Afternoon all,
I'm designing the bathrooms which I will be installing myself into our new build. I've previously done complete bathroom renovations, from bare plaster up, which have still been fully functional 10 years later, so I'm not worried about implementing a working bathroom. I am however not up to date on the regulations, which I'm reading through at the moment.
So just to make sure I don't miss anything, are there any recent regulations that commonly trip people up? I'm aware of the requirement for a TMV for the bath. I'm using a AAV for the bath to prevent the risk of siphoning the sink or toilet. Is there anything else that commonly causes issues?
Thanks in advance
Pete
Expand
Wimmin.
"There you are darlin' ...  " says @peteypops with a big (this means Brownie Points) smile and flourish
"Errr...." ( she hoists a storm warning - with a matching smile natch)  "WhatAboutThe [.....] sweetheart ?"
" But you didn't ask for one of those "
Foot tapping starts ......
"Well I'd have thought that was obvious ...... "
  • Haha 2
You may joke! I've been very careful on that front, the lady of the house has been responsible for choosing all the big ticket items while I'm responsible for implementation. Safety first!
Activity spaces in front of basins, showers and toilets.
I wondered if the over large bath that SWMBO specified would cause an issue but nobody looked or cared.
Expand
Thanks, I have covered that one.
TMV for the bath
Expand
Please tell me I don’t have to fit one of these on each of my bath and all the showers!  We’re looking at a nice big hot water cylinder which can be heated to circa 50c to be nice and efficient for the heat pump.
Expand
Fit a TMV mixing valve after the UVC so all hot water is pre-mixed with cold to 43°C or whatever the requirements. I think it might be part of the standard UVC schematic, I could be wrong.
Edited by Nick Laslett
  On 26/09/2024 at 13:38, Mike said:
And, while not a rule, beware of flexible tap connectors:
Expand
I used these on my last bath room which was still fine after 10 years. Is it possible that product quality is an issue here? As in, buying a hotels worth you might go for a cheaper option, buying half a dozen this is not an issue.
Expand
Bath only with a maximum temperature of 48 degrees C, the intention was to prevent scalding by getting into/being put into a large body of very hot water and not being able to exit swiftly, presumably one can dodge out of a too hot shower easier (although most showers have a high temperature stop that has to be over ridden, if like my wife you want a shower hot enough to peel off the skin!))
Expand
UK regs say -
3.68 The length of supply pipes between in-line
blending valves and outlets should be kept to
a minimum in order to prevent the colonisation
of waterborne pathogens.
So, if it's being checked by building control that might cause issues.
Expand
But not if you have hot water circulation. As there are issues with very hot water making its way past the TMV.
Couple of simple ways to mitigate
1. Just set your tank temp to 48 to 50 degs, then no need to have a TMV at all.
2. If you have a mixer tap on the bath this issue should be taken care of by the mixer.
Expand
Expand
I've used them many times in the past too. AFAIK they're all still fine. But, having seen the damage that can be caused, I no longer take the risk. Reliable alternatives are readily available.
Expand
Yes and no.
Being a hotel, they'd undoubtedly have specified connectors to BS EN 13618 (or it's predecessor - they'd been installed at least 10 years previously). It's more likely a DIYer would ignore that (or not even think of looking for it).
However it seems clear that that standard isn't good enough, so to that extent yes, product quality is an issue. However to pick something of higher quality you'd need to evaluate manufacturers' data on the quality and thickness of the brass / rubber / stainless stainless steel braiding that they use, and the resistance to water hammer / temperature / chemicals - if you can find anyone who publishes that.
Edited by Mike
