Looking for a recommendation for a cheap, simple thermometer so that I can check the temperature of my house when I'm not there.
The ones I'm looking up seem to want to link with Alexa etc, I just want a basic standalone unit.
I don't specifically need any kind of history or data logging function, but I guess it would be nice.
Bonus points for one that doesn't need to run off batteries, and/or it has a probe that I can tape on to the outlet of my UVC...
I use sonoff (TH100 from memory) - mains powered - can do temp and humdity with one type of sensor or just temp with another type
power consumption is very low
can use an app on my phone to see temps/humidity from anywhere over wifi or 4G
 Logs data hourly and keeps up to 12 mths data
If you feel ‘advanced’ you could go down the home assistant route . I avoid where possible battery sensors - though the current zigbee ones seem to be lasting over a year .
2 hours ago, JohnMo said:
Shelly H&T. Gen the usb version than it stays plugin without need for batteries.
Actually - this is the best solution
  • 2 months later...
The link I posted gives me the following page.
I took delivery of mine today and work fine.
It’s linked to my WiFi.
Edited by Johnnyt
  • 3 months later...
Update:
A friend installed a Raspberry pi based system with wireless thermometers, which worked perfectly... for about a month.
I've decided that I'm going to go with the very low tech approach instead: a set of sensors linked to a display, and a camera pointing at the display. It's kind of ridiculous to do it this way but I already have the camera in position and the total cost is only £25. Obviously I don't get data logging etc but at least the damn thing will actually work.
My RPi Zero W is still working.  It logs and sends the data via the TOR network (did that bit just for fun).
I'm sure it can be made to work. A friend set mine up as a favour when he was passing through. I don't really want to keep pestering him to fix it as he was very kind to spend the time (and money, it's his Pi).
Maybe when I'm next home in ~6 months I can get it working properly.
