Good afternoon.
We're trying to work out how much build up we should allow when laying 10mm porcelain tiles on top of a new liquid screed floor (Cemfloor). Would a self leveling compound be required or any matting? Any advice greatly appreciated.
Thanks
Cemfloor should be fairly flat.  I have just had one poured and apart from a few surface imperfections, which will scrape off easily, it is very flat, so you could not slide a piece of paper anywhere under a 6' level.
Our Cemfloor was bob-on level, could have been tiled onto directly. Our tiler at the time insisted on a mat, I think because that's what he knew. I'm not convinced it needed one.
You were lucky I could have slid a 6’ level under a 6’ level on mine. It’s tiled now and nearly forgotten.
  • Haha 1
5 hours ago, nod said:
The thickness of your tiles x2 No matting needed
Sorry just spotted the "x2", what to you mean? Thanks
If you are using a ten mil tile You use a ten mil notched trowel
The thickness of your tile dictates the thickness of your adhesive
So in your case allow 20 mil buildup
Others tiling into timber or traditional screed would also allow for a decoupling Matt 5-6 mil
