Hi everyone,
I have a flat roof that has started to sag and has recently started to leak on occasion. The problem area is about 1msq of deck, although I haven't lifted the felt yet.
is it feasible to cut into the felt and do a large patch repair, replacing the board underneath and then just joining to the old felt? Or is this I'll advised?
highly unlikly you.will get away with that if its sagging
 must be totally sodden  and where is all that water going ,what damage to other fabric of roof
and what about the rot on the joists below the board?
 or just use a gallon  of roof repaur iiquid if it drys out enough put it off  till spring?
i am guessing it is a livable space below ?
then any insulation will be wet as well
 guessing its av older house if its been done with felt ,so insulation is probably fibreglass wool which will hold water and spread it about
 maybe remove section of plastergoard from ihside to look ,as if its been wet it it need changing anyway
you can do a rough patch  inside once you have looked if it looks sound ,for the winter
 as said above  pictures would be good
Disclaimer.
This is a bodge up, but will get you a few years before you need to look at it again.
Did the same job this weekend on a building that will be demolished in a couple of years.
strip off 1400 x 1400 area back to the boards
rip up the soft boards back to the joists
cut a patch of new plywood or osb to fill the hole.
cut felt and stick down to match height of existing roof, or higher.NOT LOWER.
fill all gaps and joins with a roofing type sticky something
clean an are far larger than patch 2mx2m
cover entire area with a fibre reinforced coating.
BOSTIK FLEXACRYL is what I used, very impressed but not cheap.
Thanks Russell! Is there any reason you didn't use torch down? My existing roof is bitumen and so I am aware that adhesives don't mix well.
