I cannot see how a coated pipe surface would fundamentally change the bacterial levels in an airflow, just not enough area, mixing and time.
If bacterial growth in HVAC systems was a real problem, they they would not be allowed in buildings.
  On 13/10/2024 at 13:07, SteamyTea said:
….was a real problem, they they would not be allowed in buildings
Expand
Bet they said that about asbestos once, long ago.
When one embraces relatively new technology, or materials, or indeed design practices, one is taking more of a risk.  That’s the good news about being a wrinkly self builder.  Mistakes will only be a bother for a small number of decades, tops.
Had a look to see what I bought, it didn't say assume non bacterial.
Air being supplied is being filtered, so not sure is much of an issue. Extract normally isn't, but we use terminal filters to catch the rubbish being sucked out the room, so don't see where the issue would be there either.
Not sure how long an anti bacterial coating would last before it was depleted.
  On 13/10/2024 at 15:50, saveasteading said:
Isn't the potential issue the build-up of crud in the pipe?
Expand
Yes, but it is probably not a real problem.
This week's Curious Cases was about a similar thing, the 5 seconds rule, or is it 3 seconds.
Expand
Usually a silver coating.
From here
"The continued presence of silver on coated tubes has been shown for as long as three weeks, and coated tubes have demonstrated lower colonization rates for 19 of 21 bacterial strains tested"
