oldkettle Posted November 8, 2017 Posted November 8, 2017 Hi, The old actuator we have for CH/HW valve hardly moves any more even though I can hear (and see) it trying and turning the head a bit. The plastic in it is already broken but I can move the valve with my fingers so it is not stuck. Here is how the whole setup looks https://www.flickr.com/photos/97587014@N08/shares/298y9j And here is the actuator https://www.flickr.com/photos/97587014@N08/shares/397z1A I looked it up and the new ones cost in excess of £120. There seem to be refurbished ones on ebay : https://www.ebay.co.uk/itm/DM5601-SUNVIC-DUOVAL-2-PORT-4-WIRE-MID-POSITION-MOTOR-NEW-ACTUATOR/162735175159?epid=1310816191&hash=item25e3c5b5f7:g:E~YAAOSwgeRZnEU0 (the name seems wrong as it should be 3-port but the pictures and the name are a match) What is the best option for me here - based on our hopes of ripping it all off next summer STUC :-) It feels like a professional would take an hour to install a completely new system, but it would probably have to be re-wired, thermostat replaced etc, which is not really feasible. Is there a reasonably priced direct replacement for the valve + the actuator that wouldn't require drastic changes everywhere else? Or should I just buy off ebay as I then should be able to install it myself and with 1 year warranty it is a reasonable temporary solution? Thanks in advance.
PeterW Posted November 8, 2017 Posted November 8, 2017 That eBay one is brand new - they use a standard listing and I’ve ordered from them and they are fine. Should take 20 mins tops to change it. 1
oldkettle Posted November 8, 2017 Author Posted November 8, 2017 @PeterW, thank you Does it look the right item? They say 4 wire but I think I can see 5 in their picture. The product code is the same. Just before I press the Buy button...
Nickfromwales Posted November 8, 2017 Posted November 8, 2017 1 hour ago, oldkettle said: @PeterW, thank you Does it look the right item? They say 4 wire but I think I can see 5 in their picture. The product code is the same. Just before I press the Buy button... Is yours a 5-wire? If so then it's a match.
oldkettle Posted November 9, 2017 Author Posted November 9, 2017 Thank you, Nick. I will check in the evening. What confused me was that most 5601s say 5 wire and 3 port in the description unlike this one.
PeterW Posted November 9, 2017 Posted November 9, 2017 Ok that could be due to the earth wire - some count it and some don’t...! Drop them a question - you should have 4 coloured wires on yours if you have a quick look in the wiring centre. 1
oldkettle Posted November 9, 2017 Author Posted November 9, 2017 Thank you, Peter, yes, will check the wires in the evening. They also said 2-port even though it is clearly a 3-port one. Will ask them as well.
oldkettle Posted November 13, 2017 Author Posted November 13, 2017 Got the replacement actuator now, wanted to lubricate the valve while it is open. Any recommendations on what to use? WD40? Silicone lubricant (I have 3-in-one which I use for my bike)?
Jeremy Harris Posted November 13, 2017 Posted November 13, 2017 (edited) Don't use either WD-40 or 3-in-1, as both have the potential to damage seals from the solvents they contain and neither is a particularly good lubricant. WD-40 is most definitely not a lubricant, the name is an abbreviation of "Water Dispersant Type 40", and "3-in-1" is a mixture of light machine oil and solvents, intended to work as a short duration lubricant, a cleaning agent and an anti-seize agent. High temperature silicone grease is generally pretty safe on anything, and is most probably what is used as the assembly lubricant originally. I keep an aerosol can of "O ring safe" motorcycle chain lubricant around for jobs like this. You can be sure that the solvent that allows it to penetrate won't damage seals, and the resulting heavy grease is non-corrosive and resists pretty high working temperatures OK. Edited November 13, 2017 by JSHarris 1
Onoff Posted November 13, 2017 Posted November 13, 2017 (edited) +1 on silicone grease, NOT silicone spray. Been using it for years on F and co-ax connectors and crimp connectors of all sorts. I dip the stripped wire into the grease then put the crimp on. I dip crimp spades into it too before putting together. Just using it now where the rear wash wipe spindle passes through the rear screen in the Golf. Battery terminals on the cars... The lads at work use it on the actuator spindles in fan coil units too. I use silicone spray on some plumbing stuff and the door seals on the car Edited November 13, 2017 by Onoff 1
dpmiller Posted November 13, 2017 Posted November 13, 2017 Best not to use silicone spray on door seals, it can dry out the foamed rubber used. The right stuff is the wonderful Gummi-Pfledge. 1
Onoff Posted November 13, 2017 Posted November 13, 2017 48 minutes ago, dpmiller said: Best not to use silicone spray on door seals, it can dry out the foamed rubber used. The right stuff is the wonderful Gummi-Pfledge. I never knew or had even heard of it. I'll get some.
oldkettle Posted November 13, 2017 Author Posted November 13, 2017 Thank you everybody, it seems the closest I have is bike lithium grease. Will just order some. Any particular brand for the grease? Or something like this http://www.ebay.co.uk/itm/200g-silicone-grease-HIGH-TEMPERATURE-lubrication-seals-plastics-rubber-/172536887187 or that https://www.amazon.co.uk/Silverhook-SGPGT90-Silicone-Grease-Tube/product-reviews/B00W6Q3B1G/ref=cm_cr_dp_d_hist_3?ie=UTF8&filterByStar=three_star&reviewerType=all_reviews#reviews-filter-bar will do?
