GaryChaplin Posted August 3 Share Posted August 3 Hi all, I'm putting the mains water supply into my build, following the guidelines from Anglian Water. But I'm unclear on how close the water supply can be to the mains supply when it is within the building? The only guidance I have is that it cannot be less than 350mm, but I thought this was just underground. "Note: Your water pipe must be at least 350mm away from all other utilities." Can anyone provide any clearer guidance, quoting building regulations perhaps? Surely water cannot be kept away from mains power throughout the inside of the building? Thanks, Gary Link to comment Share on other sites More sharing options...
Conor Posted August 3 Share Posted August 3 That text refers only to the water main in the ground. Nothing to do within the building. Link to comment Share on other sites More sharing options...
Dave Jones Posted August 3 Share Posted August 3 same trench side by side. dont worry there are no pipe separation measuring police. 1 Link to comment Share on other sites More sharing options...
GaryChaplin Posted August 4 Author Share Posted August 4 Thanks. I've just asked Anglian Water, so we'll see what they say. Seems a bit ridiculous once it's in the house. Link to comment Share on other sites More sharing options...
Mr Punter Posted August 4 Share Posted August 4 37 minutes ago, GaryChaplin said: Seems a bit ridiculous once it's in the house. As per @Conor, there is no spec when they are in the house. Link to comment Share on other sites More sharing options...
GaryChaplin Posted August 5 Author Share Posted August 5 Would be good to know where this is referenced in the BC regs. Link to comment Share on other sites More sharing options...
FuerteStu Posted August 5 Share Posted August 5 I seem to remember a BC guy saying that services should be at least a shovel width apart.. Logic being that if you need to dig one out to repair, you aren't hitting the other services. Makes sense Link to comment Share on other sites More sharing options...
GaryChaplin Posted August 6 Author Share Posted August 6 On 05/08/2024 at 17:39, GaryChaplin said: Would be good to know where this is referenced in the BC regs. OK, so I've heard back from Anglian Water asking for a citation, apparantly this 'ruling' is from the "The Water Supply (Water Fittings) Regulations 1999." Quote: "The requirement is a safety measure when installing pipework internally and externally as per The Water Supply (Water Fittings) Regulations 1999. These regulations are a legal requirement to keep water quality safe. The regulations include information on how external pipework and internal plumbing must be installed and maintained and these are similar in nature to Building and Gas regulations." So I looked, nothing there referring to 350mm distances https://www.legislation.gov.uk/uksi/1999/1148/contents. Nevermind, I'll just pretend they are a knowledgeable authority and change my plans! Link to comment Share on other sites More sharing options...
GaryChaplin Posted September 30 Author Share Posted September 30 Just thought I'd follow this up to say that the inspection engineer said this only applies to underground work, what you do in your house is up to you. Link to comment Share on other sites More sharing options...
Nickfromwales Posted September 30 Share Posted September 30 We usually ask for a 400mm bucket for excavation, with one service laid either side. Link to comment Share on other sites More sharing options...
sharpener Posted October 8 Share Posted October 8 On 03/08/2024 at 07:37, GaryChaplin said: Can anyone provide any clearer guidance, quoting building regulations perhaps? Surely water cannot be kept away from mains power throughout the inside of the building? FWIW the IET On-site Guide says wiring must be separated by 25mm for gas pipes up to 35mm dia, and CUs by 150mm unless non-combustible insulation is interposed, but nothing at al about water installations. Link to comment Share on other sites More sharing options...
