comment Share on other sites More sharing options...
